07-09-2021 10:38 PM
How can I access pressure, temperature, humidity, gas, and IAQ data from the BME688 using the AI studio? At the moment, I am interested in comparing data from the BME688 with publicly available atmospheric data. I am not interested in training an algorithm.
07-12-2021 08:18 AM
Hello avfe,
If you only want to get pressure, temperature, humidity, gas, and IAQ data from the BME688, you could download and use BSEC 2.x software from https://www.bosch-sensortec.com/software-tools/software/bme688-software/
07-12-2021 08:33 AM
Hello Yi_Song,
Did you follow the two steps?
1.do axis remapping from BMI270 to wearable device co-ordinate system;
2.Follow the section "Wrist wear nevigation gesture detector" in data sheet, follow demonstration action and explaination of register configuration, test it on your device.
07-15-2021 10:12 PM
Is it possible to access this information given that I have the BME688 development kit? Or is the AI studio the only way to interface with the 8 BME688s? I am currently trying to use the BSEC library, but am having difficulty.l
08-03-2021 12:39 AM
