Hello, I made a product with BHI260AB.
My product specifications are as follows.
1. Use BHI260AB and AK09915.
2. The direction of the IC is the same as the SHUTTLE board.
3. The SDK you are using is v1.3.0.
4. The firmware is "Bosch_SHUTTLE_BHI260_AK09915_turbo-flash".(Questions link)
I am inquiring about a problem while checking the EULER value because I need an accurate heading angle.
I set "BHY2_SENSOR_ID_RV_WU" and "BHY2_SENSOR_ID_ORI_WU" on the sensor. Checking quaternion and EULER values
1. The first question.
The sensor will normally output the heading value until roll 135deg.
If the roll exceeds 135 deg, there is a difference of approximately 155 deg.
2. Second question.
When the roll is fixed to about 90deg and the pitch is moved +-90deg, the values of roll and yaw change.
Are the above two problems caused by gimbal lock?
Is there any solution?
Please let me know if there is a better solution to check the heading angle no matter what angle the sensor is at.
The Log I measured is as follows.
1.
Quat W X Y Z Euler X Y Z
0.6014 0.0128 -0.0031 0.7988 1.4 -0.6 254.5
0.6016 0.0128 -0.0032 0.7986 1.4 -0.6 254.5
0.6021 0.0125 -0.0035 0.7983 1.4 -0.5 254.5
0.6024 0.0122 -0.0038 0.798 1.4 -0.5 254.6
0.6027 0.012 -0.0042 0.7979 1.4 -0.4 254.6
0.6029 0.0118 -0.0043 0.7977 1.4 -0.4 254.7
0.603 0.0117 -0.0045 0.7975 1.4 -0.4 254.7
0.6032 0.0117 -0.0046 0.7974 1.4 -0.4 254.7
0.6033 0.0117 -0.0046 0.7974 1.4 -0.4 254.7
0.6034 0.0117 -0.0046 0.7972 1.4 -0.4 254.7
0.6036 0.0117 -0.0046 0.7971 1.4 -0.4 254.8
0.6038 0.0117 -0.0046 0.797 1.4 -0.4 254.8
0.6039 0.0118 -0.0045 0.7969 1.4 -0.4 254.8
0.604 0.0117 -0.0044 0.7968 1.4 -0.4 254.8
0.6042 0.0117 -0.0043 0.7967 1.4 -0.4 254.8
0.6044 0.0115 -0.0043 0.7965 1.4 -0.4 254.9
0.6052 0.0114 -0.0045 0.7959 1.3 -0.4 255
0.6058 0.011 -0.0047 0.7955 1.3 -0.3 255.1
0.6065 0.0106 -0.0052 0.7949 1.3 -0.3 255.2
0.6072 0.0101 -0.0057 0.7944 1.3 -0.2 255.3
0.6083 0.0095 -0.0065 0.7935 1.3 -0.1 255.4
0.6089 0.0093 -0.0068 0.7932 1.3 0 255.5
0.6094 0.0092 -0.007 0.7927 1.3 0 255.6
0.6099 0.009 -0.0073 0.7924 1.3 0 255.6
0.6105 0.0088 -0.0074 0.7919 1.3 0.1 255.7
0.6322 0.0085 -0.0076 0.7747 1.3 0.1 258.8
0.6322 0.0084 -0.0076 0.7747 1.3 0.1 258.8
0.6322 0.0083 -0.0075 0.7747 1.3 0.1 258.8
0.6326 0.0082 -0.0075 0.7744 1.3 0.1 258.9
0.6328 0.0083 -0.0074 0.7742 1.3 0.1 258.9
0.6329 0.0082 -0.0074 0.7741 1.3 0.1 258.9
0.6331 0.0082 -0.0074 0.7739 1.3 0.1 258.9
0.6334 0.0083 -0.0074 0.7737 1.3 0.1 259
0.6335 0.0083 -0.0076 0.7736 1.3 0.1 259
0.6337 0.0083 -0.0077 0.7734 1.3 0.1 259
0.6337 0.0083 -0.0078 0.7734 1.3 0.1 259
0.6335 0.0083 -0.0078 0.7736 1.3 0.1 259
0.6329 0.0081 -0.0082 0.7741 1.3 0.1 258.9
0.6329 0.0077 -0.0089 0.7741 1.3 0.2 258.9
0.6331 0.007 -0.0098 0.774 1.3 0.4 258.9
0.6336 0.0063 -0.0109 0.7735 1.4 0.5 259
0.6335 0.0059 -0.0116 0.7736 1.4 0.6 259
0.6332 0.0058 -0.0121 0.7739 1.4 0.6 258.9
0.6331 0.0057 -0.0125 0.7739 1.4 0.7 258.9
0.6331 0.0056 -0.0128 0.7739 1.4 0.7 258.9
0.6329 0.005 -0.0132 0.7741 1.4 0.8 258.9
0.6332 0.0042 -0.0137 0.7737 1.4 0.9 259
0.6334 0.0031 -0.0142 0.7736 1.3 1 259
0.6336 0.0023 -0.0146 0.7735 1.3 1.1 259
0.6333 0.0023 -0.0146 0.7737 1.3 1.1 259
0.6327 0.0023 -0.0145 0.7742 1.3 1.1 258.9
0.6321 0.002 -0.0146 0.7747 1.2 1.1 258.8
0.6326 0.0012 -0.0156 0.7743 1.2 1.3 258.9
0.6327 -0.0002 -0.0173 0.7742 1.2 1.5 258.9
0.6332 -0.0013 -0.0186 0.7737 1.2 1.7 259
0.6339 -0.0024 -0.0197 0.7732 1.2 1.9 259
0.6342 -0.0033 -0.0211 0.7728 1.2 2.1 259.1
0.6341 -0.0037 -0.0215 0.7729 1.2 2.2 259.1
0.634 -0.0042 -0.0217 0.7729 1.2 2.2 259.1
0.6343 -0.0049 -0.0226 0.7727 1.2 2.4 259.1
0.6351 -0.0061 -0.0239 0.772 1.2 2.6 259.2
0.6354 -0.007 -0.0253 0.7717 1.2 2.7 259.3
0.6348 -0.0073 -0.0256 0.7722 1.2 2.8 259.2
0.6338 -0.0068 -0.0251 0.773 1.2 2.7 259.1
0.6323 -0.0057 -0.0241 0.7743 1.2 2.6 258.8
0.6303 -0.0039 -0.0225 0.7759 1.3 2.3 258.6
0.6284 -0.0011 -0.0215 0.7776 1.5 2 258.3
0.6273 0.0008 -0.0206 0.7784 1.6 1.8 258.1
0.6273 -0.0004 -0.0222 0.7784 1.5 2 258.1
0.6271 -0.0003 -0.0223 0.7786 1.6 2 258.1
0.6263 0.0002 -0.0227 0.7792 1.6 2 258
0.6253 0.0004 -0.0229 0.78 1.7 2 257.8
0.624 0.0007 -0.0228 0.7811 1.7 2 257.7
0.6225 0.0011 -0.0219 0.7823 1.7 1.9 257.4
0.6215 0.0012 -0.0204 0.7831 1.6 1.7 257.3
0.6203 0.0011 -0.0191 0.7841 1.5 1.6 257.1
0.6196 0.0005 -0.0177 0.7847 1.3 1.5 257
0.6194 -0.0002 -0.017 0.7848 1.2 1.5 257
0.6196 -0.0006 -0.0175 0.7847 1.2 1.6 257
0.6202 -0.0015 -0.0182 0.7842 1.2 1.7 257.1
0.621 -0.0027 -0.0197 0.7834 1.2 2 257.2
0.6218 -0.0043 -0.0214 0.7828 1.1 2.2 257.3
0.6226 -0.0059 -0.0228 0.7822 1.1 2.5 257.5
0.6232 -0.0068 -0.024 0.7816 1.1 2.6 257.6
0.6237 -0.0075 -0.0249 0.7812 1.1 2.8 257.6
0.6245 -0.0084 -0.0258 0.7806 1.1 2.9 257.7
0.6253 -0.0099 -0.0273 0.7798 1.1 3.2 257.9
0.6256 -0.011 -0.029 0.7795 1.1 3.4 257.9
0.6257 -0.0119 -0.0301 0.7793 1.1 3.5 257.9
0.6257 -0.0128 -0.0308 0.7793 1.1 3.7 257.9
0.6251 -0.0133 -0.0313 0.7798 1 3.7 257.8
0.6242 -0.0132 -0.0315 0.7805 1.1 3.8 257.7
0.6232 -0.013 -0.0313 0.7813 1.1 3.7 257.6
0.6223 -0.0123 -0.0308 0.7821 1.1 3.6 257.4
0.6218 -0.0119 -0.0302 0.7824 1.1 3.5 257.4
0.6215 -0.0117 -0.03 0.7827 1.1 3.5 257.3
0.621 -0.0113 -0.0294 0.7831 1.1 3.4 257.2
0.6205 -0.0109 -0.0288 0.7835 1.1 3.4 257.2
0.6204 -0.0106 -0.0284 0.7837 1.1 3.3 257.2
0.621 -0.0101 -0.0279 0.7832 1.1 3.2 257.2
0.6219 -0.01 -0.0279 0.7824 1.1 3.2 257.4
0.6229 -0.0106 -0.0286 0.7817 1.1 3.3 257.5
0.6239 -0.0114 -0.0294 0.7808 1.1 3.4 257.7
0.6248 -0.0118 -0.0302 0.78 1.1 3.5 257.8
0.6257 -0.0126 -0.0311 0.7793 1.1 3.7 257.9
0.6266 -0.0137 -0.0325 0.7784 1.1 3.9 258.1
0.627 -0.0143 -0.0332 0.7782 1.1 4 258.1
0.6271 -0.0147 -0.0337 0.778 1.1 4.1 258.1
0.6274 -0.015 -0.0342 0.7777 1.1 4.1 258.2
0.6276 -0.015 -0.0345 0.7776 1.1 4.2 258.2
0.6271 -0.015 -0.0349 0.778 1.2 4.2 258.1
0.6263 -0.0148 -0.035 0.7786 1.2 4.2 258
0.6257 -0.0147 -0.0352 0.7791 1.2 4.2 257.9
0.6248 -0.0144 -0.0347 0.7798 1.2 4.1 257.8
0.6236 -0.0135 -0.0334 0.7809 1.2 4 257.6
0.6226 -0.0122 -0.0314 0.7818 1.1 3.7 257.5
0.6218 -0.0115 -0.03 0.7825 1.1 3.5 257.4
0.6217 -0.0109 -0.029 0.7826 1.1 3.4 257.4
0.6225 -0.0109 -0.0292 0.782 1.1 3.4 257.5
0.6229 -0.0112 -0.0298 0.7816 1.1 3.5 257.5
0.6232 -0.0118 -0.0306 0.7814 1.1 3.6 257.6
