    BMP series pressure sensor design guide
     Selecting the right part
    The BMP series of pressure sensor contains 2 products: BMP280 and BMP388. Table 1 shows an overview of the features.
                                                        Table 1: Overview of the products in this family
    Key features
    • LGA with metal lid package
    • SPI or I2C interface
    • Built-in IIR filter.
     Differences between products
    The main differences in the BMP product family are in the thickness of the package, and the overall performance of the MEMS element. BMP388 offers higher performance in a smaller package compared to BMP280. See the complete list of differences in Table 2.
                                              Table 2: Differences between BMP product family members
    Available evaluation tools and software
    To best to evaluate the products from the BMP family, we recommend the following combination of evaluation tools:
    Reference design
    Figure 1 shows a complete schematic of a typical use case.
        BMP280
    8.png        BMP388
                                                           Figure 1: Exemplary Reference design
      Bill of materials
    1.png                                            Table 3: Bill of materials
    Layout recommendations
    Because the BMP sensor family contains tiny mechanical structure inside the package, care must be taken during the layout phase to ensure the best performance. The complete handling and soldering guide can be found on the Bosch Sensortec’s website.
    BMP28x Handling, soldering & mounting instructions
    BMP380 Handling,soldering & mounting instructions
    In addition to the attached guidelines, see below for the typical manufacturing procedure for the BMP388 pressure sensor.
        BMP280
        BMP388
                                                             Figure 2: Recommended landing pattern
    Typical Layout
        BMP280
        BMP388
        Figure 3: Typical layout
    Manufacturing notes
    4.png                                                              Table 4: Manufacture recommendation
    First power-on
    After powering on the sensor for the first time, the initial specs would be tested for communication with the device. This can be done simply by reading the chip identification code in the register 0xD0 (BMP280) 0x00 (BMP388). See below for the expected values:
                                                             Table 5: Chip IDs of the BMP product family
    Here is some sample code on how to perform this test, based on the BMP388 , using the COINES software as the host.
     * @brief This internal API is used to check the bmp388 sensor chip ID
     * @param[in] void
     * @return void
    static void init_bmp3(void)
        int8_t rslt;
        rslt = bmp3_init(&bmp3Dev);
        if (rslt == BMP3_OK)
            printf("BMP3 Initialization Success!\n");
            printf("Chip ID 0x%X\n", bmp3Dev.chip_id);
        else
            printf("Chip Initialization failure !\n");
            exit(COINES_E_FAILURE);
    How to read sensor data
    Here is some sample code on how to read sensor data, based on the BMP388, using the COINES software as the host
     * @brief This internal API is used to read the streaming data in a while loop and
     * print in console.
     *  @param[in] void
     *  @return void
    static void read_sensor_data(void)
        int times_to_read = 0;
        while (times_to_read < 200)
            bmp3_get_sensor_data(BMP3_ALL, &bmp3_comp_data, &bmp3Dev);
            printf("T: %.2f, P: %.2f \n", (bmp3_comp_data.temperature / 100.), (bmp3_comp_data.pressure / 100.));
            fflush(stdout);
            coines_delay_msec(10);
            times_to_read = times_to_read + 1;
     Sample code
    The complete sample code shown above can be compiled and executed from the COINES installation directory (by default, C:/COINES under Windows), from the following subfolder: \examples\c\bmp3
    Usage
    The COINES installation provides sample code on how to turn on the sensor, configure it and read out the pressure data. COINES\v1.0\examples\c\bmp3
    Sample code
     *  @brief Main Function where the execution getting started to test the code.
     *  @param[in] argc
     *  @param[in] argv
     *  @return status
    int main(int argc, char *argv[])
        int16_t rslt;
        struct coines_board_info board_info;
        init_bmp3_sensor_driver_interface();
        rslt = coines_open_comm_intf(COINES_COMM_INTF_USB);
        if (rslt < 0)
            printf("\n Unable to connect with Application Board ! \n"
                   " 1. Check if the board is connected and powered on. \n"
                   " 2. Check if Application Board USB driver is installed. \n"
                   " 3. Check if board is in use by another application. (Insufficient permissions to access USB) \n");
            exit(rslt);
        rslt = coines_get_board_info(&board_info);
        if (rslt == COINES_SUCCESS)
            if (board_info.shuttle_id != BMP3_SHUTTLE_ID)
                printf("! Warning invalid sensor shuttle. This application will not support this sensor \r\n"
                       "1.Check the sensor shuttle \r\n"
                       "2.Reset the board  \r\n");
        init_sensor_interface();
        /* after sensor init introduce 200 msec sleep */
        coines_delay_msec(200);
        init_bmp3();
        read_sensor_data();
        coines_close_comm_intf(COINES_COMM_INTF_USB);
        return EXIT_SUCCESS;
    Further reads
    Datasheets:
    Application notes:
    Handling, soldering and mounting instructions
    Version history
    Revision #:
    11 of 11
    Last update:
    ‎08-14-2019 10:25 AM
    Updated by:
    Contributors
