I am following bst-bhi260ab-an000-SDK-quickstart-guide.pdf to install the ARC GNU Eclipse IDE/toolchain and the Bosch supplied BHI260 SDK.
I have successfully installed the ARC GNU tools and the BHI260 SDK and have successfully imported the SDK and made the property changes indicated in the guide .
However, when I try to build the BHI260 SDK it hangs at 29% when trying to build the C object VirtSignificantMotion driver.
I have retried several times with the same result including with virus protection disabled.
I am using 64 bit Windows 10, version 2004, build 19041.572
The complete build output produced is:
11:50:48 **** Incremental Build of configuration Default for project BHI260_SDK ****
build.bat
SDK Version 5978
Using cmake binary: C:\Projects\BHI260_SDK_Install\Documents\BHI260_SDK\win64\cmake\bin\cmake.exe
Using cpack binary: C:\Projects\BHI260_SDK_Install\Documents\BHI260_SDK\win64\cmake\bin\cpack.exe
Using ninja binary: C:\Projects\BHI260_SDK_Install\Documents\BHI260_SDK\win64\bin\ninja.exe
Running cmake generator
-- The C compiler identification is GNU 10.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/arc_gnu/bin/arc-elf32-gcc.exe
-- RAM Type: KERNEL_RAM
-- User RAM Type: USER_RAM
-- Flash Type: KERNEL_FLASH
-- User Flash Type: USER_FLASH
-- Flash Bootloader Type: BOOTLOADER_FLASH
-- Boards require driver: AK09915Mag
-- Boards require driver: TMG4903Light
-- Boards require driver: TMG4903Proximity
-- Boards require driver: ORG1510
-- Boards require driver: ExCamera
-- Boards require driver: VirtStepCounter
-- Boards require driver: VirtWakeupStepCounter
-- Boards require driver: VirtStepDetector
-- Boards require driver: VirtWakeupStepDetector
-- Boards require driver: VirtAnyMotion
-- Boards require driver: VirtSignificantMotion
-- Boards require driver: VirtAccelPassthrough
-- Boards require driver: VirtWakeupAccel
-- Boards require driver: VirtMagPassthrough
-- Boards require driver: VirtGyroPassthrough
-- Boards require driver: VirtGPS
-- Boards require driver: VirtExCamera
-- Boards require driver: VirtBSXAccelPassthrough
-- Boards require driver: VirtBSXWakeupAccel
-- Boards require driver: VirtBSXAccelOffset
-- Boards require driver: VirtBSXAccelUncal
-- Boards require driver: VirtBSXWakeupAccelUncal
-- Boards require driver: VirtBSXLinearAccel
-- Boards require driver: VirtBSXWakeupLinearAccel
-- Boards require driver: VirtBSXGravity
-- Boards require driver: VirtBSXWakeupGravity
-- Boards require driver: VirtBSXGyroPassthrough
-- Boards require driver: VirtBSXWakeupGyro
-- Boards require driver: VirtBSXGyroOffset
-- Boards require driver: VirtBSXGyroUncal
-- Boards require driver: VirtBSXWakeupGyroUncal
-- Boards require driver: VirtBSXMagPassthrough
-- Boards require driver: VirtBSXWakeupMag
-- Boards require driver: VirtBSXMagOffset
-- Boards require driver: VirtBSXMagUncal
-- Boards require driver: VirtBSXWakeupMagUncal
-- Boards require driver: VirtBSXRotation
-- Boards require driver: VirtBSXWakeupRotation
-- Boards require driver: VirtBSXGameRotation
-- Boards require driver: VirtBSXWakeupGameRotation
-- Boards require driver: VirtBSXGeoRotation
-- Boards require driver: VirtBSXWakeupGeoRotation
-- Boards require driver: VirtBSXStepDetect
-- Boards require driver: VirtBSXWakeupStepDetect
-- Boards require driver: VirtBSXStepCounter
-- Boards require driver: VirtBSXWakeupStepCounter
-- Boards require driver: VirtBSXWakeupGesture
-- Boards require driver: VirtBSXPickupGesture
-- Boards require driver: VirtBSXGlanceGesture
-- Boards require driver: VirtBSXTiltDetector
-- Boards require driver: VirtBSXSigMotion
-- Boards require driver: VirtBSXActivity
-- Boards require driver: VirtBSXOrientation
-- Boards require driver: VirtBSXWakeupOrientation
-- Boards require driver: VirtBSXDeviceOrientation
-- Boards require driver: VirtBSXWakeupDeviceOrientation
-- Boards require driver: VirtBSXWakeupMotionDetect
-- Boards require driver: VirtBSXWakeupStationaryDetect
-- Boards require driver: VirtBSXWakeupWristTiltGesture
-- Boards require driver: VirtHumidity
-- Boards require driver: VirtPressure
-- Boards require driver: VirtTemperature
-- Boards require driver: VirtWakeupHumidity
-- Boards require driver: VirtWakeupPressure
-- Boards require driver: VirtWakeupTemperature
-- Boards require driver: VirtLight
-- Boards require driver: VirtProximity
-- Boards require driver: VirtWakeupLight
CMake Warning at cmake/clang-format.cmake:120 (MESSAGE):
-- Boards require driver: VirtWakeupProximity
Clang-format not found.
