    BHI160B : bhy_get_physical_sensor_status(&accel_status, &gyro_status, &mag_status)
    Eyalb
    I use BHI160B.
    I call bhy_get_physical_sensor_status(&accel_status, &gyro_status, &mag_status) and get all parameters zero value.
    other than that I have gyro example working, but I want to know which dynamic range value is set after I called :
    bhy_enable_virtual_sensor(VS_TYPE_GYROSCOPE, VS_WAKEUP, sample_range, 0, VS_FLUSH_NONE, 0, dynamic_range);
    this because I want my computation to be right : float_tmp = pi_const * (sensor_data->data_vector.x) * dynamic_range / 32768 / 180 ;
    thanks.
    eyal.
    4 REPLIES 4
    Re: BHI160B : bhy_get_physical_sensor_status(&accel_status, &gyro_status, &mag_status)
    Hello Eyalb,
    Before you call sensor API, have you finished sensor initialization?
    By the way, which example code you used?
    https://github.com/BoschSensortec/BHy1_driver_and_MCU_solution/tree/master/examples
    Eyalb
    hello.
    Yes. I finished sensor init  and then called func to get parameters.
    I use this code :
    bhy_driver_init(&bhy_fw);
    semTake(imuSem,WAIT_FOREVER);
    if(bhy_install_sensor_callback(VS_TYPE_GYROSCOPE, VS_WAKEUP, sensors_callback))
    DEBUG("Fail to install VS_TYPE_GYROSCOPE callback\n");
    return;
    /* enables the virtual sensors : */
    if (bhy_enable_virtual_sensor(VS_TYPE_GYROSCOPE, VS_WAKEUP, sample_range, 0, VS_FLUSH_NONE, 0, 0/*dynamic_range*/))
    DEBUG("==========================Fail to enable sensor id=%d==================================\n", VS_TYPE_GYROSCOPE);
    return;
    if (!( bhy_get_physical_sensor_status(&accel_status, &gyro_status, &mag_status)))
    dynamic_range = gyro_status.gyro_dynamic_range;
    DEBUG("read dynamic_range. value is : %d \n",dynamic_range);
    else
    DEBUG("error read dynamic_range. \n");
    while(1) {
    /*while (!ioport_get_pin_level(BHY_INT) && !bytes_remaining);*/
    bhy_read_fifo(fifo + bytes_left_in_fifo, FIFO_SIZE - bytes_left_in_fifo, &bytes_read, &bytes_remaining);
    thanks.
    Hello Eyalb,
    There was a example in github to read sensor status, could you test it on your platform?
    https://github.com/BoschSensortec/BHy1_driver_and_MCU_solution/blob/master/examples/custom_sensor_ex...
    Eyalb
    I'll test it ASAP. thanks.