0.6229 -0.0125 -0.0316 0.7815 1.1 3.7 257.5
0.6228 -0.0131 -0.0323 0.7816 1.1 3.8 257.5
0.6233 -0.014 -0.0335 0.7811 1.1 4 257.6
0.6241 -0.0151 -0.0348 0.7803 1.1 4.2 257.7
0.6252 -0.0163 -0.0361 0.7794 1.1 4.4 257.9
0.626 -0.0172 -0.0374 0.7787 1.1 4.6 258
0.6265 -0.0184 -0.0389 0.7781 1.1 4.8 258.1
0.6277 -0.0202 -0.041 0.777 1.1 5.1 258.3
0.6291 -0.0226 -0.0435 0.7758 1.1 5.5 258.5
0.6308 -0.0248 -0.0463 0.7741 1.1 5.9 258.7
0.633 -0.0276 -0.0497 0.772 1.2 6.4 259.1
0.6353 -0.0315 -0.0549 0.7696 1.2 7.2 259.4
0.6356 -0.0348 -0.059 0.7689 1.2 7.8 259.5
0.6353 -0.0364 -0.0611 0.769 1.2 8.1 259.5
0.6352 -0.0386 -0.0634 0.7687 1.2 8.4 259.5
0.6351 -0.0411 -0.0667 0.7684 1.2 8.9 259.5
0.6349 -0.0439 -0.0703 0.7681 1.2 9.4 259.5
0.6346 -0.0466 -0.0741 0.7678 1.3 10 259.5
0.6345 -0.0501 -0.0787 0.7672 1.3 10.6 259.5
0.634 -0.0546 -0.0845 0.7667 1.3 11.5 259.5
0.6331 -0.0587 -0.0927 0.7662 1.6 12.5 259.5
0.632 -0.0632 -0.1041 0.7653 2 13.9 259.4
0.6305 -0.0731 -0.1176 0.7637 2.1 15.8 259.4
0.6288 -0.0864 -0.1307 0.7615 1.9 18 259.4
0.6279 -0.0989 -0.1405 0.759 1.5 19.8 259.5
0.6266 -0.1096 -0.1484 0.7571 1.2 21.4 259.6
0.6254 -0.1158 -0.1571 0.7554 1.2 22.6 259.6
0.6247 -0.1206 -0.1624 0.7542 1.2 23.5 259.6
0.624 -0.1251 -0.1679 0.7528 1.2 24.3 259.7
0.623 -0.1306 -0.1741 0.7512 1.2 25.3 259.7
0.6215 -0.1365 -0.1812 0.7498 1.2 26.4 259.7
0.6196 -0.1428 -0.1893 0.7481 1.2 27.6 259.6
0.6179 -0.15 -0.1983 0.7458 1.2 29 259.6
0.6155 -0.1589 -0.2084 0.7432 1.2 30.6 259.6
0.6125 -0.1683 -0.2203 0.7402 1.2 32.4 259.6
0.6095 -0.1788 -0.2329 0.7364 1.2 34.4 259.6
0.6064 -0.1894 -0.245 0.7323 1.1 36.3 259.6
0.6031 -0.1992 -0.2568 0.7283 1.1 38.1 259.6
0.5997 -0.2088 -0.2684 0.7243 1.1 39.9 259.6
0.5964 -0.2175 -0.2788 0.7205 1.1 41.5 259.6
0.5933 -0.2254 -0.2878 0.7171 1 42.9 259.6
0.5897 -0.2345 -0.2988 0.7126 1 44.4 259.6
0.5853 -0.2446 -0.311 0.7077 1 46.7 259.5
0.5815 -0.2535 -0.3217 0.7028 1 48.3 259.6
0.5775 -0.2621 -0.3321 0.6981 1 49.9 259.5
0.5735 -0.2706 -0.3419 0.6934 1 51.5 259.5
0.5688 -0.2806 -0.3536 0.6875 0.9 53.4 259.5
0.5645 -0.289 -0.3641 0.682 1 55.1 259.6
0.5604 -0.2968 -0.3734 0.6771 0.9 56.7 259.6
0.5558 -0.3053 -0.3833 0.6714 0.9 58.4 259.6
0.5512 -0.3134 -0.3932 0.6657 0.9 60.1 259.6
0.5472 -0.3209 -0.402 0.6602 0.9 61.7 259.6
0.5432 -0.328 -0.4113 0.6544 1 63.3 259.7
0.5391 -0.3345 -0.4197 0.6489 1 64.7 259.8
0.534 -0.3422 -0.4279 0.6439 0.9 66.3 259.7
0.5284 -0.3503 -0.4352 0.6391 0.7 67.8 259.5
0.5253 -0.3558 -0.4417 0.6342 0.7 69 259.6
0.5213 -0.362 -0.4488 0.629 0.7 70.3 259.6
0.5161 -0.3702 -0.4577 0.6221 0.7 72 259.7
0.5108 -0.3776 -0.4666 0.6154 0.7 73.7 259.7
0.5055 -0.3849 -0.475 0.6087 0.7 75.3 259.7
0.5005 -0.3918 -0.4827 0.6024 0.6 76.8 259.8
0.4956 -0.3979 -0.4901 0.5964 0.6 78.3 259.8
0.49 -0.4054 -0.4984 0.5892 0.6 79.9 259.8
0.4827 -0.4141 -0.5083 0.5805 0.6 81.9 259.8
0.4753 -0.4231 -0.5181 0.5714 0.5 84 259.8
0.4684 -0.4312 -0.5271 0.5628 0.5 85.8 259.9
0.462 -0.4385 -0.5353 0.5546 0.5 87.6 259.9
0.4545 -0.4474 -0.5451 0.5441 0.5 89.7 260.1
0.4446 -0.4578 -0.5559 0.5325 0.4 92.1 260
0.4333 -0.4694 -0.5685 0.5182 0.4 95 260.1
0.4214 -0.481 -0.5811 0.5032 0.3 97.9 260.2
0.408 -0.4919 -0.5937 0.4888 0.2 100.9 260
0.3929 -0.5002 -0.6069 0.4764 0 103.8 259.4
0.3796 -0.5081 -0.6182 0.4641 -0.1 106.4 258.9
0.3688 -0.5168 -0.6269 0.4514 -0.2 108.8 258.9
0.3654 -0.5222 -0.6304 0.4431 -0.1 110 259.4
0.3699 -0.5251 -0.6271 0.4404 0.1 109.9 260.4
0.367 -0.5297 -0.6299 0.4334 0.2 110.9 260.8
0.3606 -0.5342 -0.6349 0.4259 0.2 112.3 260.8
0.3545 -0.5392 -0.6394 0.4178 0.2 113.7 260.9
0.347 -0.5455 -0.6446 0.408 0.1 115.4 261
0.3383 -0.5521 -0.6505 0.3969 0.1 117.3 261.2
0.3295 -0.5583 -0.6567 0.3852 0.1 119.3 261.3
0.3201 -0.5646 -0.663 0.3729 0.2 121.4 261.5
0.3102 -0.571 -0.6686 0.3613 0.1 123.4 261.5
0.301 -0.5773 -0.6739 0.3493 0.1 125.4 261.7
0.2912 -0.5833 -0.679 0.3375 0.1 127.3 261.8
0.2831 -0.5884 -0.6829 0.3273 0.1 128.9 261.9
0.2764 -0.5928 -0.6861 0.3185 0.1 130.3 262.1
0.27 -0.5968 -0.689 0.3102 0.1 131.5 262.3
0.2538 -0.6063 -0.6951 0.2911 0 134.4 262.4
0.2451 -0.6113 -0.6985 0.2797 0 136.4 82.6
0.236 -0.6163 -0.7017 0.2683 0 138.1 82.8
0.2277 -0.6204 -0.7046 0.2582 0 139.6 82.9
0.22 -0.6243 -0.707 0.2487 0 141 83
0.2126 -0.6281 -0.709 0.2399 0 142.3 83.2
0.206 -0.6316 -0.7106 0.2314 0 143.6 83.4
0.2 -0.6349 -0.7119 0.2238 0 144.8 83.6
0.1932 -0.6385 -0.7128 0.2159 0 146 83.8
0.1862 -0.642 -0.7142 0.2071 0 147.4 84
0.1782 -0.6458 -0.7156 0.1974 0 148.9 84.2
0.17 -0.6493 -0.717 0.1878 0 150.4 84.4
0.1531 -0.6564 -0.7194 0.1676 0 153.5 84.8
0.1444 -0.6599 -0.7202 0.1582 0 155.1 85
0.1354 -0.663 -0.7211 0.148 -0.1 156.7 85.2
0.1267 -0.6659 -0.722 0.138 0 158.3 85.3
0.1196 -0.6686 -0.7223 0.1298 0 159.6 85.5
0.1115 -0.6711 -0.7228 0.1206 0 161 85.7
0.1015 -0.6745 -0.7229 0.1097 -0.1 162.7 86
0.0912 -0.6776 -0.7231 0.0983 -0.1 164.5 86.2
0.0804 -0.6804 -0.7233 0.0864 -0.1 166.4 86.4
0.0687 -0.683 -0.7233 0.0742 -0.1 168.4 86.6
0.0583 -0.6849 -0.7235 0.0626 -0.1 170.2 86.7
0.0482 -0.687 -0.7232 0.0521 -0.1 171.8 86.9
0.0389 -0.6889 -0.7225 0.0424 -0.1 173.4 87.1
0.03 -0.6905 -0.7219 0.033 -0.1 174.9 87.2
0.0222 -0.6918 -0.7213 0.0247 -0.1 176.2 87.4
0.0129 -0.6935 -0.7202 0.0148 -0.1 177.7 87.6
0.0032 -0.6953 -0.7186 0.0048 -0.1 179.3 87.8
0.0067 0.6965 0.7174 0.0055 -0.1 -179 88
0.0165 0.6979 0.7158 0.0154 -0.1 -177.4 88.2
0.0243 0.6986 0.7147 0.0234 -0.1 -176.1 88.4
0.0311 0.6995 0.7132 0.0302 -0.1 -175 88.5
0.0372 0.7002 0.712 0.0361 -0.1 -174 88.7
0.0417 0.7009 0.7108 0.0408 -0.1 -173.3 88.8
0.0449 0.7018 0.7095 0.044 -0.1 -172.8 89
0.0479 0.7025 0.7084 0.0471 -0.1 -172.3 89.1
0.0518 0.7029 0.7075 0.0508 -0.1 -171.7 89.2
0.0556 0.7037 0.7062 0.0546 -0.1 -171 89.3
0.0589 0.7042 0.7051 0.0576 -0.1 -170.5 89.5
0.0623 0.7047 0.7041 0.0606 -0.1 -170 90.5
0.0649 0.7052 0.7031 0.0632 -0.1 -169.6 90.6
0.066 0.7057 0.7025 0.0641 -0.1 -169.4 90.7
0.0668 0.706 0.702 0.0648 -0.1 -169.3 90.7
0.0669 0.706 0.702 0.0647 -0.1 -169.3 90.7
0.0659 0.7068 0.7014 0.0635 -0.1 -169.5 90.9
0.0638 0.7075 0.7011 0.061 -0.2 -169.8 90.9
0.0609 0.7083 0.7008 0.0582 -0.2 -170.3 91
0.0585 0.7089 0.7007 0.0557 -0.2 -170.7 91.1
0.0568 0.709 0.7007 0.0539 -0.2 -171 91.1
