    BESC 2.0 not triggering measurements when trying to read gas estimates
    MightyNate
    I am Using BSEC version 2.0.6.1 with a BME688 sensor and AI Studio version 1.6.0 on a Raspberry Pi.
    My goal is to read the gas estimate predictions from an algorithm that I have trained in AI Stuio.
    My setup is working when I use a BSEC config from the conf directory in the BSEC package.
    But as soon as I use the config (algorithm) that I exported from AI Studio, BSEC does not trigger measurements any more.
    I already checked that the versions match.
    First I initialize the BME688 sensor via the BME68X API from GitHub and the I initialize the BSEC.
    Then I set the config (the algorithm that I have trained) from AI Studio via the bsec_set_configuration function.
    Next I subscribe all 19 BSEC outputs using BSEC_SAMPLE_RATE_HIGH_PERFORMANCE via bsec_update_subscription.
    So far all functions return BSEC_OK.
    Then I call bsec_sensor_control, which returns BSEC_OK as well but in the bsec_bme_settings_t the
    process_data and trigger_measurement fields are 0.
    op_mode is 2 (BME68X_PARALLEL_MODE), run_gas is 1  and the next_call, heater_temperature_profile and heater_duration_profile match the expactations.
    So my question is:
    What could be reasons for process_data and  trigger_measurement  to be 0?
    Thanks for your answers.
    Minhwan
    Hello MightyNate,
    Can you use my example config file?
    Please let me know whether it works or not.