-- Boards require driver: AccelInject
Call Stack (most recent call first):
-- Boards require driver: BHI260SigMotion
CMakeLists.txt.common:56 (include)
-- Boards require driver: BHI260StepCounter
CMakeLists.txt:52 (include)
-- Boards require driver: BHI260StepDetector
-- Boards require driver: BHI260Accel
-- Boards require driver: BHI260AnyMotion
-- Boards require driver: BHI260Gyro
-- Boards require driver: AK09915Mag_aux
-- Boards require driver: BMM150Mag
-- Boards require driver: BME280Temperature
-- Boards require driver: BME280Pressure
-- Boards require driver: BME280Humidity
-- Boards require driver: VirtHangDetection
-- Using prebuilt Windows host tools C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/win64/bin
-- Add imported library MetawarePrintf at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/MetawarePrintf
-- Add imported library MetawareDouble at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/MetawareDouble
-- Add imported library Bootloader at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/Bootloader
-- Add imported library Time at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/Time
-- Add imported library SensorInterface at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/SensorInterface
-- Add imported library HostInterfaceStreaming at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/HostInterfaceStreaming
-- Add imported library I2CInterface at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/I2CInterface
-- Add imported library SPIInterface at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/SPIInterface
-- Add imported library OuterloopROM at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/OuterloopROM
-- Add imported library Config at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/Config
-- Add imported library FlashInterface at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/FlashInterface
-- Add imported library openrtos at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/openrtos
-- Add imported library Ram at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/Ram
-- Add imported library OscTrim at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/OscTrim
-- Add imported library SensorCalibration at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/SensorCalibration
-- Add imported library Hooks at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/Hooks
-- Add imported library BSXSupport at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSXSupport
-- Add imported library Outerloop at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/Outerloop
-- Building driver AK09915Mag
-- Building driver TMG4903Light
-- Building driver TMG4903Proximity
-- Building driver ORG1510
-- Building driver ExCamera
-- Building driver VirtStepCounter
-- Building driver VirtWakeupStepCounter
-- Building driver VirtStepDetector
-- Building driver VirtWakeupStepDetector
-- Building driver VirtAnyMotion
-- Building driver VirtSignificantMotion
-- Building driver VirtAccelPassthrough
-- Building driver VirtWakeupAccel
-- Building driver VirtMagPassthrough
-- Building driver VirtGyroPassthrough
-- Building driver VirtGPS
-- Building driver VirtExCamera
-- Building driver VirtBSXAccelPassthrough
-- Building driver VirtBSXWakeupAccel
-- Building driver VirtBSXAccelOffset
-- Building driver VirtBSXAccelUncal
-- Building driver VirtBSXWakeupAccelUncal
-- Building driver VirtBSXLinearAccel
-- Building driver VirtBSXWakeupLinearAccel
-- Building driver VirtBSXGravity
-- Building driver VirtBSXWakeupGravity
-- Building driver VirtBSXGyroPassthrough
-- Building driver VirtBSXWakeupGyro
-- Building driver VirtBSXGyroOffset
-- Building driver VirtBSXGyroUncal
-- Building driver VirtBSXWakeupGyroUncal
-- Building driver VirtBSXMagPassthrough
-- Building driver VirtBSXWakeupMag
-- Building driver VirtBSXMagOffset
-- Building driver VirtBSXMagUncal
-- Building driver VirtBSXWakeupMagUncal