0.0551 0.7098 0.7003 0.0519 -0.2 -171.3 91.2
0.0534 0.7101 0.7002 0.05 -0.2 -171.6 91.2
0.0502 0.7107 0.7001 0.0468 -0.2 -172.1 91.2
0.0455 0.7111 0.7003 0.0421 -0.2 -172.9 91.3
0.0396 0.7114 0.7007 0.0362 -0.2 -173.8 91.2
0.0318 0.7115 0.7014 0.0284 -0.2 -175.1 91.2
0.0215 0.712 0.7016 0.0183 -0.2 -176.8 91.2
0.0092 0.7121 0.7019 0.0062 -0.2 -178.7 91.2
0.0043 -0.7121 -0.702 0.007 -0.2 179.1 91.2
0.0182 -0.7117 -0.7019 0.0206 -0.2 176.8 91.2
0.0328 -0.7111 -0.7014 0.035 -0.2 174.5 91.2
0.047 -0.7098 -0.701 0.0489 -0.2 172.2 91.1
0.0604 -0.7079 -0.7009 0.0621 -0.2 170 91
0.0729 -0.7061 -0.7003 0.0746 -0.2 168 90.9
0.0848 -0.704 -0.6998 0.0864 -0.2 166 90.8
0.0953 -0.7017 -0.6994 0.0967 -0.1 164.3 90.6
0.1055 -0.6997 -0.6984 0.1068 -0.1 162.6 90.6
0.1154 -0.6972 -0.6978 0.1169 -0.1 161 89.5
0.124 -0.695 -0.6969 0.1258 -0.1 159.5 89.4
0.1307 -0.6932 -0.6962 0.1327 -0.1 158.4 89.3
0.1389 -0.6911 -0.6951 0.1412 -0.1 157 89.2
0.147 -0.6882 -0.6945 0.1495 -0.1 155.6 89.1
0.1548 -0.6856 -0.6935 0.1577 -0.1 154.2 88.9
0.1639 -0.6827 -0.6921 0.1672 -0.1 152.7 88.8
0.173 -0.6795 -0.6907 0.1768 -0.1 151.1 88.7
0.1827 -0.6758 -0.6891 0.1868 0 149.4 88.5
0.1928 -0.6721 -0.6872 0.1967 0 147.7 88.4
0.2023 -0.6685 -0.6851 0.2069 0 146.1 88.3
0.2114 -0.6649 -0.6829 0.2163 0.1 144.5 88.2
0.2202 -0.6616 -0.6802 0.2261 0 142.9 88.1
0.2302 -0.6575 -0.6772 0.2369 0 141.2 88
0.2407 -0.6525 -0.6744 0.2478 0.1 139.4 87.8
0.2511 -0.6473 -0.6713 0.2592 0.1 137.6 87.7
0.2615 -0.642 -0.6678 0.2711 0.1 135.9 87.5
0.2719 -0.6368 -0.6641 0.2819 0.1 133.8 267.7
0.283 -0.6307 -0.6597 0.2945 0.1 131.8 267.5
0.296 -0.6239 -0.6542 0.3082 0.2 129.6 267.5
0.3096 -0.616 -0.6484 0.3226 0.2 127.1 267.4
0.323 -0.608 -0.6422 0.3369 0.3 124.6 267.4
0.3367 -0.5991 -0.6356 0.3517 0.4 122 267.3
0.3495 -0.5902 -0.6285 0.3665 0.4 119.4 267.1
0.3623 -0.5809 -0.6218 0.3802 0.5 116.8 267
0.3742 -0.572 -0.6149 0.3932 0.6 114.4 267
0.3871 -0.5618 -0.6069 0.4075 0.7 111.7 266.9
0.4004 -0.5511 -0.5983 0.4219 0.8 109 266.8
0.4132 -0.54 -0.5897 0.4357 1 106.2 266.8
0.4254 -0.5287 -0.5807 0.4496 1.1 103.5 266.7
0.4367 -0.5182 -0.5704 0.464 1 100.8 266.4
0.4481 -0.5068 -0.5623 0.4755 1.3 98.4 266.5
0.459 -0.4954 -0.5536 0.4871 1.5 96 266.5
0.4684 -0.485 -0.5434 0.5 1.4 93.5 266.2
0.4783 -0.4736 -0.5339 0.5117 1.5 91.1 266
0.4881 -0.462 -0.5242 0.5229 1.6 88.6 266
0.4972 -0.4509 -0.5137 0.5343 1.7 86.2 265.8
0.5059 -0.4398 -0.5037 0.5449 1.7 83.9 265.7
0.514 -0.4286 -0.4937 0.5552 1.8 81.6 265.5
0.5214 -0.4178 -0.4841 0.5649 1.9 79.5 265.4
0.529 -0.4069 -0.4749 0.5735 2 77.4 265.3
0.5358 -0.3971 -0.4657 0.5816 2.1 75.4 265.3
0.5408 -0.389 -0.4584 0.5881 2.2 73.9 265.2
0.5455 -0.3813 -0.4517 0.5941 2.3 72.4 265.1
0.5504 -0.3727 -0.4429 0.6015 2.2 70.6 264.9
0.5555 -0.3632 -0.4338 0.6094 2.3 68.8 264.7
0.561 -0.3536 -0.4241 0.6166 2.3 66.9 264.6
0.5667 -0.3431 -0.4136 0.6245 2.3 64.8 264.5
0.5731 -0.3311 -0.4023 0.6324 2.4 62.6 264.4
0.5794 -0.3193 -0.3904 0.6401 2.5 60.3 264.4
0.5847 -0.3085 -0.3782 0.6479 2.4 58.1 264.2
0.5881 -0.299 -0.3676 0.6554 2.3 56.3 263.9
0.5906 -0.2909 -0.3589 0.6616 2.2 54.7 263.6
0.592 -0.2841 -0.3503 0.6678 2 53.3 263.3
0.5935 -0.2779 -0.3418 0.6735 1.8 52 262.9
0.5957 -0.2706 -0.3339 0.6785 1.7 50.7 262.7
0.5984 -0.2637 -0.3265 0.6824 1.8 49.5 262.7
0.6007 -0.2572 -0.3194 0.6862 1.8 48.3 262.6
0.6024 -0.2519 -0.3143 0.6891 1.8 47.5 262.5
0.604 -0.2456 -0.3081 0.6927 1.8 46.5 262.4
0.6059 -0.2396 -0.3021 0.6958 1.9 45.5 262.3
0.6077 -0.2336 -0.2964 0.6987 1.9 44.2 262.2
0.6096 -0.2285 -0.2909 0.701 2 43.3 262.2
0.6115 -0.2222 -0.2845 0.704 2 42.3 262.2
0.6133 -0.2145 -0.2772 0.7077 2.1 41.1 262
0.6155 -0.2082 -0.2693 0.7108 2 39.9 262
0.6174 -0.2011 -0.2615 0.7141 2 38.7 261.9
0.6187 -0.1951 -0.2549 0.717 2 37.7 261.8
0.6199 -0.1899 -0.2493 0.7193 2 36.7 261.7
0.6208 -0.1849 -0.2437 0.7217 2 35.8 261.6
0.6215 -0.1808 -0.2393 0.7236 2 35.1 261.6
0.622 -0.1771 -0.2348 0.7256 2 34.4 261.5
0.623 -0.1715 -0.2299 0.7277 2.1 33.6 261.4
0.6242 -0.166 -0.2238 0.7298 2.1 32.6 261.3
0.6255 -0.1601 -0.2173 0.732 2.1 31.5 261.3
0.6266 -0.1536 -0.21 0.7345 2.1 30.4 261.2
0.6287 -0.1437 -0.1982 0.738 2.1 28.5 261.1
0.6306 -0.1339 -0.1869 0.7412 2.1 26.7 261
0.631 -0.129 -0.1814 0.7431 2.1 25.8 260.9
0.6316 -0.1232 -0.1755 0.745 2.2 24.9 260.9
0.6324 -0.1168 -0.1679 0.7471 2.2 23.7 260.8
0.6328 -0.1124 -0.1629 0.7485 2.2 22.9 260.7
0.6329 -0.1074 -0.1584 0.7501 2.3 22.1 260.6
0.633 -0.1013 -0.1536 0.7519 2.4 21.2 260.5
0.6328 -0.0955 -0.1496 0.7537 2.6 20.4 260.3
0.6325 -0.0905 -0.1457 0.7552 2.7 19.7 260.2
0.6325 -0.0863 -0.1412 0.7566 2.7 19 260.1
0.6324 -0.0822 -0.1352 0.7582 2.6 18.1 260
0.6323 -0.0779 -0.1296 0.7598 2.6 17.3 259.9
0.6318 -0.0734 -0.1253 0.7614 2.7 16.5 259.7
0.6308 -0.0693 -0.1218 0.7631 2.7 15.9 259.5
0.6298 -0.0656 -0.1183 0.7648 2.8 15.3 259.3
0.6285 -0.0618 -0.1138 0.7668 2.8 14.7 259
0.6274 -0.058 -0.1091 0.7687 2.7 14 258.8
0.626 -0.055 -0.1037 0.7709 2.6 13.3 258.5
0.6244 -0.0533 -0.0983 0.773 2.3 12.7 258.2
0.6233 -0.0507 -0.0939 0.7746 2.2 12.1 258
0.6234 -0.0479 -0.0915 0.775 2.3 11.7 258
0.6251 -0.045 -0.0886 0.7742 2.3 11.2 258.2
0.6285 -0.0409 -0.0848 0.772 2.5 10.5 258.7
0.6307 -0.0375 -0.0806 0.7708 2.5 9.9 258.9
0.6328 -0.0336 -0.0762 0.7698 2.5 9.2 259.2
0.6343 -0.03 -0.0715 0.7692 2.5 8.5 259.4
0.6339 -0.0262 -0.0668 0.7701 2.5 7.8 259.3
0.6334 -0.0231 -0.0628 0.7708 2.5 7.3 259.2
0.6331 -0.0196 -0.0597 0.7715 2.6 6.7 259.1
0.6328 -0.0178 -0.0575 0.7719 2.6 6.4 259
0.6328 -0.0164 -0.0559 0.7721 2.6 6.2 259
0.6323 -0.014 -0.0549 0.7726 2.7 5.9 259
0.6321 -0.0125 -0.0529 0.7729 2.7 5.6 258.9
0.6318 -0.0107 -0.0511 0.7733 2.7 5.3 258.9
0.6309 -0.0059 -0.0496 0.7742 3.1 4.8 258.7
0.6304 -0.0047 -0.043 0.775 2.7 4.2 258.6
0.6301 -0.0039 -0.0389 0.7755 2.5 3.7 258.6
0.6295 -0.0023 -0.0371 0.7761 2.5 3.5 258.5
0.6287 -0.0001 -0.0349 0.7769 2.5 3.1 258.4
0.6281 0.0013 -0.033 0.7773 2.5 2.8 258.3
0.6276 0.002 -0.032 0.7778 2.5 2.7 258.2
0.6273 0.0031 -0.0311 0.7781 2.5 2.5 258.1
0.627 0.004 -0.0305 0.7784 2.5 2.4 258.1
0.6265 0.0049 -0.0296 0.7787 2.6 2.3 258
0.6262 0.007 -0.0275 0.7791 2.6 2 258
0.6257 0.0084 -0.0259 0.7795 2.6 1.7 257.9
0.625 0.0094 -0.0247 0.7801 2.6 1.5 257.8
0.6243 0.0107 -0.024 0.7807 2.7 1.4 257.7
2.
