    BHI160B initialization issue BHY_META_EVENT_TYPE_ERROR()
    robinpipers
    So I am trying to get my bhi160b to work and stream accelerometer data connected to a stm32f7 via i2c.
    Here I have used some of the example code:
    Together with the following firmware: Bosch_PCB_7183_di03_BMI160-7183_di03.2.1.11696_170103.h
    void demo_sensor(void)
        int8_t ret;
        /* BHY Variable*/
        uint8_t                    *fifoptr           = NULL;
        uint8_t                    bytes_left_in_fifo = 0;
        uint16_t                   bytes_remaining    = 0;
        uint16_t                   bytes_read         = 0;
        bhy_data_generic_t         fifo_packet;
        bhy_data_type_t            packet_type;
        BHY_RETURN_FUNCTION_TYPE   result;
        /* To get the customized version number in firmware, it is necessary to read Parameter Page 2, index 125 */
        /* to get this information. This feature is only supported for customized firmware. To get this customized */
        /* firmware, you need to contact your local FAE of Bosch Sensortec. */
        //struct cus_version_t      bhy_cus_version;
        BHY_RETURN_FUNCTION_TYPE com_rslt = BHY_COMM_RES;
        uint8_t data[1] = {1};
        com_rslt = bhy_write_reg(BHY_I2C_REG_RESET_REQUEST_ADDR, data, sizeof(data));
        while (!bhi160b_get_int_status());
        osDelay(5000);
        // bhy_install_meta_event_callback(BHY_META_EVENT_TYPE_ERROR, meta_event_callback);
        // bhy_install_meta_event_callback(BHY_META_EVENT_TYPE_SENSOR_ERROR, meta_event_callback);
        bhy_install_meta_event_callback(BHY_META_EVENT_TYPE_INITIALIZED, meta_event_callback);
        bhy_install_meta_event_callback(BHY_META_EVENT_TYPE_SELF_TEST_RESULTS, meta_event_callback);
        bhy_install_sensor_callback(VS_ID_CUS1, VS_WAKEUP, sensors_callback);
        // PDEBUG("version=%s, %s, %s\n", bhy_get_version(), __DATE__, __TIME__);
        // PDEBUG("start example\n");
        /* init the bhy chip */
        if(bhy_driver_init(bhy1_fw))
            PDEBUG("Fail to init bhy\n");
        /* wait for the bhy trigger the interrupt pin go down and up again */
        while(bhi160b_get_int_status());
        while(!bhi160b_get_int_status());
        //bhy_read_parameter_page(BHY_PAGE_2, PAGE2_CUS_FIRMWARE_VERSION, (uint8_t*)&bhy_cus_version, sizeof(struct cus_version_t));
        //PDEBUG("cus version base:%d major:%d minor:%d\n", bhy_cus_version.base, bhy_cus_version.major, bhy_cus_version.minor);
        struct accel_physical_status_t phy_acc;
        struct gyro_physical_status_t phy_gyro;
        struct mag_physical_status_t phy_mag;
        uint8_t physical_sensor_present_bitmap[8];
        uint32_t                   i                  = 0;
        struct sensor_information_non_wakeup_t sensor_info_non_wakeup;
        struct sensor_information_wakeup_t sensor_info_wakeup;
        /* get physical sensor present from sensor hub */
        bhy_read_parameter_page(BHY_PAGE_1, BHY_PARAM_SYSTEM_PHYSICAL_SENSOR_PRESENT, &physical_sensor_present_bitmap[0], 8);
        PDEBUG("Physical Sensor Present:\n");
        for(i = 0; i < 8; i++)
          PDEBUG("bitmap[%d] = 0x%x\n", i, physical_sensor_present_bitmap[i]);
          PDEBUG("");
        /* get physical sensor status from sensor hub */
        bhy_get_physical_sensor_status(&phy_acc, &phy_gyro, &phy_mag);
          /*	Physical Sensor Status:
        Flags[bit 0]:  interrupt enable
        Flags[bits 5-7]: Sensor Power Mode values:
        0: Sensor Not Present
        1: Power Down
        2: Suspend
        3: Self-Test
        4: Interrupt Motion
        5: One Shot
        6: Low Power Active
        7: Active
        PDEBUG("Physical Sensor Status:\n");
        PDEBUG("Acc : sample rate %d, range %d, int %d pwr %d\n",\
        phy_acc.accel_sample_rate, phy_acc.accel_dynamic_range, phy_acc.accel_flag & 0x01, (phy_acc.accel_flag & 0xE0) >> 5);
        PDEBUG("Gyro: sample rate %d, range %d, int %d pwr %d\n", \
        phy_gyro.gyro_sample_rate, phy_gyro.gyro_dynamic_range, phy_gyro.gyro_flag & 0x01, (phy_gyro.gyro_flag & 0xE0) >> 5);
