    BHI160+BMM150 sleep mode
    dex
    Hello every one,
    i'm using the BHI160 +BMM160 with fusion , i have succeeded having euler's data.
    my probleme is how can i put the sensor in sleep or deep sleep mode.
    it seem like the sleep mode is only trigger by the firmware i want to know when and how is the sleep mode trigger.
    thank you!
    shellywang
    Occasional Contributor
    Here are some informations about BMM150 sleep mode :
    The user puts device from suspend into Sleep mode by setting the Power bit to “1”, or from
    active modes (normal or forced) by setting OpMode bits to “11”. In this state the user has full
    access to the device registers. In particular, the Chip ID can be read. Setting the power control
    bit to “0” (register 0x4B bit0) will bring the device back into Suspend mode. From the Sleep
    mode the user can put the device back into Suspend mode or into Active mode.