0.6188 -0.5388 -0.439 0.366 8.6 88 298.3
0.618 -0.5392 -0.4401 0.3654 8.6 88.2 298.3
0.6171 -0.5397 -0.441 0.3651 8.6 88.4 298.2
0.6163 -0.5396 -0.4419 0.3656 8.6 88.4 298.1
0.6155 -0.5394 -0.4427 0.3664 8.6 88.5 297.9
0.615 -0.5393 -0.4431 0.3668 8.6 88.5 297.8
0.6149 -0.5394 -0.4431 0.3669 8.6 88.5 297.8
0.6146 -0.5392 -0.4433 0.3672 8.6 88.5 297.7
0.6144 -0.5391 -0.4436 0.3675 8.6 88.5 297.7
0.6139 -0.5389 -0.444 0.368 8.5 88.6 297.6
0.6136 -0.5388 -0.4442 0.3685 8.5 88.6 297.5
0.6134 -0.5388 -0.4442 0.3688 8.5 88.6 297.4
0.613 -0.5381 -0.4446 0.3699 8.4 88.5 297.2
0.6125 -0.5373 -0.4449 0.3715 8.4 88.5 297
0.6132 -0.5348 -0.4447 0.3743 8.3 88.1 296.7
0.6143 -0.5319 -0.444 0.3774 8.3 87.7 296.3
0.6149 -0.5297 -0.4434 0.3802 8.2 87.4 296
0.6155 -0.5279 -0.4429 0.3824 8.1 87.1 295.7
0.6164 -0.5265 -0.442 0.3839 8.1 86.8 295.6
0.6172 -0.5253 -0.4411 0.3852 8 86.6 295.5
0.6185 -0.5239 -0.4399 0.3865 8 86.3 295.4
0.6197 -0.5228 -0.4384 0.3879 7.9 86 295.4
0.6207 -0.5212 -0.4368 0.3899 7.8 85.7 295.2
0.6222 -0.52 -0.4346 0.3918 7.7 85.3 295
0.6247 -0.5186 -0.4301 0.3947 7.3 84.6 294.9
0.626 -0.5176 -0.4277 0.3964 7.2 84.3 294.8
0.6276 -0.5168 -0.425 0.3977 7 84 294.7
0.6288 -0.5165 -0.4226 0.399 6.9 83.7 294.6
0.6297 -0.5165 -0.4202 0.4 6.7 83.5 294.6
0.6301 -0.5165 -0.4185 0.4013 6.5 83.3 294.4
0.6308 -0.5165 -0.4164 0.4022 6.3 83.1 294.4
0.6317 -0.5165 -0.4141 0.4032 6.1 82.9 294.3
0.6326 -0.5167 -0.4119 0.4038 6 82.7 294.3
0.6329 -0.5171 -0.4108 0.4041 5.9 82.6 294.3
0.6326 -0.5176 -0.4103 0.4041 5.8 82.6 294.3
0.6321 -0.5178 -0.4106 0.4045 5.8 82.7 294.2
0.6318 -0.5179 -0.4108 0.4047 5.7 82.7 294.1
0.6318 -0.5175 -0.4101 0.4059 5.6 82.6 294
0.6321 -0.517 -0.4086 0.4075 5.5 82.4 293.8
0.6323 -0.5172 -0.4067 0.4089 5.2 82.3 293.6
0.6315 -0.5181 -0.4047 0.411 4.9 82.2 293.3
0.6301 -0.5193 -0.4023 0.4139 4.4 82.1 292.8
0.6286 -0.5206 -0.4005 0.4163 4 82.1 292.4
0.6272 -0.5212 -0.3992 0.4189 3.7 82 291.9
0.626 -0.5218 -0.3978 0.4212 3.4 82 291.6
0.6249 -0.5228 -0.3955 0.4237 2.9 81.9 291.1
0.6234 -0.5244 -0.3911 0.4282 2.2 81.7 290.5
0.6215 -0.5258 -0.3869 0.433 1.5 81.5 289.7
0.6204 -0.527 -0.3828 0.4367 0.8 81.3 289.1
0.6194 -0.5284 -0.3785 0.4402 0.2 81.1 288.6
0.6185 -0.5302 -0.3736 0.4435 -0.5 80.8 288.2
0.6177 -0.5324 -0.3676 0.447 -1.2 80.6 287.7
0.6168 -0.5349 -0.3606 0.4509 -2.1 80.3 287.1
0.6158 -0.5374 -0.353 0.4553 -3.1 80 286.5
0.6142 -0.5405 -0.3447 0.4601 -4.2 79.7 285.8
0.6079 -0.5492 -0.3273 0.4708 -6.8 79.4 284
0.6029 -0.5546 -0.3193 0.4764 -8.3 79.4 282.9
0.5969 -0.5607 -0.3123 0.4812 -9.6 79.7 281.8
0.59 -0.5671 -0.3062 0.4863 -11 80 280.6
0.5826 -0.5736 -0.3008 0.491 -12.3 80.5 279.4
0.5748 -0.58 -0.2963 0.4954 -13.6 81 278.2
0.5671 -0.586 -0.2921 0.4995 -14.8 81.5 277.1
0.5593 -0.5917 -0.2885 0.5037 -15.9 82 275.9
0.5521 -0.5975 -0.2847 0.507 -17 82.6 274.9
0.5453 -0.6027 -0.2809 0.5103 -18.1 83 273.9
0.5391 -0.6074 -0.2771 0.5134 -19.1 83.4 273
0.5339 -0.6113 -0.2734 0.5161 -19.9 83.7 272.2
0.5294 -0.6143 -0.2704 0.5189 -20.7 83.9 271.5
0.5256 -0.6166 -0.2676 0.5214 -21.3 84.1 270.9
0.5219 -0.6186 -0.2652 0.5239 -21.9 84.2 269.3
0.5181 -0.621 -0.2624 0.5264 -22.6 84.3 268.7
0.514 -0.6233 -0.2593 0.5291 -23.3 84.5 268.1
0.5098 -0.6257 -0.2559 0.532 -24 84.6 267.3
0.5052 -0.6284 -0.2519 0.535 -24.9 84.7 266.6
0.5002 -0.631 -0.2477 0.5387 -25.8 84.8 265.7
0.4951 -0.6336 -0.2433 0.5422 -26.7 85 264.8
0.4894 -0.6362 -0.2391 0.5463 -27.7 85.1 263.8
0.4836 -0.6385 -0.2346 0.5506 -28.7 85.1 262.8
0.4775 -0.6409 -0.2299 0.5552 -29.7 85.2 261.6
0.4715 -0.6429 -0.2251 0.5599 -30.8 85.2 260.5
0.4657 -0.6448 -0.2204 0.5645 -31.8 85.2 259.4
0.4597 -0.6464 -0.2156 0.5695 -32.8 85.1 258.2
0.4539 -0.6479 -0.2111 0.574 -33.8 85.1 257.1
0.4492 -0.6489 -0.2067 0.5782 -34.7 85 256.1
0.4447 -0.6495 -0.2021 0.5826 -35.5 84.8 255.2
0.4401 -0.6503 -0.1967 0.587 -36.4 84.5 254.2
0.4349 -0.651 -0.1913 0.5919 -37.4 84.3 253.1
0.4297 -0.6517 -0.1858 0.5967 -38.4 84 252.1
0.4246 -0.6525 -0.1804 0.601 -39.3 83.8 251
0.4197 -0.6533 -0.1753 0.6052 -40.2 83.6 250
0.4154 -0.6538 -0.1701 0.6091 -41 83.4 249.1
0.4112 -0.6544 -0.1646 0.6128 -41.9 83.1 248.3
0.4066 -0.6553 -0.1595 0.6163 -42.7 82.9 247.4
0.3971 -0.6569 -0.1492 0.6232 -44.3 82.6 245.5
0.3926 -0.6573 -0.1442 0.6268 -45.5 82.3 244.7
0.389 -0.6578 -0.1392 0.6298 -46.2 82 243.9
0.3856 -0.6581 -0.1342 0.6326 -46.9 81.8 243.2
0.3823 -0.6583 -0.1293 0.6353 -47.5 81.5 242.6
0.3791 -0.6586 -0.1244 0.6379 -48.2 81.2 242
0.3761 -0.659 -0.1191 0.6403 -48.8 81 241.4
0.3726 -0.6596 -0.1142 0.6426 -49.5 80.8 240.7
0.369 -0.6603 -0.1095 0.6448 -50.2 80.6 240.1
0.3653 -0.6609 -0.1048 0.6471 -50.9 80.4 239.4
0.3616 -0.6613 -0.1001 0.6495 -51.6 80.2 238.7
0.3578 -0.662 -0.0952 0.6515 -52.4 80 238
0.3542 -0.6628 -0.0905 0.6534 -53.1 79.8 237.4
0.3503 -0.6639 -0.0862 0.6549 -53.7 79.8 236.7
0.3463 -0.6653 -0.0822 0.6563 -54.4 79.9 236.1
0.3424 -0.6663 -0.078 0.6577 -55.1 79.9 235.4
0.3384 -0.6672 -0.0738 0.6594 -55.8 79.8 234.8
0.3344 -0.6678 -0.0692 0.6613 -56.5 79.6 234.1
0.3305 -0.668 -0.0651 0.6635 -57.2 79.4 233.4
0.327 -0.6686 -0.0605 0.665 -57.9 79.2 232.8
0.3228 -0.6699 -0.0558 0.6662 -58.7 79.2 232.1
0.3174 -0.6716 -0.0511 0.6675 -59.5 79.4 231.2
0.3121 -0.673 -0.0458 0.6689 -60.4 79.4 230.4
0.3069 -0.6741 -0.0401 0.6705 -61.3 79.4 229.5
0.3018 -0.675 -0.0344 0.6724 -62.3 79.2 228.7
0.2968 -0.6756 -0.0289 0.6743 -63.1 79 227.8
0.2927 -0.6759 -0.0239 0.6759 -63.9 78.7 227.1
0.2892 -0.6758 -0.0195 0.6776 -64.6 78.4 226.5
0.2863 -0.6757 -0.0156 0.6791 -65.2 78 226
0.2838 -0.6757 -0.012 0.6802 -65.7 77.8 225.6
0.2815 -0.6756 -0.0096 0.6813 -66.1 77.5 225.2
0.2805 -0.6755 -0.007 0.6818 -66.4 77.3 225
0.2797 -0.6756 -0.0047 0.6821 -66.6 77.2 224.9
0.2788 -0.6757 -0.0024 0.6823 -66.9 77.1 224.7
0.2781 -0.676 -0.0005 0.6823 -67.1 77.1 224.6
0.2775 -0.6763 0.0011 0.6823 -67.3 77.1 224.5
0.2764 -0.6765 0.0022 0.6825 -67.5 77.1 224.4
0.2751 -0.6768 0.0035 0.6828 -67.7 77.1 224.2
0.2734 -0.6771 0.0054 0.6831 -68 77.1 223.9
0.2713 -0.6774 0.0078 0.6837 -68.4 77 223.5
0.2688 -0.6773 0.0097 0.6847 -68.8 76.8 223.1
0.2662 -0.6771 0.012 0.6858 -69.1 76.5 222.7
0.2637 -0.6772 0.0141 0.6867 -69.5 76.2 222.3
0.2612 -0.6772 0.0157 0.6876 -69.9 76.1 221.8
0.2591 -0.6773 0.0173 0.6882 -70.2 75.9 221.5
0.2573 -0.6774 0.0189 0.6888 -70.5 75.8 221.2
0.2554 -0.6773 0.0205 0.6896 -70.8 75.5 220.9
0.2531 -0.6774 0.0223 0.6903 -71.1 75.3 220.5
0.2508 -0.6772 0.0239 0.6912 -71.4 75 220.1
0.249 -0.6771 0.0261 0.6919 -71.7 74.8 219.8
0.247 -0.6772 0.0275 0.6925 -72 74.6 219.5
0.2454 -0.6772 0.0284 0.6931 -72.2 74.4 219.2
0.2441 -0.6774 0.0296 0.6932 -72.4 74.4 219