        PDEBUG("Mag : sample rate %d, range %d, int %d pwr %d\n", \
        phy_mag.mag_sample_rate, phy_mag.mag_dynamic_range, phy_mag.mag_flag & 0x01, (phy_mag.mag_flag & 0xE0) >> 5);
        PDEBUG("");
        /* read custom sensor event size from hub for later fifo parse */
        bhy_sync_cus_evt_size();
        PDEBUG("cus evt size = %d %d %d %d %d\n", bhy_get_cus_evt_size(VS_ID_CUS1), bhy_get_cus_evt_size(VS_ID_CUS2), \
        bhy_get_cus_evt_size(VS_ID_CUS3), bhy_get_cus_evt_size(VS_ID_CUS4), \
        bhy_get_cus_evt_size(VS_ID_CUS5));
        /* get virtual sensor information from sensor hub */
        PDEBUG("Supported Virtual Sensor Information:\n");
        for(i = 1; i < 32; i++)
          bhy_get_wakeup_sensor_information(i, &sensor_info_wakeup);
          if(sensor_info_wakeup.wakeup_sensor_type == i)
          PDEBUG("id=%2d\n", i);
        for(i = 33; i < 64; i++)
          bhy_get_non_wakeup_sensor_information(i, &sensor_info_non_wakeup);
          if(sensor_info_non_wakeup.non_wakeup_sensor_type == i)
        PDEBUG("");
        bool shouldSelftest = false;
        if (shouldSelftest) {
          bhy_set_chip_control(0);
          bhy_set_host_interface_control(BHY_HOST_SELFTEST, ENABLE);
          osDelay(100);
          bhy_set_chip_control(1);
          osDelay(100);
        } else {
          bhy_enable_virtual_sensor(VS_ID_CUS1, VS_WAKEUP, 5, 0, VS_FLUSH_NONE, 0, 0);
        while(1)
            osDelay(1);
            /* wait until the interrupt fires */
            /* unless we already know there are bytes remaining in the fifo */
            while (!bhi160b_get_int_status() && !bytes_remaining);
            bhy_read_fifo(fifo + bytes_left_in_fifo, FIFO_SIZE - bytes_left_in_fifo, &bytes_read, &bytes_remaining);
            bytes_read           += bytes_left_in_fifo;
            fifoptr              = fifo;
            packet_type          = BHY_DATA_TYPE_PADDING;
            do
                /* this function will call callbacks that are registered */
                result = bhy_parse_next_fifo_packet(&fifoptr, &bytes_read, &fifo_packet, &packet_type);
                /* prints all the debug packets */
                if (packet_type == BHY_DATA_TYPE_PADDING)
                  /* padding data only added at the end of each FIFO dump, discard it. */
                  PDEBUG(">Padding\n");
                else if (packet_type == BHY_DATA_TYPE_DEBUG)
                  PDEBUG(">DebugString       :");
                  bhy_print_debug_packet(&fifo_packet.data_debug, bhy_printf);
                  PDEBUG("\n");
                /* the logic here is that if doing a partial parsing of the fifo, then we should not parse  */
                /* the last 18 bytes (max length of a packet) so that we don't try to parse an incomplete   */
                /* packet */
            } while ((result == BHY_SUCCESS) && (bytes_read > (bytes_remaining ? MAX_PACKET_LENGTH : 0)));
            if (bytes_remaining)
                /* shifts the remaining bytes to the beginning of the buffer */
                while (bytes_left_in_fifo < bytes_read)
                    fifo[bytes_left_in_fifo++] = *(fifoptr++);
    Callback:
    static void meta_event_callback(bhy_data_meta_event_t *event_data, bhy_meta_event_type_t event_type)
        PDEBUG(">Meta event type %d,  \n", event_type);
        switch(event_type)
            case BHY_META_EVENT_TYPE_INITIALIZED:
                PDEBUG("initialize success!\n");
                break;
            case BHY_META_EVENT_TYPE_SELF_TEST_RESULTS:
                if(event_data->event_specific == BHY_SUCCESS)
                    PDEBUG("self test result success!  sensor_type=%d \n", event_data->sensor_type);
                else
                    PDEBUG("self test result fail!  sensor_type=%d  \n", event_data->sensor_type);
                break;
            case BHY_META_EVENT_TYPE_ERROR:
              PDEBUG("error meta event\n");
            break;
            default:
                PDEBUG("unknown meta event\n");
                break;
    However this causes BHY_META_EVENT_TYPE_ERROR once entering the meta_callback after first time processing fifo.
