we are usign BHI160 and bhy sensor library.
I am trying to understand the configuration we are using on the physical and virtual sensor; hence I have patched in some routines to dump what i think is correct info. I find data sheets and documentation a little confusing about what these config numbers mean.
void start_bhy_accelerometer_sensor(int8_t sampling_rate_accelerometer)
BHY_RETURN_FUNCTION_TYPE result = BHY_ERROR;
u16 sr, mrl, cs, dr;
if( BHY_SUCCESS == bhy_get_wakeup_sensor_configuration( VS_TYPE_ACCELEROMETER, &sr, &mrl, &cs, &dr ) ){
NRF_LOG_INFO("IAC:SR:%d,MRL:%d,CS:%d, DR:%d", sr, mrl, cs, dr);
}else{
NRF_LOG_INFO("IAC:???");
bhy_enable_virtual_sensor(VS_TYPE_ACCELEROMETER, VS_WAKEUP, sampling_rate_accelerometer, 0, VS_FLUSH_NONE, 0, 0);
NRF_LOG_INFO("CAC:SR:%d,MRL:%d,CS:%d, DR:%d", sr, mrl, cs, dr);
}else{
NRF_LOG_INFO("CAC:???");
result = bhy_install_sensor_callback(VS_TYPE_ACCELEROMETER, VS_WAKEUP, sensors_callback_common);
APP_ERROR_CHECK(result);
<info> app: IAC:SR:12289,MRL:257,CS:16, DR:16
<info> app: CAC:SR:12289,MRL:257,CS:16, DR:16
So what do these numbers represent 12289 ( Rate in Hz; 12KHz? or what?)
Change sensitivity 16? What does this represent?
Dynamic Range 16; what does this represent 16g? Why does phys sensor say 4g (see later).?
<info> app: IGY:SR:12548,MRL:2049,CS:1000, DR:16
<info> app: CGY:SR:12548,MRL:2049,CS:1000, DR:16
Similar questions for gyro? What do figures represent?
<info> app: IMG:SR:2818,MRL:3845,CS:2000, DR:15
<info> app: CMG:SR:2818,MRL:3845,CS:2000, DR:15
<info> app:
Similar questions for magnetometer? What do figures represent?
void dumpPhysicalSensorStatus( void )
struct accel_physical_status_t as;
struct gyro_physical_status_t gs;
struct mag_physical_status_t ms;
if( BHY_SUCCESS == bhy_get_physical_sensor_status( &as, &gs, &ms )){
NRF_LOG_INFO("");
NRF_LOG_INFO("Accel Phys:SR:%d,DR:%d,Flag:%d", as.accel_sample_rate, as.accel_dynamic_range, as.accel_flag );
NRF_LOG_INFO("Gyro Phys:SR:%d,DR:%d,Flag:%d", gs.gyro_sample_rate, gs.gyro_dynamic_range, gs.gyro_flag );
NRF_LOG_INFO("Mag Phys:SR:%d,DR:%d,Flag:%d", ms.mag_sample_rate, ms.mag_dynamic_range, ms.mag_flag );
NRF_LOG_INFO("");
<info> app: Accel Phys:SR:100,DR:4,Flag:225
So sample rate 100Hz, dynamic range 4g; so what does this mean?
Wikipedia says dynamic range is ratio between smallest and largest value; surely this is not just 4.
I assume for a signed short this means -32,768 to 32,767 where low limit is -2g and high limit is 2g.
<info> app: Gyro Phys:SR:100,DR:2000,Flag:225
Again sample rate 100Hz, Dynamic range 2000; 2000 what (not g as sensor hub document says) and what does this represent.
Is this 2000 degrees/second?
<info> app: Mag Phys:SR:25,DR:2000,Flag:225
So sample rate 25Hz, Dynamic Range 2000; Again 2000 what?
Regards,
Owain
I will break your question into parts.
The thing to note here, is that BHI and BHA have 2 layers of software. the bhy.c and bhy.h files are a basic API that puts names on register values. The bhy_uc_driver* files are a simple driver that can be ported to any platform, including the smallest microcontrollers. the file bhy_uc_driver.h should contain all the functions that are required for the vast majority of use-cases.