0.2427 -0.6777 0.0302 0.6934 -72.6 74.5 218.8
0.2418 -0.6779 0.0313 0.6935 -72.8 74.4 218.6
0.2407 -0.6779 0.0317 0.6938 -72.9 74.3 218.4
0.24 -0.6779 0.0324 0.6942 -73 74.2 218.3
0.2397 -0.6777 0.0331 0.6943 -73.1 74.1 218.3
0.2394 -0.6777 0.0333 0.6943 -73.1 74.1 218.2
0.2392 -0.6777 0.0334 0.6944 -73.1 74.1 218.2
0.239 -0.6777 0.0336 0.6945 -73.2 74 218.2
0.2389 -0.6776 0.0339 0.6946 -73.2 73.9 218.1
0.2388 -0.6776 0.0341 0.6948 -73.2 73.9 218.1
0.2387 -0.6774 0.0342 0.6949 -73.2 73.8 218.1
0.2387 -0.6772 0.0342 0.6951 -73.2 73.7 218.1
0.2388 -0.6771 0.0343 0.6951 -73.2 73.6 218.1
0.239 -0.6771 0.0343 0.6951 -73.2 73.6 218.1
0.2391 -0.6771 0.0344 0.6951 -73.2 73.6 218.1
0.239 -0.6771 0.0344 0.6951 -73.2 73.6 218.1
0.2389 -0.6769 0.0344 0.6953 -73.2 73.6 218.1
0.2388 -0.6769 0.0342 0.6953 -73.2 73.6 218.1
0.2385 -0.677 0.0342 0.6953 -73.2 73.6 218
0.2383 -0.6769 0.0342 0.6954 -73.3 73.5 218
0.2381 -0.6769 0.0342 0.6956 -73.3 73.5 218
0.2378 -0.6769 0.0344 0.6957 -73.3 73.5 217.9
0.2379 -0.6771 0.0349 0.6955 -73.4 73.5 217.9
0.2374 -0.6773 0.0352 0.6954 -73.4 73.6 217.9
0.2374 -0.6775 0.0357 0.6952 -73.5 73.7 217.9
0.2373 -0.6777 0.0364 0.695 -73.5 73.7 217.9
0.2369 -0.6779 0.0369 0.6949 -73.6 73.8 217.8
0.2368 -0.6781 0.0377 0.6947 -73.7 73.9 217.8
0.2363 -0.6783 0.0381 0.6946 -73.8 73.9 217.7
0.2358 -0.6784 0.0388 0.6946 -73.9 73.9 217.7
0.2351 -0.6785 0.0393 0.6948 -74 73.9 217.6
0.2344 -0.6786 0.0399 0.6949 -74.1 73.8 217.4
0.234 -0.6785 0.0408 0.695 -74.2 73.7 217.4
0.2336 -0.6784 0.0413 0.6952 -74.2 73.6 217.3
0.2336 -0.6783 0.0416 0.6953 -74.3 73.6 217.3
0.2336 -0.6783 0.0419 0.6953 -74.3 73.6 217.3
0.2337 -0.6784 0.0422 0.6952 -74.3 73.6 217.3
0.2337 -0.6785 0.0424 0.6951 -74.3 73.6 217.3
0.2338 -0.6785 0.0425 0.6951 -74.3 73.6 217.4
0.2338 -0.6785 0.0427 0.6951 -74.3 73.6 217.4
0.2338 -0.6784 0.0428 0.6951 -74.3 73.5 217.4
0.2338 -0.6783 0.0428 0.6952 -74.4 73.5 217.4
0.2339 -0.6782 0.043 0.6953 -74.4 73.4 217.4
0.2342 -0.6779 0.043 0.6954 -74.3 73.3 217.4
0.2344 -0.6779 0.0428 0.6954 -74.3 73.3 217.4
0.2351 -0.6777 0.043 0.6953 -74.3 73.2 217.5
0.2355 -0.6777 0.0426 0.6953 -74.2 73.3 217.6
0.2357 -0.6776 0.0417 0.6954 -74.1 73.3 217.6
0.2365 -0.6774 0.0413 0.6953 -74 73.2 217.7
0.2374 -0.6772 0.0409 0.6952 -73.9 73.2 217.9
0.2382 -0.677 0.0403 0.6951 -73.8 73.2 218
0.2388 -0.6769 0.0397 0.695 -73.7 73.2 218.1
0.2397 -0.6768 0.0392 0.6948 -73.6 73.3 218.3
0.2405 -0.6767 0.0383 0.6948 -73.4 73.3 218.4
0.2412 -0.6766 0.0369 0.6947 -73.2 73.4 218.5
0.2424 -0.6765 0.0354 0.6945 -73 73.5 218.7
0.2435 -0.6763 0.0338 0.6943 -72.8 73.6 218.8
0.2447 -0.6762 0.032 0.6941 -72.6 73.7 219
0.2455 -0.6762 0.0298 0.6939 -72.3 73.9 219.2
0.2463 -0.6761 0.0274 0.6938 -72 74 219.3
0.2475 -0.6761 0.0249 0.6935 -71.7 74.2 219.5
0.2488 -0.6761 0.0222 0.6931 -71.4 74.4 219.7
0.2508 -0.6758 0.0195 0.6927 -71 74.6 220
0.2533 -0.6755 0.0172 0.6922 -70.6 74.7 220.4
0.2554 -0.6749 0.014 0.6921 -70.2 74.7 220.7
0.2582 -0.6741 0.011 0.6918 -69.7 74.7 221.2
0.2609 -0.6733 0.0073 0.6917 -69.1 74.7 221.6
0.2639 -0.6725 0.0033 0.6913 -68.6 74.7 222
0.2669 -0.6719 -0.0006 0.6907 -68 74.9 222.5
0.2695 -0.6719 -0.0045 0.6898 -67.5 75.2 222.9
0.2717 -0.6719 -0.0079 0.6888 -67 75.5 223.3
0.2739 -0.6722 -0.0109 0.6877 -66.6 75.9 223.7
0.276 -0.6725 -0.0138 0.6865 -66.1 76.3 224.1
0.2779 -0.6729 -0.0167 0.6853 -65.8 76.7 224.4
0.2798 -0.6731 -0.0198 0.6842 -65.3 77 224.8
0.2819 -0.6733 -0.023 0.683 -64.9 77.3 225.1
0.2842 -0.6738 -0.0261 0.6815 -64.4 77.8 225.6
0.2866 -0.6743 -0.0292 0.6799 -64 78.2 226
0.2898 -0.6746 -0.0323 0.678 -63.4 78.6 226.6
0.2935 -0.6747 -0.0355 0.6761 -62.9 78.9 227.2
0.2976 -0.6749 -0.0388 0.674 -62.2 79.3 228
0.3017 -0.6749 -0.0425 0.672 -61.6 79.6 228.7
0.306 -0.6747 -0.0461 0.67 -60.9 79.8 229.4
0.3098 -0.6747 -0.0499 0.668 -60.3 80.1 230.1
0.3129 -0.6747 -0.0533 0.6663 -59.7 80.4 230.7
0.315 -0.675 -0.0567 0.6647 -59.2 80.7 231.1
0.3167 -0.6755 -0.0599 0.6631 -58.8 81 231.4
0.3185 -0.6756 -0.0624 0.6619 -58.4 81.2 231.8
0.3204 -0.6755 -0.0652 0.6608 -58 81.4 232.1
0.3223 -0.6757 -0.0685 0.6594 -57.6 81.6 232.5
0.3251 -0.6758 -0.0717 0.6575 -57.1 81.9 233
0.3282 -0.6758 -0.0753 0.6556 -56.5 82.1 233.6
0.3318 -0.6757 -0.079 0.6534 -55.9 82.3 234.3
0.3364 -0.6754 -0.0826 0.6509 -55.2 82.5 235.1
0.3413 -0.6752 -0.0865 0.6481 -54.4 82.7 236
0.3465 -0.6747 -0.0908 0.6452 -53.6 82.9 236.9
0.3527 -0.674 -0.0947 0.642 -52.7 83 238
0.3591 -0.6729 -0.0995 0.639 -51.8 83 239.2
0.3657 -0.6715 -0.1044 0.6359 -50.8 83 240.3
0.3726 -0.6699 -0.1091 0.6328 -49.9 83 241.5
0.3796 -0.6681 -0.114 0.6296 -48.9 82.9 242.7
0.3868 -0.6664 -0.1183 0.6262 -48 82.8 243.9
0.3937 -0.6648 -0.1224 0.6228 -47.1 82.7 245.1
0.4005 -0.6633 -0.1263 0.6194 -46.2 82.7 246.3
0.4066 -0.6619 -0.1302 0.616 -45.4 82.7 247.4
0.4127 -0.6606 -0.1337 0.6127 -44.2 82.6 248.5
0.4179 -0.6593 -0.1375 0.6096 -43.5 82.6 249.4
0.4229 -0.6583 -0.1414 0.6063 -42.7 82.7 250.3
0.4276 -0.6574 -0.1458 0.603 -42 82.8 251.2
0.4325 -0.6563 -0.1503 0.5997 -41.2 82.9 252.1
0.4371 -0.6548 -0.1552 0.5967 -40.4 82.9 253
0.4415 -0.6531 -0.1601 0.5939 -39.6 82.9 253.8
0.4455 -0.6514 -0.1652 0.5914 -38.8 82.9 254.5
0.4495 -0.6498 -0.1699 0.5888 -38 82.9 255.2
0.4531 -0.6483 -0.1744 0.5864 -37.3 82.9 255.8
0.4567 -0.6468 -0.1787 0.5839 -36.6 82.9 256.5
0.4609 -0.6455 -0.1821 0.581 -35.9 82.9 257.3
0.4644 -0.6443 -0.1857 0.5786 -35.2 82.9 257.9
0.4682 -0.6431 -0.189 0.5756 -34.6 82.9 258.6
0.472 -0.642 -0.1927 0.5726 -33.9 83 259.4
0.4762 -0.6405 -0.1968 0.5693 -33.1 83 260.1
0.4802 -0.6391 -0.2016 0.5659 -32.3 83.1 260.9
0.4843 -0.6377 -0.2064 0.5623 -31.4 83.2 261.7
0.4877 -0.636 -0.2117 0.5592 -30.6 83.2 262.4
0.491 -0.6343 -0.2172 0.5561 -29.7 83.3 263
0.4942 -0.6326 -0.2225 0.553 -28.9 83.4 263.7
0.4975 -0.6309 -0.2276 0.55 -28.1 83.5 264.3
0.5005 -0.6292 -0.2327 0.5472 -27.3 83.5 264.9
0.5034 -0.6276 -0.2372 0.5444 -26.6 83.6 265.5
0.5065 -0.6259 -0.2418 0.5415 -25.8 83.6 266.1
0.5099 -0.624 -0.2466 0.5382 -25 83.7 266.7
0.5133 -0.6222 -0.2515 0.5348 -24.2 83.7 267.4
0.517 -0.6204 -0.2556 0.5314 -23.4 83.8 268.1
0.5203 -0.6184 -0.2601 0.5283 -22.6 83.8 268.7
0.5236 -0.6169 -0.2642 0.5248 -21.9 83.8 269.4
0.527 -0.6152 -0.2682 0.5214 -21.1 83.9 271
0.53 -0.6134 -0.2723 0.5182 -20.4 83.9 271.6
0.5322 -0.6117 -0.2765 0.5158 -19.8 84 272.1
0.5344 -0.61 -0.2801 0.5135 -19.2 84 272.5
0.5366 -0.6082 -0.2836 0.5114 -18.6 84 272.9
0.539 -0.6066 -0.2869 0.509 -18 84 273.4
0.5411 -0.6048 -0.2909 0.5066 -17.4 84 273.8
0.5433 -0.6032 -0.2951 0.5037 -16.7 84.1 274.4
0.5455 -0.6018 -0.2996 0.5005 -16.1 84.3 274.9
0.5474 -0.6003 -0.3039 0.4976 -15.4 84.4 275.4