    There are no more events following that event. neither sensor or meta callback.
    And the code snippet bellow shows that the flags for phy_acc is 0x20. which means suspended mode, is there any way to take it out of suspended?
    Attached my hw schematics.
    Tags (1)
    10 REPLIES 10
    Re: BHI160B initialization issue BHY_META_EVENT_TYPE_ERROR()
    Hi robinpipers,
    Run the same code, I got the following result, haven't found 0x20 acc flag.
    What is the full running result of your program?
    robinpipers
    Wait... I get the same as you.
    I have only debuged it previously and missed the mask when reading flags. If logging I get the same result.
    If I also uncomment the lines for meta callback etc. I get the following.
    Then after running for 5s the error callback is triggered.
    Then my next question is how do i get to set sample rate and actually get the accelerometer to produce samples.
    Hi robinpipers,
    You could refer the following code to read acc data with 100 Hz.
    static void sensors_callback_acc(bhy_data_generic_t * sensor_data, bhy_virtual_sensor_t sensor_id)
    switch(sensor_id)
    case VS_ID_ACCELEROMETER:
    case VS_ID_ACCELEROMETER_WAKEUP:
    PDEBUG("acc,%d,%d,%d\r\n", sensor_data->data_vector.x, sensor_data->data_vector.y, sensor_data->data_vector.z);
    break;
    default:
    PDEBUG("unknown id = %d\r\n", sensor_id);
    break;
    /* install the callback function for parse fifo data */
    if(bhy_install_sensor_callback(VS_TYPE_ACCELEROMETER, VS_WAKEUP, sensors_callback_acc))
    PDEBUG("Fail to install sensor callback\r\n");
    /* enables the virtual sensor */
    if(bhy_enable_virtual_sensor(VS_TYPE_ACCELEROMETER, VS_WAKEUP, 100, 0, VS_FLUSH_NONE, 0, 0))
    PDEBUG("Fail to enable sensor id=%d\n", VS_TYPE_ACCELEROMETER);
    robinpipers
    Thanks BSTRobin
    I tried the following, but with no success.
    No rtt prints.
    	uint16_t i = 0;
    	switch(sensor_id)
        break;
    		default:
    			PDEBUG("unknown id = %d\n", sensor_id);
    		break;
        int8_t ret;
        /* BHY Variable*/
        // BHY_RETURN_FUNCTION_TYPE com_rslt = BHY_COMM_RES;
        // uint8_t data[1] = {1};
        // com_rslt = bhy_write_reg(BHY_I2C_REG_RESET_REQUEST_ADDR, data, sizeof(data));
        // while (!bhi160b_get_int_status());
        // osDelay(100);
        if(bhy_install_sensor_callback(VS_TYPE_ACCELEROMETER, VS_WAKEUP, sensors_callback_acc)) {
        if(bhy_enable_virtual_sensor(VS_TYPE_ACCELEROMETER, VS_WAKEUP, 100, 0, VS_FLUSH_NONE, 0, 0)) {
        while(1)
            osDelay(1);
            fifoptr              = fifo;
            do
                  PDEBUG("\n");
                /* packet */
