    Arduino Nicla BHI260AP Timestamp and Data Logging to SPI Flash
    Moechl
    Hey everyone,
    I have posted this question two weeks ago in the Arduino forum but have not revceived any answers.
    I did an extensive amount of research and went throught the Arduino_BHY2 source code, but at this point, help would be much appreciated.
    I want record an acceleration signal with a rate of 1000 to 3200 Hz with a duration of 10 seconds, if possible. Afterwards I forward the data to a PC using USB. I use the Nicla Sense ME because it has an accelerometer and a 2 Mb data logging flash.
    I have written code (below) that does that at 1000 Hz, but for a shorter sample length of 0.5 seconds.
    I have two questions:
    1. My measurement is for verification of a mechanical system and I need to be able to trust the measurements. Therefore I would like to have a timestamp from the sample creation.
    I store my own timestamp in datalines[i][0]. As you can see in the output, the timing is all over the place, which is not much of a surprise, because my timestamp is made after transfer via serial from the sensor and buffering. Does anyone know how to get a timestamp for the respective reading from the sensor? Or can the sensor just be trusted with 1kHz samples?
    2. With my 0.5 second sample I already max out the Nicla's RAM. There is a data logging flash (MX25R1635FZUIH0) connected via SPI. I really don't want to start from scratch using the flash's data sheet, can anyone recommend a library or any simpler solution?
    Help would be much appreciated! I'm also happy to receive feedback on my coding as I think there is still a lot to learn for me.
    Thank you
    Moechl
    Code:
    #include "Arduino.h"
    #include "Arduino_BHY2.h"
    #include "Nicla_System.h"
    #define SAMPLE_LENGTH 500 //number of samples recorded; 500 is about the maximum for this RAM
    int sampleInterval = 1000; //microseconds
    int l = SAMPLE_LENGTH;
    int16_t datalines[SAMPLE_LENGTH][4]; // array where the data is stored
    SensorXYZ accel(SENSOR_ID_ACC);
    void setup()
    Serial.begin(115200);
    while (!Serial);
    BHY2.begin(); //methods are defined in Arduino_BHY2.cpp
    accel.begin(1000, 0); //sample rate 1000 Hz, 0 ms latency
    nicla::begin();
    nicla::leds.begin();
    BHY2.delay(50);
    static auto sampleTime = micros();
    static auto startTime = millis();
    /* record values to datalines */
    for (int i = 0; i <= l; i++) {
    while (micros() - sampleTime < sampleInterval) {
    BHY2.update(); // Update function should be continuously polled
    datalines[i][0] = millis() - startTime; //does not give a good timestamp
    datalines[i][1] = accel.x();
    datalines[i][2] = accel.y();
    datalines[i][3] = accel.z();
    BHY2.delay(50);
    /* write the data to PC over serial */
    for (int k = 0; k <= l; k++) {
    Serial.println(String(datalines[k][0]) + "," + String(datalines[k][1]) + "," + String(datalines[k][2]) + "," + String(datalines[k][3]) + ";");
    delay(30);
    void loop()
    // blink so I know it is done
    nicla::leds.setColor(green);
    delay(1000);
    nicla::leds.setColor(off);
    delay(1000);
    Output Excerpt:
    14:03:15.948 -> 1,1836,-816,3702;
    14:03:15.988 -> 33,1830,-823,3720;
    14:03:16.029 -> 34,1845,-824,3710;
    14:03:16.069 -> 39,1843,-822,3732;
    14:03:16.069 -> 41,1841,-812,3723;
    14:03:16.109 -> 42,1834,-816,3735;
    14:03:16.149 -> 43,1834,-816,3735;
    14:03:16.190 -> 44,1829,-826,3724;
    14:03:16.230 -> 49,1846,-819,3708;
    14:03:16.230 -> 50,1845,-821,3719;
    14:03:16.270 -> 51,1829,-820,3727;
    14:03:16.310 -> 52,1829,-820,3727;
    6 REPLIES 6
    Hi Moechl,
    The firmware determines the maximum ODR. The maximum ODR supported by the current firmware is 400 Hz.
    For Arduino code, if the current reference code does not have the functions you need, you can modify it on the basis of the reference code.
    Kjagan304
    Hi Moechl,
    If you can put BHY2.begin(NICLA_STANDALONE) you can increase the samples but it is not going beyond 1024. Also if we do the FFT with the samples, the sensor is able to work correctly till 200Hz sampling rate only not even till 400Hz. Please do check and confirm if possible.
