    AI-Studio Server
    AI-Studio Server
    estani
    I have downloaded the linux version, unzip and run successfully the login commands. But when I try to run docker-compose (inside the right folder) I get an error message saying:
    Can't find a suitable configuration file in this directory or any parent. Are you in the right directory?
    Inside the server folder, there are just three files:
    - bst-bme-aistudio-server
    - LICENSE
    - README.md
    What's going on?
    Am I missing a file or should I run a different command?
    13 REPLIES 13
    Somewhere there is an engineer that has a docker-compose.yml that works.  They just need to find that person and share the file.  At this point I don't have a lot of hope.
    Jim...
    Hi all,
    Please refer to the following solution.md file.
    # BST BME AI-Studio Server
    ## Requirements
    - Linux for BST BME AI-Studio Server
    - Running PostgreSQL Server v14.x thet can be accessed from the host running BST BME AI-Studio Server
    ## Setup
    Configuration of BST BME AI-Studio Server is done setting environment variables.
    The following example starts BST BME AI-Studio Server listening on port 8080 and accesses a PostgreSQL database server running on port 5432 on localhost:
    ```bash
    $ PGHOST=127.0.0.1 \
    PGPORT=5432 \
    PGDATABASE=my_existing_db \
    PGUSER=my_existing_pg_user \
    PGPASSWORD=my_secret_passowrd \
    PORT=8080 \
    ./bst-bme-aistudio-server
    These options can be set as environment variables:
    - PGUSER - (required) The postgres user name. Note that the user needs permissions to create tables in the configured database.
    - PGPASSWORD - (required) The password of the postgres user.
    - PGDATABASE - (required) The name of the postgres database to use.
    - PGHOST - (optional) The hostname (or IP) of the postgres server to use. Only use this option if an external database server is used.
    Default: 127.0.0.1
    - PGPORT - (optional) The port the postgres server is listening on. Only use this Default: 5432
    - PORT - (optional) The port BST BME AI-Studio Server is listening on for HTTP requests.
    Default: 3000
    - LOG_LEVEL - (optional) The log level to use in BST BME AI-Studio Server. Logs are written to stdout/stderr.
    Options: error, warn, info, debug.
    Default: info
    Note that BST BME AI-Studio Server does not restart automatically on process termination. So it is recommended to use a service manager (e.g. systemd) to start and manage the service.
    ## API
    By default the API is exposed on port 3000. So locally the API doc can be accessed at [http://localhost:3000/api/v1/api-docs](http://localhost:3000/api/v1/api-docs).
    Hi all,
    If any feedback, please send it here. Thanks.
    Hi Jim!
    I agree with you, at least, there should be included docker-compose.yml file.
    When I try to run bst-bme-aistudio-server without any configuration, env variables, I get
    $ ./bst-bme-aistudio-server
    Illegal instruction (core dumped)
    I tried to setup up everything (db, env variables) manually and I'm getting Illegal instruction (core dumped) error.
    I will write instructions so I hope someone will reporduce it and see is problem in my amd ryzen 5 cpu or virtual box.
    0. Enter in superuser mode
    sudo su
    1. Verify that you have docker installed
    docker --version
    Docker version 24.0.5, build 24.0.5-0ubuntu1~20.04.1
    2. Download postgredb
    docker pull postgres
    3. Set Environment variables
    #  PGHOST=127.0.0.1
    #   PGPORT=5432
    #   PGDATABASE=my_existing_db
    #   PGUSER=my_existing_pg_user
    #    PGPASSWORD=my_secret_passowrd
    #    PORT=8080
    4. Verify with echo $variable commad that they exist, like in example below.
    # echo $PGHOST
    127.0.0.1
    # echo $PGPORT
    5432
    # echo $PGDATABASE
    my_existing_db
    # echo $PGUSER
    my_existing_pg_user
    # echo $PGPASSWORD
    my_secret_passowrd
    # echo $PORT
    8080
    5.  Run Postgre Container
    $ docker run -itd \
    -e POSTGRES_HOST=127.0.0.1 \
    -e POSTGRES_USER=my_existing_pg_user \
    -e POSTGRES_PORT=5432 \
    -e POSTGRES_DB=my_existing_db \
    -e POSTGRES_PASSWORD=my_secret_password \
    -p 5432:5432 \
    -v /data:/var/lib/postgresql/data \
    --name postgresql \
    postgres
    6. Verify container is running
    $ docker ps
    CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
    1a6401934f34 postgres "docker-entrypoint.s…" About a minute ago Up About a minute 0.0.0.0:5432->5432/tcp, :::5432->5432/tcp postgresql
    7. Run bst Bme Studio Server
    Could developers be some kind and provide us docker compose yml file and instructions to run it automatically as well.