-- Building driver VirtBSXRotation
-- Building driver VirtBSXWakeupRotation
-- Building driver VirtBSXGameRotation
-- Building driver VirtBSXWakeupGameRotation
-- Building driver VirtBSXGeoRotation
-- Building driver VirtBSXWakeupGeoRotation
-- Building driver VirtBSXStepDetect
-- Building driver VirtBSXWakeupStepDetect
-- Building driver VirtBSXStepCounter
-- Building driver VirtBSXWakeupStepCounter
-- Building driver VirtBSXWakeupGesture
-- Building driver VirtBSXPickupGesture
-- Building driver VirtBSXGlanceGesture
-- Building driver VirtBSXTiltDetector
-- Building driver VirtBSXSigMotion
-- Building driver VirtBSXActivity
-- Building driver VirtBSXOrientation
-- Building driver VirtBSXWakeupOrientation
-- Building driver VirtBSXDeviceOrientation
-- Building driver VirtBSXWakeupDeviceOrientation
-- Building driver VirtBSXWakeupMotionDetect
-- Building driver VirtBSXWakeupStationaryDetect
-- Building driver VirtBSXWakeupWristTiltGesture
-- Building driver VirtHumidity
-- Building driver VirtPressure
-- Building driver VirtTemperature
-- Building driver VirtWakeupHumidity
-- Building driver VirtWakeupPressure
-- Building driver VirtWakeupTemperature
-- Building driver VirtLight
-- Building driver VirtProximity
-- Building driver VirtWakeupLight
-- Building driver VirtWakeupProximity
-- Building driver AccelInject
-- Add imported library BHI260SigMotion at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BHI260SigMotion
-- Add imported library BHI260StepCounter at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BHI260StepCounter
-- Add imported library BHI260StepDetector at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BHI260StepDetector
-- Add imported library BHI260Accel at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BHI260Accel
-- Add imported library BHI260AnyMotion at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BHI260AnyMotion
-- Add imported library BHI260Gyro at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BHI260Gyro
-- Add imported library AK09915Mag_aux at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/AK09915Mag_aux
-- Add imported library BMM150Mag at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BMM150Mag
-- Add imported library BME280Temperature at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BME280Temperature
-- Add imported library BME280Pressure at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BME280Pressure
-- Add imported library BME280Humidity at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/BME280Humidity
-- Add imported library VirtBSX at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/VirtBSX
-- Add imported library VirtHangDetection at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/drivers/VirtHangDetection
-- Add imported library libkernel-flash at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/kernel
-- Add imported library libkernel at C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/kernel
-- Linking board images against bosch_rom/bosch_rom.elf
-- Reading in configuration list from libs/BSX/SolutionList/csvList_SENSORHUB_BHY2_AG_1.txt
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_INPUT_ACC_GYRO_DYN_SAMPLE_RATE_BHY_OUTPUT_SENSORHUB_AG.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_timeScaling_ENGPHONE_NEXUS5X_FPGABOARD.csv
-- Board Bosch_SHUTTLE_BHI260 (hash: fb5ff5c38b2ac67549634b88dffcc9b6)
-- Board Bosch_SHUTTLE_BHI260_turbo (hash: fb5ff5c38b2ac67549634b88dffcc9b6)
-- Reading in configuration list from libs/BSX/SolutionList/csvList_SENSORHUB_BHY2_AMG_6.txt
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_INPUT_MAG_ACC_GYRO_DYN_SAMPLE_RATE_BHY_OUTPUT_SENSORHUB_AMG.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_timeScaling_SHUTTLE_BHI260.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_magnetometer_AK09915.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_SIC_AK09915_SHUTTLE_BHI260.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_magCorr_FILTER1_ENABLE.csv
