    BHI260 + BMM150 magnetometer measurement confuse
    BadLagger
    I am using BHI260 + BMM150 combination for get IMU data and using firmware Bosch_SHUTTLE_BHI260_BMM150.fw.h for this. Accelerometer and gyroscope data are fine. But I cann't find good coeficient for getting magnetometer data in uT. I am using Sensor Id = 19 (Magnetometer passthrough).Through experements with numbers I determinated that if i multiply all data from magnetometer to 0.0625 (=1/16) than I get values look like true. That is right? Should I multiply all data from magnetometer to 0.0625 for getting data in uT?
    And the second moment. BHI260 has few different Sensor Id's: 19 - Magnetometer passthrough, 21 - Magnetometer uncalibrated, 22 - Magnetometer corrected. I tried all of them but the data stay the same. What the really difference between this Sensor Id's?
    Hello BadLagger,
    Could we know your HW schematic and which driver code you used?
    Hello, BSTRobin
    I am using:
    Hardware
    - Bosch Sensortec’s BHI260AB shuttle board from one side;
    - custom board based on SoC TI OMAP DM3730 from other side;
    - connection type between boards is I2C;
    - on OMAP 3 I am using custom Linux with driver based on https://github.com/BoschSensortec/BHY2-Sensor-API (API was fully integrated in driver without changes)
    - firmware that we are loading on Bosch Sensortec’s BHI260AB shuttle board:   https://github.com/BoschSensortec/BHY2-Sensor-API/tree/master/firmware/bhi260/Bosch_SHUTTLE_BHI260_B...
    Application logic:
    Application (from userspace) opens device file, reads and parse data. After that all MEMS data performs as following:
    - Accelerometer x,y,z divide by 8192 for getting data in G (in driver set range 4);
    - Gyroscope x,y,z divide by 65.6 for getting data in degrees(in driver set range 500);
    - Magnitometer: x,y,z divide (or multiply) by ???? (<-that's all I want to know!!!) for getting data in uT (the range for magnetometer fixed and does not set in driver);
    I am suggesting that I should divide magnetometer x,y,z by 16 (or multiply by 0.0625) for getting data in uT. That is correct suggesting?
    Hello BadLagger,
    BHI260AB shuttle board used BMM150 magnitometer sensor, you could see BMM150 magnitometer sensor range from data sheet.
    When you used BHY2-Sensor-API, could we know your SW code to check it?