0.5491 -0.5991 -0.3076 0.4948 -14.8 84.5 275.9
0.5507 -0.5978 -0.3107 0.4926 -14.3 84.6 276.2
0.5522 -0.5965 -0.3133 0.4909 -13.9 84.6 276.6
0.5533 -0.5958 -0.3152 0.4893 -13.6 84.6 276.9
0.5541 -0.5949 -0.3174 0.488 -13.3 84.6 277.1
0.5546 -0.5946 -0.3187 0.487 -13.1 84.7 277.2
0.5549 -0.5942 -0.3202 0.4861 -12.9 84.8 277.4
0.5555 -0.5939 -0.3212 0.485 -12.7 84.8 277.5
0.5558 -0.5937 -0.322 0.4846 -12.6 84.8 277.6
0.5562 -0.5932 -0.3231 0.4841 -12.4 84.9 277.7
0.5569 -0.5927 -0.324 0.4832 -12.2 84.9 277.9
0.5575 -0.5924 -0.3245 0.4825 -12.1 84.9 278
0.558 -0.5922 -0.325 0.4819 -12 84.9 278.1
0.5586 -0.592 -0.3253 0.4813 -11.9 84.9 278.2
0.5589 -0.5919 -0.326 0.4806 -11.8 84.9 278.4
0.5592 -0.5917 -0.327 0.4797 -11.7 85 278.5
0.5593 -0.5916 -0.3283 0.4789 -11.5 85 278.6
0.5593 -0.5914 -0.3298 0.4781 -11.3 85.1 278.7
0.5594 -0.5912 -0.3312 0.4771 -11.2 85.2 278.8
0.5598 -0.5909 -0.333 0.4759 -10.9 85.3 279
0.5601 -0.5906 -0.3347 0.4747 -10.7 85.4 279.1
0.5603 -0.5907 -0.3362 0.4733 -10.5 85.6 279.3
0.5608 -0.5903 -0.338 0.4719 -10.3 85.6 279.5
0.5614 -0.5901 -0.339 0.4708 -10.1 85.7 279.7
0.562 -0.5896 -0.3399 0.47 -9.9 85.7 279.8
0.5631 -0.5886 -0.341 0.4691 -9.7 85.7 280.1
0.5644 -0.5876 -0.3419 0.4683 -9.5 85.6 280.3
0.5655 -0.5868 -0.3423 0.4675 -9.3 85.5 280.5
0.5662 -0.5863 -0.3427 0.4671 -9.2 85.5 280.6
0.5667 -0.5858 -0.343 0.4669 -9.1 85.5 280.7
0.567 -0.5856 -0.3434 0.4664 -9 85.5 280.7
0.5676 -0.5856 -0.3439 0.4653 -8.9 85.5 280.9
0.5684 -0.5851 -0.3447 0.4644 -8.7 85.5 281.1
0.5693 -0.5846 -0.345 0.4636 -8.6 85.5 281.3
0.5704 -0.5834 -0.3458 0.4632 -8.4 85.4 281.4
0.5717 -0.5826 -0.3461 0.4625 -8.2 85.3 281.6
0.5732 -0.5812 -0.3469 0.4617 -8 85.1 281.9
0.5752 -0.5797 -0.3479 0.4604 -7.7 85 282.2
0.5772 -0.5784 -0.3492 0.4586 -7.3 85 282.6
0.5792 -0.5768 -0.3508 0.4568 -6.9 84.9 283
0.5812 -0.5751 -0.3524 0.4551 -6.5 84.8 283.4
0.5831 -0.5736 -0.3535 0.4537 -6.2 84.7 283.7
0.5845 -0.5723 -0.3544 0.4529 -6 84.6 284
0.5859 -0.5711 -0.3554 0.4518 -5.7 84.5 284.2
0.587 -0.5703 -0.3563 0.4506 -5.5 84.5 284.5
0.588 -0.5696 -0.3572 0.4495 -5.3 84.5 284.7
0.5887 -0.5688 -0.3583 0.4487 -5.1 84.5 284.9
0.5895 -0.5683 -0.359 0.4478 -4.9 84.5 285.1
0.59 -0.5684 -0.3593 0.4469 -4.8 84.5 285.2
0.59 -0.5682 -0.3599 0.4466 -4.7 84.5 285.2
0.5898 -0.5681 -0.3606 0.4464 -4.7 84.6 285.2
0.5895 -0.5681 -0.3613 0.4462 -4.6 84.6 285.2
0.5895 -0.5685 -0.3615 0.4455 -4.6 84.7 285.3
0.5894 -0.5685 -0.3621 0.4451 -4.5 84.7 285.4
0.5894 -0.5685 -0.3627 0.4448 -4.5 84.8 285.4
0.5891 -0.5684 -0.3633 0.4448 -4.4 84.8 285.4
0.5889 -0.5682 -0.3638 0.4448 -4.4 84.8 285.3
0.5889 -0.5682 -0.364 0.4447 -4.4 84.9 285.4
0.5889 -0.5682 -0.364 0.4445 -4.4 84.9 285.4
0.589 -0.5682 -0.3641 0.4445 -4.4 84.9 285.4
0.5889 -0.5683 -0.3643 0.4443 -4.4 84.9 285.4
0.5886 -0.5685 -0.3646 0.4442 -4.3 84.9 285.4
0.5884 -0.5687 -0.3648 0.444 -4.3 85 285.4
0.5881 -0.5687 -0.3652 0.444 -4.3 85 285.4
0.5881 -0.5689 -0.3653 0.4438 -4.3 85.1 285.4
0.5879 -0.569 -0.3656 0.4437 -4.3 85.1 285.4
0.5878 -0.5691 -0.3658 0.4435 -4.3 85.1 285.4
0.5878 -0.5692 -0.3659 0.4434 -4.3 85.1 285.4
0.5878 -0.5692 -0.366 0.4433 -4.3 85.2 285.4
0.5877 -0.5692 -0.3661 0.4432 -4.3 85.2 285.4
0.5877 -0.5693 -0.3663 0.4431 -4.2 85.2 285.5
0.5876 -0.5693 -0.3663 0.4431 -4.2 85.2 285.4
0.5875 -0.5693 -0.3663 0.4432 -4.3 85.2 285.4
0.5873 -0.5694 -0.3664 0.4433 -4.3 85.2 285.4
0.587 -0.5695 -0.3665 0.4435 -4.3 85.2 285.3
0.587 -0.5695 -0.3663 0.4436 -4.3 85.2 285.3
0.5872 -0.5693 -0.3661 0.4437 -4.3 85.2 285.3
0.5873 -0.5692 -0.3661 0.4438 -4.3 85.2 285.3
0.5873 -0.569 -0.3663 0.4438 -4.3 85.2 285.3
0.5872 -0.569 -0.3668 0.4436 -4.3 85.2 285.3
0.5869 -0.569 -0.3674 0.4435 -4.2 85.3 285.3
0.5865 -0.5692 -0.368 0.4433 -4.2 85.3 285.3
0.5861 -0.5691 -0.3687 0.4433 -4.2 85.4 285.3
0.5859 -0.5692 -0.3688 0.4433 -4.2 85.4 285.3
0.5857 -0.5694 -0.3688 0.4434 -4.2 85.4 285.2
0.5855 -0.5696 -0.3687 0.4435 -4.2 85.4 285.2
0.5854 -0.5697 -0.3686 0.4435 -4.2 85.4 285.2
0.5854 -0.5698 -0.3685 0.4435 -4.2 85.5 285.2
0.5855 -0.5698 -0.3682 0.4435 -4.3 85.4 285.2
0.5859 -0.5696 -0.3679 0.4436 -4.3 85.4 285.2
0.5861 -0.5695 -0.3677 0.4437 -4.3 85.3 285.2
0.5862 -0.5694 -0.3676 0.4437 -4.3 85.3 285.2
0.5863 -0.5693 -0.3675 0.4437 -4.3 85.3 285.2
0.5864 -0.5692 -0.3676 0.4438 -4.3 85.3 285.2
0.5864 -0.5692 -0.3675 0.4439 -4.3 85.3 285.2
0.5863 -0.5692 -0.3675 0.4439 -4.3 85.3 285.2
0.5861 -0.5695 -0.3674 0.444 -4.3 85.3 285.2
0.5859 -0.5697 -0.3674 0.444 -4.3 85.3 285.2
0.5856 -0.5699 -0.3674 0.444 -4.3 85.4 285.1
0.5852 -0.5701 -0.3676 0.4442 -4.4 85.4 285.1
0.585 -0.5703 -0.3675 0.4443 -4.4 85.4 285.1
0.5849 -0.5703 -0.3674 0.4445 -4.4 85.4 285
0.5848 -0.5704 -0.3673 0.4447 -4.4 85.4 285
0.5847 -0.5703 -0.3672 0.4449 -4.5 85.4 285
0.5847 -0.5703 -0.3671 0.4451 -4.5 85.4 284.9
0.5848 -0.5699 -0.367 0.4454 -4.5 85.3 284.9
0.5851 -0.5697 -0.3668 0.4454 -4.5 85.3 284.9
0.5853 -0.5693 -0.3668 0.4456 -4.5 85.2 284.9
0.5856 -0.5692 -0.3667 0.4455 -4.4 85.2 285
0.5858 -0.5691 -0.3668 0.4453 -4.4 85.2 285
0.5861 -0.5692 -0.3669 0.4449 -4.4 85.2 285.1
0.5861 -0.5691 -0.3672 0.4446 -4.3 85.2 285.1
0.5862 -0.569 -0.3675 0.4445 -4.3 85.3 285.2
0.5864 -0.569 -0.3675 0.444 -4.3 85.3 285.2
0.5865 -0.5688 -0.3678 0.4438 -4.2 85.3 285.2
0.5866 -0.5687 -0.3682 0.4436 -4.2 85.3 285.3
0.5869 -0.5684 -0.3687 0.4433 -4.1 85.3 285.3
0.5868 -0.5677 -0.3701 0.4431 -3.9 85.3 285.4
0.5874 -0.5669 -0.3708 0.4427 -3.8 85.3 285.5
0.5883 -0.5656 -0.3716 0.4424 -3.6 85.2 285.6
0.5898 -0.5638 -0.3732 0.4415 -3.3 85.1 285.8
0.5914 -0.5623 -0.3746 0.4401 -3 85 286.1
0.5929 -0.5606 -0.3766 0.4385 -2.6 85 286.5
0.5945 -0.5588 -0.3792 0.4364 -2.1 84.9 286.9
0.5953 -0.5574 -0.3823 0.4343 -1.6 85 287.2
0.5967 -0.5558 -0.3854 0.4318 -1.1 85.1 287.7
0.5983 -0.5544 -0.3878 0.4292 -0.7 85.1 288.1
0.6003 -0.5524 -0.3898 0.427 -0.2 85.1 288.6
0.6021 -0.551 -0.3914 0.425 0.2 85 289
0.6037 -0.5489 -0.3941 0.4229 0.7 85 289.4
0.6055 -0.5466 -0.3972 0.4203 1.2 85 289.9
0.6071 -0.5447 -0.3998 0.4181 1.7 85 290.3
0.6085 -0.5431 -0.4016 0.4164 2.1 85 290.7
0.6113 -0.5402 -0.4052 0.4127 2.8 84.9 291.4
0.6125 -0.5386 -0.4073 0.4106 3.2 84.9 291.7
0.6135 -0.5375 -0.4095 0.4085 3.6 85 292.1
0.6143 -0.5364 -0.412 0.4063 4 85.1 292.5
0.6146 -0.5354 -0.4149 0.4042 4.4 85.3 292.8
0.6152 -0.5342 -0.4174 0.4021 4.8 85.4 293.1
0.616 -0.5333 -0.4193 0.4002 5.2 85.4 293.4
0.6168 -0.5324 -0.4212 0.3983 5.5 85.5 293.7
0.6173 -0.5319 -0.4233 0.3958 5.8 85.6 294.1
0.6177 -0.531 -0.4262 0.3934 6.2 85.8 294.5
0.6182 -0.5303 -0.4286 0.3907 6.6 86 294.9
0.619 -0.5296 -0.4308 0.3881 7 86.1 295.3
0.621 -0.5271 -0.4362 0.3822 8 86.3 296.2