-- Board Bosch_SHUTTLE_BHI260_AK09915 (hash: 97df84ec8122a0de8d6cf3413a289112)
-- Reading in configuration list from libs/BSX/SolutionList/csvList_SENSORHUB_BHY2_AMG_5.txt
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_INPUT_MAG_BMM_ACC_GYRO_DYN_SAMPLE_RATE_BHY_OUTPUT_SENSORHUB_AMG.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_magnetometer_BMM150.csv
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_SIC_BMM150_SHUTTLE_BHI260.csv
-- Board Bosch_SHUTTLE_BHI260_BMM150 (hash: d66927bc6b7229a80953ef99e811472a)
-- Board Bosch_SHUTTLE_BHI260_AK09915_BME280 (hash: a9d622d876c13cb67a65e15c2cf77d14)
-- Board Bosch_SHUTTLE_BHI260_BME280 (hash: b493b6d7e3aa1f3db1c2d38f9a7e6e59)
-- Reading in configuration list from libs/BSX/SolutionList/csvList_SENSORHUB_BHY2_A_1.txt
-- Reading in configuration file from C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/libs/BSX/SolutionList/../spec/bsx4configSerialization_SENSORHUB_INPUT_ACC_DYN_SAMPLE_RATE_BHY_OUTPUT_SENSORHUB_A.csv
-- Board DataInject (hash: 08fc008fd4e19e310c99a3bd232846a4)
-- Board DataInject_nobsx (hash: 86bdf125440f2c720d9795b58dc7306f)
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Projects/BHI260_SDK_Install/Documents/BHI260_SDK/build
Running build
[1/216] Building C object drivers/VirtStepCounter/CMakeFiles/VirtStepCounter.dir/VirtStepCounter.c.obj
[2/216] Building C object drivers/VirtStepDetector/CMakeFiles/VirtStepDetector.dir/VirtStepDetector.c.obj
[3/216] Building C object drivers/VirtWakeupStepCounter/CMakeFiles/VirtWakeupStepCounter.dir/VirtWakeupStepCounter.c.obj
[4/216] Building C object drivers/VirtWakeupStepDetector/CMakeFiles/VirtWakeupStepDetector.dir/VirtWakeupStepDetector.c.obj
[5/216] Building C object drivers/TMG4903Proximity/CMakeFiles/TMG4903Proximity.dir/TMG4903ProximitySensor.c.obj
[6/216] Building C object drivers/ExCamera/CMakeFiles/ExCamera.dir/ex_camera.c.obj
[7/216] Building C object drivers/ORG1510/CMakeFiles/ORG1510.dir/ORG1510.c.obj
[8/216] Building C object drivers/AK09915Mag/CMakeFiles/AK09915Mag.dir/AK09915MagSensor.c.obj
[9/216] Building C object drivers/TMG4903Light/CMakeFiles/TMG4903Light.dir/TMG4903LightSensor.c.obj
[10/216] Building C object drivers/ORG1510/CMakeFiles/ORG1510.dir/ORG1510PhysicalGPS.c.obj
[11/216] Building C object drivers/VirtAnyMotion/CMakeFiles/VirtAnyMotion.dir/VirtAnyMotion.c.obj
[12/216] Linking C static library drivers\VirtWakeupStepDetector\libVirtWakeupStepDetector.a
[13/216] Building C object drivers/VirtSignificantMotion/CMakeFiles/VirtSignificantMotion.dir/VirtSignificantMotion.c.obj
I saw you created the second topic for also BHI260AB SDK build issue in following link:
https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BHI260-SDK-compiler-errors/m-p/17675
I want to combine the answer in that ticket.
How do you think?
No these are separate issues run on different machines but with slightly different Windows build versions. The problem on both posts, with this problem it crashes my machine - the other is build failure.
Both of my posts use separate machines with Windows 10 version 2004 installed but the builds are different - this post has the later of the 2 windows builds installed but is the most serious problem because it crashes and locks the build directory.
To move forward you need to be working with Windows 10 version 2004 not 1809 as you said in your other post reply.
I have given the exact windows 10 v2004 build ID in this post already, I have also replied to the other post with it's exact windows 10 build ID so you have them both for comparision
The installation in this post used ARC GNU IDE version 2020-03 (4.15.0) which is the same as in the other post
Regards
Richard
Can you try with arc_gnu_2018 version(https://github.com/foss-for-synopsys-dwc-arc-processors/toolchain/releases/tag/arc-2018.09-release ) first to see if it can solve your question?
