BMI088 gyroscope does not communicate properly via I2C
I have been trying to use BMI088, communicating via I2C at 400kHz.
The accelerometer part of the chip works perfectly, reading our correct acceleration values,
but I get completely wrong results from the gyroscope.
Already the chip ID register #0 reads out 0x0a, while it should
be 0x0f according to the datasheet and the registers with angular
velocities read out highly fluctuating 'random' numbers with the sensor lying on the table.
I have tried two modules, first a module obtained from SEEED studio, and later
the original Bosch shuttle board with BMI088, purchased from Mouser, connected for I2C communication according to the datasheet.
(I was afraid the chinese one might be a poor clone of the chip.)
However, both modules did show the same problem. The code marking on the chips is:
365/P1827/001 and 365/P1827/008 respectively.
I am using STM32F37 MCU and code based on STM's library for I2C and
several other I2C sensors worked well in the setup.
Since the I2C communication with the BMI088 accelerometer works perfectly,
I do not see where could be the problem  with my I2C connection/software.
I am using I2C address 0x19 for acc. and 0x69 for gyro (with appropriate
pullups), 3V3 power.
So I am really puzzled with the problem. Do you have any ideas?
With best regards,
Jiri Pittner
Best reply by jpittner
I found it eventually - the culprit was a fault 24C16 eeprom on the same bus, which obviously confused its address
and entered into the communication, spoiling it. After replacement by another eeprom (different size/manufacturer) it all works fine.
