Dear colleagues,
I have a question regarding changing the sample rate of the BME688 in BSEC2 library
In BSEC1 I simply use continuous Mode, in BSEC2 it is not very clear to me how to get 1 sec sample rate, if there is a simple code for this it will be much appreciated, thanks for help
Hello Al-Okby,
In BSEC2 integration guide, there was sample rate option table, you could set it in your code.
Hello BSTRobin,
Thank you for helping me,
could you please help me in modifying the example of BSEC 2, what should I change to get a 1sec sample rate for IAQ instead of approximately 10 sec
I attached a copy of my serial monitor
Best regards
al-okby