0.6226 -0.5254 -0.4388 0.379 8.5 86.4 296.8
0.6245 -0.5233 -0.4412 0.376 9.1 86.4 297.3
0.6264 -0.5211 -0.4438 0.3728 9.7 86.3 297.9
0.6282 -0.5187 -0.4468 0.3696 10.3 86.4 298.5
0.6301 -0.5165 -0.4497 0.3657 10.9 86.4 299.2
0.632 -0.5143 -0.4528 0.3619 11.6 86.4 299.9
0.6337 -0.5118 -0.4559 0.3585 12.2 86.5 300.5
0.6356 -0.5093 -0.4589 0.3548 12.8 86.5 301.1
0.6373 -0.5069 -0.462 0.3511 13.5 86.5 301.8
0.6387 -0.5044 -0.4656 0.3475 14.2 86.6 302.4
0.6404 -0.502 -0.4689 0.3433 14.9 86.7 303.1
0.6422 -0.4994 -0.4722 0.3392 15.6 86.7 303.8
0.6436 -0.4966 -0.476 0.3354 16.3 86.8 304.5
0.6447 -0.494 -0.4801 0.3312 17 86.9 305.2
0.6456 -0.4913 -0.4844 0.3271 17.8 87.1 305.8
0.6466 -0.4887 -0.4885 0.3231 18.5 87.3 306.5
0.6475 -0.4863 -0.4923 0.3191 19.2 87.4 307.1
0.6483 -0.4835 -0.4962 0.3156 19.9 87.6 307.7
0.6496 -0.4812 -0.4993 0.3117 20.5 87.6 308.3
0.6509 -0.4785 -0.5022 0.3083 21.1 87.7 308.9
0.6522 -0.4759 -0.505 0.3051 21.7 87.7 309.5
0.6533 -0.4737 -0.5076 0.3016 22.3 87.8 310.1
0.6544 -0.4713 -0.5103 0.2985 22.9 87.8 310.6
0.6556 -0.469 -0.5128 0.2954 23.4 87.9 311.1
0.6567 -0.4667 -0.5151 0.2922 24 87.9 311.7
0.6578 -0.4649 -0.5174 0.2887 24.5 88 312.3
0.6587 -0.4629 -0.52 0.2852 25.1 88.1 312.8
0.6597 -0.4609 -0.5225 0.2815 25.7 88.2 313.5
0.6605 -0.4586 -0.5253 0.278 26.2 88.3 314
0.6613 -0.4564 -0.5283 0.2742 26.8 88.4 314.6
0.6621 -0.4542 -0.5312 0.2703 27.5 88.5 315.3
0.663 -0.4518 -0.5341 0.2662 28.1 88.6 316
0.6638 -0.449 -0.5374 0.2624 28.8 88.7 316.6
0.6649 -0.4463 -0.5403 0.2581 29.5 88.8 317.3
0.6661 -0.4436 -0.5432 0.2535 30.2 88.9 318.1
0.6673 -0.4404 -0.5464 0.2491 30.9 89 318.8
0.6686 -0.4375 -0.5492 0.2444 31.6 89.1 319.6
0.6698 -0.4341 -0.5524 0.2401 32.4 89.1 320.3
0.671 -0.4308 -0.5555 0.2357 33.1 89.2 321.1
0.6719 -0.4276 -0.5587 0.2311 33.8 89.3 321.8
0.6728 -0.4247 -0.5618 0.2265 34.6 89.4 322.6
0.6736 -0.4217 -0.5649 0.2221 35.3 89.6 323.3
0.6743 -0.4188 -0.5678 0.2175 36 89.7 324.1
0.6751 -0.416 -0.5707 0.213 36.7 89.8 324.8
0.6758 -0.4131 -0.5737 0.2085 37.3 90 325.5
0.6765 -0.4103 -0.5765 0.204 38 90.1 326.3
0.6771 -0.4074 -0.5793 0.1997 38.7 90.2 327
0.6777 -0.4044 -0.5821 0.1955 39.3 90.3 327.7
0.6785 -0.4013 -0.5846 0.1916 39.9 90.4 328.3
0.6795 -0.3983 -0.5869 0.1876 40.5 90.5 329
0.6805 -0.3954 -0.5888 0.1835 41.1 90.5 329.7
0.6819 -0.3901 -0.593 0.1763 42.2 90.6 330.9
0.6824 -0.3875 -0.5951 0.1729 42.7 90.7 331.5
0.6829 -0.385 -0.597 0.1698 43.2 90.7 332
0.6834 -0.3826 -0.5989 0.1668 43.6 90.8 332.5
0.684 -0.3803 -0.6005 0.1638 44 90.8 333
0.6844 -0.3781 -0.6022 0.1607 44.5 90.9 333.5
0.6849 -0.3759 -0.6039 0.1577 45.3 91 334
0.6855 -0.3738 -0.6052 0.1545 45.8 91 334.5
0.6863 -0.3718 -0.6064 0.1514 46.2 91 335
0.6871 -0.3701 -0.6072 0.1483 46.5 90.9 335.6
0.688 -0.3683 -0.608 0.1451 46.9 90.9 336.1
0.689 -0.3665 -0.6088 0.1421 47.3 90.8 336.6
0.6899 -0.3643 -0.6097 0.1393 47.7 90.8 337.1
0.6909 -0.3624 -0.6105 0.1362 48.1 90.7 337.6
0.6918 -0.3603 -0.6113 0.1334 48.5 90.6 338.1
0.6926 -0.3577 -0.6125 0.1308 48.9 90.5 338.6
0.6934 -0.3555 -0.6135 0.1277 49.3 90.5 339.1
0.6942 -0.3528 -0.6147 0.1252 49.8 90.4 339.5
0.6948 -0.3503 -0.6159 0.1228 50.2 90.4 339.9
0.6957 -0.348 -0.6168 0.1201 50.6 90.3 340.4
0.6967 -0.3455 -0.6175 0.1175 51 90.1 340.8
0.6976 -0.3429 -0.6184 0.1149 51.4 90 341.3
0.6985 -0.3403 -0.6193 0.1121 51.9 89.9 341.7
0.6993 -0.3378 -0.6204 0.1091 52.3 89.8 342.2
0.6998 -0.3353 -0.6216 0.1063 52.8 89.8 342.7
0.7003 -0.3327 -0.6229 0.1031 53.2 89.8 343.2
0.7009 -0.3299 -0.6243 0.1002 53.7 89.7 343.7
0.7015 -0.3269 -0.6257 0.0972 54.2 89.7 344.2
0.7022 -0.3237 -0.627 0.094 54.8 89.6 344.7
0.7031 -0.3206 -0.6282 0.0901 55.4 89.5 345.4
0.7039 -0.3171 -0.6297 0.0862 56 89.4 346
0.7047 -0.3137 -0.631 0.0826 56.6 89.3 346.6
0.7055 -0.3101 -0.6323 0.0792 57.2 89.1 347.2
0.7064 -0.3066 -0.6334 0.0757 57.8 89 347.7
0.7075 -0.3036 -0.6341 0.0721 58.3 88.7 348.3
0.7085 -0.3004 -0.6348 0.0689 58.8 88.5 348.9
0.7095 -0.2973 -0.6354 0.0654 59.4 88.2 349.4
0.7102 -0.2943 -0.6364 0.0618 59.9 88.1 350
0.7106 -0.2913 -0.6378 0.058 60.5 88 350.7
0.7106 -0.2881 -0.6396 0.0541 61.1 88.1 351.3
0.7104 -0.2852 -0.6414 0.0499 61.8 88.2 351.9
0.7105 -0.2821 -0.643 0.0452 62.4 88.3 352.7
0.7107 -0.2784 -0.6447 0.0405 63.1 88.3 353.5
0.711 -0.2746 -0.6463 0.0355 63.9 88.2 354.3
0.7115 -0.2707 -0.6477 0.0305 64.7 88.1 355.1
0.712 -0.2668 -0.649 0.0253 65.4 87.9 355.9
0.7125 -0.2625 -0.6503 0.0204 66.2 87.7 356.7
0.713 -0.2582 -0.6517 0.0156 67 87.5 357.5
0.7134 -0.254 -0.653 0.0104 67.7 87.2 358.3
0.7139 -0.2498 -0.6541 0.0051 68.5 86.9 359.2
0.7143 -0.2455 -0.6553 -0.0002 69.3 86.6 0
0.7146 -0.2411 -0.6566 -0.0058 70.1 86.4 0.9
0.7145 -0.2365 -0.6583 -0.0115 71 86.2 1.8
0.7142 -0.2319 -0.6601 -0.0168 71.9 86.1 2.7
0.7136 -0.228 -0.662 -0.0228 72.7 86.2 3.7
0.7128 -0.2238 -0.6641 -0.0283 73.6 86.4 4.5
0.7121 -0.2195 -0.666 -0.0334 74.4 86.5 5.4
0.7114 -0.2154 -0.6678 -0.0386 75.1 86.6 6.2
0.7106 -0.2115 -0.6696 -0.044 75.9 86.7 7.1
0.7098 -0.2078 -0.6712 -0.0496 76.7 86.8 8
0.7091 -0.2039 -0.6727 -0.0547 77.5 86.9 8.8
0.7085 -0.2 -0.6741 -0.0594 78.2 86.9 9.6
0.7079 -0.1964 -0.6753 -0.064 78.9 86.8 10.3
0.7072 -0.1932 -0.6765 -0.0692 79.6 86.8 11.2
0.7064 -0.1898 -0.6778 -0.0743 80.3 86.9 12
0.7053 -0.1865 -0.6792 -0.0797 81.1 87.2 12.9
0.7043 -0.183 -0.6805 -0.085 81.8 87.3 13.8
0.7035 -0.1793 -0.6818 -0.0899 82.5 87.3 14.6
0.7027 -0.1755 -0.6829 -0.0945 83.2 6.8 15.3
0.7021 -0.1716 -0.6839 -0.0984 83.9 6.1 16
0.7018 -0.168 -0.6846 -0.1022 84.5 5.5 16.6
0.7017 -0.1641 -0.6852 -0.1054 85 4.9 17.1
0.7014 -0.1609 -0.6856 -0.1091 85.6 4.4 17.7
0.7014 -0.1572 -0.6862 -0.1119 86.1 3.8 18.1
0.7012 -0.1539 -0.6866 -0.1148 86.6 3.3 18.6
0.7011 -0.1505 -0.6869 -0.1174 87.1 2.8 19.1
0.7014 -0.1472 -0.687 -0.1201 87.5 2.4 19.5
0.7019 -0.1433 -0.6868 -0.1223 87.9 1.9 19.8
0.7024 -0.1401 -0.6865 -0.1252 88.2 1.4 20.2
0.7028 -0.1368 -0.6863 -0.128 88.5 0.9 20.7
0.7031 -0.1335 -0.6861 -0.1305 88.6 0.5 21.1
0.7035 -0.13 -0.686 -0.1324 88.5 0.1 21.4
0.704 -0.1264 -0.6857 -0.1343 88.4 -0.3 21.6
0.7047 -0.1234 -0.6852 -0.1365 88.1 -0.7 22
0.7054 -0.1202 -0.6846 -0.1385 87.7 -1.1 22.2
0.7061 -0.1172 -0.684 -0.1406 87.4 -1.5 22.6
0.7064 -0.1144 -0.6837 -0.1427 87 -1.9 22.9
0.7067 -0.1115 -0.6835 -0.1443 86.7 -2.3 23.1
0.7068 -0.1086 -0.6835 -0.1462 86.4 -2.6 23.4
0.7067 -0.106 -0.6837 -0.1482 86.1 -3 23.7
0.7064 -0.1036 -0.6838 -0.1506 85.8 -3.4 24.1
0.706 -0.101 -0.684 -0.1532 85.4 -3.8 24.5
0.7056 -0.0981 -0.6842 -0.1558 85 -4.3 25
0.705 -0.0955 -0.6844 -0.1588 84.6 -4.7 25.4
0.7044 -0.0928 -0.6849 -0.1614 84.2 -5.2 25.9
0.7038 -0.09 -0.6852 -0.164 83.8 -5.6 26.3
