I'm currently evaluating using BME680 + BSEC software and was wondering what the optimum way was to switch between LP & ULP (and vice versa) while the sensor & library is running.
- Can I simply call "updateSubscription" with the new "BSEC_SAMPLE_RATE_..."? or...
- Do I need to reinitialize as if it's turned on for the first time? i.e. with "begin(...)" & "bsec_virtual_sensor_t" & "updateSubscription" commands? or...
- Do I need to soft-reset the BME680 before doing the above?
Ideally, I would like to keep the calibration data when switching e.g. calibrate quickly using the 3s mode then switch to the 5min mode after IAQ accuracy >1 is achieved.
I had some concerns as the integration guide mentions: "To achieve best gas sensor performance, the user shall not switch between LP and ULP modes during the life-time of a given sensor"
Any advice would be great.Thanks!
