    Application versions for BMI270
    Ethan
    I am trying out with BMI270 shutter board. From the description:
    https://www.bosch-sensortec.com/news/bosch-launches-smart-ultra-low-power-imu-bmi270.html
    There are two application-specific versions: gesture and context/activity.
    For our usage, I think the geture version will help more.
    The data sheet seems very straight forward to set up.
    But after I enabled activity and gesture, seems I can only get activity works.
    Tried disable activity and enable gesture/wake up only, still no output for the gesture feature.
    So I am wondering, what the meaning of two application specific versions?
    Are they both implemented and coexisted in same chip?
    Any specific register operation to enable the gesture version?
    2 REPLIES 2
    Vincent
    Re: Application versions for BMI270
    Yes, BMI270 have two different feature set according to gesture and context / ativity.
    Both two are based on different configuration string.
    Suppose you are using the API from our Github.  In that package, you can see bmi270.c and bmi270_context.c.
    So if you want to use context feature,  you should using the bmi270_context_config_file instead of bmi270_config_file during initialize the sensor.
    Ethan
    Thanks Vincent,
    Before, I used the zephyr project with BMI270 driver from your company's forked branch.
    Seems that driver initialized BMI270 without gesture feature.
    Maybe worth to add a property for zephyr BMI270 device to set feature, etc.
    After changed to the API and referred to wrist_gesture example.
    It works now. Got valid gesture output.