The function bhy_get_wakeup_sensor_configuration is part of the API for does not use the same enums as the driver, therefore the argument VS_TYPE_ACCELEROMETER is invalid. See code excerpt from bhy.h :
/*! * @brief API used to get the sensor wakeup configuration * Sensor page-3 parameter 65 to 89 * * @param v_sample_rate_u16 : contains the wakeup sample rate data * @param v_max_report_latency_u16: contains the wakeup max report latency * @param v_change_sensitivity_u16: contains the wakeup sensitivity * @param v_dynamic_range_u16: contains the wakeup dynamic range * * @param v_parameter_request_u8: value of selected parameter request * param_request | value | Virtual sensor * -----------------------------------|-------|---------------- * BHY_PARAMETER_REQUEST_READ_PARAMETER_97 | 0xE1 | Accelerometer * BHY_PARAMETER_REQUEST_READ_PARAMETER_98 | 0xE2 | Magnetometer * BHY_PARAMETER_REQUEST_READ_PARAMETER_99 | 0xE3 | Orientation * BHY_PARAMETER_REQUEST_READ_PARAMETER_100 | 0xE4 | Gyroscope * BHY_PARAMETER_REQUEST_READ_PARAMETER_101 | 0xE5 | Light * BHY_PARAMETER_REQUEST_READ_PARAMETER_102 | 0xE6 | Barometer * BHY_PARAMETER_REQUEST_READ_PARAMETER_103 | 0xE7 | Temperature * BHY_PARAMETER_REQUEST_READ_PARAMETER_104 | 0xE8 | Proximity * BHY_PARAMETER_REQUEST_READ_PARAMETER_105 | 0xE9 | Gravity * BHY_PARAMETER_REQUEST_READ_PARAMETER_106 | 0xEA | Liner accel * BHY_PARAMETER_REQUEST_READ_PARAMETER_107 | 0xEB | Rotation vector * BHY_PARAMETER_REQUEST_READ_PARAMETER_108 | 0xEC | Humidity * BHY_PARAMETER_REQUEST_READ_PARAMETER_109 | 0xED | Ambient Temperature * BHY_PARAMETER_REQUEST_READ_PARAMETER_110 | 0xEE | Uncalibrated Mag * BHY_PARAMETER_REQUEST_READ_PARAMETER_111 | 0xEF | Game rotation Vector * BHY_PARAMETER_REQUEST_READ_PARAMETER_112 | 0xF0 | Uncalibrated Gyro * BHY_PARAMETER_REQUEST_READ_PARAMETER_113 | 0xF1 | Signification Motion * BHY_PARAMETER_REQUEST_READ_PARAMETER_114 | 0xF2 | Step detector * BHY_PARAMETER_REQUEST_READ_PARAMETER_115 | 0xF3 | Step Counter * BHY_PARAMETER_REQUEST_READ_PARAMETER_116 | 0xF4 | Geomagnetic * BHY_PARAMETER_REQUEST_READ_PARAMETER_117 | 0xF5 | Heart Rate * BHY_PARAMETER_REQUEST_READ_PARAMETER_118 | 0xF6 | Tilt Detector * BHY_PARAMETER_REQUEST_READ_PARAMETER_119 | 0xF7 | Wakeup Gesture * BHY_PARAMETER_REQUEST_READ_PARAMETER_120 | 0xF8 | Glance Gesture * BHY_PARAMETER_REQUEST_READ_PARAMETER_121 | 0xF9 | Pickup Gesture * BHY_PARAMETER_REQUEST_READ_PARAMETER_127 | 0xFF | Activity * * * @return results of bus communication function * @retval 0 -> Success * @retval -1 -> Error * * * */ BHY_RETURN_FUNCTION_TYPE bhy_get_wakeup_sensor_configuration( u8 v_parameter_request_u8, u16 *v_sample_rate_u16, u16 *v_max_report_latency_u16, u16 *v_change_sensitivity_u16, u16 *v_dynamic_range_u16);
I believe that you are confusing range and resolution. In the case of the acceleromter, it has possible ranges of +-2G, +-4G, +-8G or +-16. Since the range can vary it is dynamic.
Resolution on the other hand is fixed, always 16 bits. There are a total of 65536 values that are mapped to the entire range (positive and negative). For the default +-4G range, that means 65536/8 = 8196 LSB/g
@owain-incus wrote:Again sample rate 100Hz, Dynamic range 2000; 2000 what (not g as sensor hub document says) and what does this represent.
Thank you for finding this typo. Indeed the data for the gyroscope is in degrees/second. For the magnetometer, it is in uT.
I highly recommend that you start your development with one of our examples. The BHI160 is a sensor Hub, and unlike dumb sensors, there is a communication protocol for the data readout that must be followed.
I still don't have this working. Don't know if this is due to me not using API's correctly; or incorrect documentation.
Some basic misunderstandings here.
Here configuration routine; together with debug prints.
struct sensor_configuration_wakeup_t sensorConf;
sensorConf.wakeup_sample_rate = 0;
sensorConf.wakeup_max_report_latency = 0;
sensorConf.wakeup_change_sensitivity = 0;
sensorConf.wakeup_dynamic_range = 16;
if( BHY_SUCCESS == bhy_set_wakeup_sensor_configuration( &sensorConf, 0x0e1 ) ){
NRF_LOG_INFO( "Accel changed range OK" );
}else{
NRF_LOG_INFO( "Accel changed range FAIL" );
if( BHY_SUCCESS == bhy_get_wakeup_sensor_configuration( 0x0e1, &sr, &mrl, &cs, &dr ) ){
}else{
}else{
bhi160 initialize success!
<info> app: Accel changed range OK
<info> app: IAC:SR:0,MRL:0,CS:0, DR:0
<info> app: CAC:SR:0,MRL:0,CS:0, DR:0
<info> app: IGY:SR:0,MRL:0,CS:0, DR:0
<info> app: CGY:SR:0,MRL:0,CS:0, DR:0
<info> app: IMG:SR:0,MRL:0,CS:0, DR:0
<info> app: CMG:SR:0,MRL:0,CS:0, DR:0
<info> app:
<info> app:
Could you please advise?
Playing around I now have something that works; but still unclear on the bhy_get_wakeup_sensor_configuration() as this still appear to return 0's.
<info> app: Gyro changed range OK
<info> app:
<info> app: Accel Phys:SR:100,DR:16,Flag:225
<info> app:
<info> app: >Meta event type 16,
So DR for physical sensor is changed for the accel and gyro.
But why do the bhy_get_wakeup_sensor_configuration() not reflect the changes made?