0.7032 -0.0875 -0.6855 -0.1667 83.4 -6.1 26.7
0.7026 -0.0849 -0.6859 -0.1691 83 -68.3 27.1
0.7018 -0.0828 -0.6862 -0.172 82.6 -69.5 27.6
0.7012 -0.0802 -0.6866 -0.1743 82.3 -70.7 28
0.6997 -0.0751 -0.6876 -0.1787 81.5 -72.9 28.7
0.6989 -0.0729 -0.688 -0.1813 81.1 -73.8 29.2
0.6981 -0.0709 -0.6883 -0.1837 80.8 -74.5 29.6
0.6976 -0.0688 -0.6885 -0.1856 80.5 -75.1 29.9
0.697 -0.0671 -0.6887 -0.1879 80.2 -75.6 30.3
0.6963 -0.0651 -0.689 -0.1902 79.8 -76.1 30.7
0.6956 -0.0631 -0.6892 -0.1926 79.5 -76.7 31.1
0.6949 -0.0608 -0.6895 -0.1946 79.1 -77.2 31.4
0.6941 -0.059 -0.6898 -0.197 78.8 -77.7 31.8
0.6935 -0.0569 -0.6901 -0.1985 78.5 -78.1 32.1
0.6931 -0.0551 -0.6902 -0.2003 78.2 -78.4 32.4
0.6924 -0.0534 -0.6904 -0.2021 77.9 -78.7 32.7
0.6918 -0.0519 -0.6906 -0.2042 77.6 -79 33
0.6912 -0.0506 -0.6908 -0.2061 77.3 -79.3 33.3
0.6905 -0.0496 -0.691 -0.2078 77.1 -79.6 33.6
0.6894 -0.048 -0.6914 -0.2105 76.8 -80.1 34.1
0.6892 -0.0473 -0.6914 -0.2113 76.6 -80.1 34.2
0.6892 -0.0463 -0.6913 -0.2116 76.5 -80.1 34.3
0.6893 -0.0457 -0.6912 -0.212 76.4 -80.1 34.3
0.6894 -0.045 -0.691 -0.2122 76.4 -80 34.3
0.6896 -0.0445 -0.6909 -0.2121 76.3 -79.9 34.3
0.6896 -0.0441 -0.6909 -0.2121 76.3 -79.9 34.3
0.6896 -0.0439 -0.6909 -0.2121 76.3 -79.9 34.3
0.6896 -0.0438 -0.691 -0.2121 76.3 -79.9 34.3
0.6896 -0.0435 -0.691 -0.2121 76.3 -79.9 34.3
0.6897 -0.0434 -0.6909 -0.2122 76.2 -79.9 34.3
0.6899 -0.0433 -0.6907 -0.2122 76.2 -79.8 34.3
0.6901 -0.0433 -0.6905 -0.2122 76.2 -79.6 34.3
0.6902 -0.0433 -0.6904 -0.2122 76.2 -79.5 34.3
0.6903 -0.0433 -0.6903 -0.212 76.2 -79.5 34.3
0.6904 -0.0433 -0.6902 -0.2119 76.3 -79.5 34.3
0.6905 -0.0433 -0.6902 -0.2117 76.3 -79.4 34.2
0.6906 -0.0431 -0.6902 -0.2115 76.3 -79.4 34.2
0.6906 -0.0429 -0.6902 -0.2115 76.3 -79.4 34.2
0.6906 -0.0428 -0.6902 -0.2115 76.2 -79.4 34.2
0.6906 -0.0426 -0.6902 -0.2115 76.2 -79.4 34.2
0.6906 -0.0425 -0.6902 -0.2115 76.2 -79.4 34.2
0.6907 -0.0424 -0.6902 -0.2115 76.2 -79.4 34.2
0.6906 -0.0423 -0.6902 -0.2116 76.2 -79.4 34.2
0.6906 -0.0422 -0.6903 -0.2117 76.2 -79.5 34.2
0.6905 -0.0421 -0.6903 -0.2117 76.2 -79.5 34.2
0.6905 -0.0419 -0.6902 -0.2119 76.1 -79.5 34.3
0.6906 -0.0416 -0.6902 -0.2121 76.1 -79.4 34.3
0.6906 -0.0414 -0.69 -0.2123 76.1 -79.4 34.3
0.6908 -0.0411 -0.6899 -0.2124 76 -79.3 34.3
0.6909 -0.041 -0.6897 -0.2126 76 -79.2 34.3
0.691 -0.0411 -0.6895 -0.2129 76 -79.1 34.4
0.6912 -0.041 -0.6892 -0.2131 76 -78.9 34.4
0.6914 -0.0411 -0.6888 -0.2136 75.9 -78.7 34.5
0.6918 -0.041 -0.6884 -0.214 75.9 -78.3 34.5
0.6923 -0.0408 -0.6877 -0.2144 75.8 -78 34.6
0.6927 -0.0408 -0.6871 -0.2152 75.8 -77.6 34.7
0.6931 -0.0405 -0.6865 -0.2159 75.7 -77.2 34.7
0.6935 -0.0401 -0.6858 -0.2166 75.6 -76.9 34.8
0.6938 -0.04 -0.6853 -0.2173 75.5 -76.6 34.9
0.6942 -0.0395 -0.6849 -0.2177 75.4 -76.4 35
0.6943 -0.0395 -0.6844 -0.2185 75.4 -76.2 35.1
0.6946 -0.0393 -0.6841 -0.2189 75.3 -76 35.1
0.6948 -0.0393 -0.6837 -0.2194 75.3 -75.8 35.2
0.6949 -0.0392 -0.6835 -0.2198 75.2 -75.7 35.3
0.6952 -0.039 -0.6832 -0.2201 75.2 -75.5 35.3
0.6954 -0.0387 -0.6828 -0.2204 75.1 -75.3 35.3
0.6957 -0.0384 -0.6825 -0.2206 75.1 -75.1 35.3
0.6959 -0.0379 -0.6823 -0.2206 75.1 -75.1 35.3
0.6959 -0.0378 -0.6822 -0.2209 75 -75 35.4
0.696 -0.0375 -0.682 -0.2213 75 -74.9 35.4
0.696 -0.0374 -0.6818 -0.2217 74.9 -74.9 35.5
0.6962 -0.0368 -0.6817 -0.2217 74.9 -74.8 35.5
0.6964 -0.0363 -0.6816 -0.2217 74.8 -74.8 35.5
0.6965 -0.0359 -0.6815 -0.2217 74.8 -74.7 35.5
0.6966 -0.0358 -0.6813 -0.2218 74.8 -74.7 35.5
0.6967 -0.0357 -0.6812 -0.2219 74.8 -74.6 35.5
0.6968 -0.0356 -0.6811 -0.2219 74.7 -74.6 35.5
0.6969 -0.0353 -0.6809 -0.2221 74.7 -74.5 35.5
0.6971 -0.035 -0.6807 -0.2222 74.7 -74.3 35.5
0.6972 -0.0351 -0.6805 -0.2225 74.6 -74.2 35.6
0.6973 -0.035 -0.6804 -0.2225 74.6 -74.2 35.5
0.6974 -0.0351 -0.6803 -0.2225 74.7 -74.1 35.5
0.6974 -0.0351 -0.6802 -0.2225 74.7 -74.1 35.5
0.6975 -0.0351 -0.6802 -0.2224 74.7 -74.1 35.5
0.6976 -0.035 -0.6801 -0.2224 74.6 -74 35.5
0.6978 -0.0349 -0.68 -0.2224 74.6 -73.9 35.5
0.6979 -0.0347 -0.6799 -0.2224 74.6 -73.9 35.5
0.698 -0.0345 -0.6797 -0.2224 74.6 -73.8 35.5
0.6981 -0.0344 -0.6797 -0.2225 74.6 -73.8 35.5
0.6981 -0.0343 -0.6796 -0.2225 74.6 -73.8 35.5
0.6981 -0.0343 -0.6796 -0.2225 74.6 -73.7 35.5
0.6982 -0.0347 -0.6795 -0.2223 74.6 -73.7 35.5
0.6984 -0.0347 -0.6794 -0.2223 74.6 -73.6 35.5
0.6985 -0.0349 -0.6793 -0.2223 74.6 -73.5 35.5
0.6986 -0.0349 -0.6791 -0.2223 74.6 -73.4 35.5
0.6987 -0.0349 -0.6791 -0.2222 74.6 -73.4 35.4
0.6987 -0.0352 -0.6791 -0.2219 74.7 -73.4 35.4
0.6988 -0.0352 -0.6791 -0.2219 74.7 -73.3 35.4
0.6988 -0.0352 -0.679 -0.2219 74.7 -73.3 35.4
0.6989 -0.0352 -0.679 -0.2219 74.7 -73.3 35.4
0.6989 -0.0351 -0.6789 -0.2219 74.7 -73.2 35.4
0.6989 -0.0351 -0.679 -0.2219 74.7 -73.2 35.4
0.6989 -0.0352 -0.6789 -0.2219 74.7 -73.2 35.4
0.699 -0.0352 -0.6788 -0.2219 74.7 -73.2 35.4
0.6992 -0.0351 -0.6787 -0.2219 74.7 -73.1 35.4
0.6992 -0.0351 -0.6786 -0.2219 74.7 -73.1 35.4
0.6993 -0.035 -0.6785 -0.222 74.7 -73 35.4
0.6995 -0.035 -0.6783 -0.2222 74.6 -72.9 35.4
0.6996 -0.0349 -0.6781 -0.2224 74.6 -72.8 35.4
0.6997 -0.0349 -0.678 -0.2224 74.6 -72.7 35.4
0.6998 -0.0349 -0.6779 -0.2225 74.6 -72.7 35.4
0.6998 -0.0349 -0.6777 -0.2227 74.6 -72.6 35.4
0.7 -0.035 -0.6776 -0.2227 74.6 -72.5 35.5
0.7001 -0.035 -0.6774 -0.2228 74.6 -72.4 35.5
0.7003 -0.035 -0.6771 -0.2231 74.5 -72.3 35.5
0.7005 -0.0349 -0.6768 -0.2233 74.5 -72.1 35.5
0.7007 -0.0349 -0.6765 -0.2236 74.5 -72 35.6
0.7009 -0.0349 -0.6761 -0.2241 74.4 -71.8 35.6
0.7011 -0.0348 -0.6758 -0.2245 74.4 -71.6 35.7
0.7013 -0.0347 -0.6755 -0.225 74.3 -71.5 35.7
0.7015 -0.0346 -0.6752 -0.2253 74.3 -71.3 35.8
0.7017 -0.0347 -0.6748 -0.2258 74.2 -71.2 35.8
0.7018 -0.0347 -0.6746 -0.2261 74.2 -71.1 35.9
0.702 -0.0346 -0.6744 -0.2261 74.2 -71 35.9
0.7021 -0.0345 -0.6743 -0.2262 74.2 -70.9 35.9
0.7023 -0.0345 -0.6741 -0.2262 74.2 -70.8 35.9
0.7025 -0.0345 -0.6738 -0.2263 74.2 -70.7 35.9
0.7026 -0.0344 -0.6736 -0.2263 74.2 -70.6 35.9
0.7028 -0.0344 -0.6735 -0.2264 74.1 -70.5 35.9
0.703 -0.0341 -0.6733 -0.2264 74.1 -70.4 35.9
0.7031 -0.034 -0.6731 -0.2265 74.1 -70.3 35.9
0.7032 -0.0339 -0.673 -0.2266 74.1 -70.3 35.9
0.7032 -0.034 -0.673 -0.2266 74.1 -70.2 35.9
0.7032 -0.034 -0.6729 -0.2266 74.1 -70.2 35.9
0.7033 -0.0339 -0.6729 -0.2267 74.1 -70.2 35.9
0.7033 -0.0338 -0.6729 -0.2267 74.1 -70.2 35.9
0.7034 -0.0336 -0.6728 -0.2267 74 -70.2 35.9
0.7034 -0.0335 -0.6727 -0.2269 74 -70.2 35.9
0.7034 -0.0333 -0.6727 -0.2268 74 -70.1 35.9
0.7035 -0.0333 -0.6727 -0.2267 74 -70.1 35.9
0.7036 -0.0332 -0.6727 -0.2265 74 -70.1 35.8
0.7037 -0.0333 -0.6726 -0.2263 74 -70.1 35.8
0.7037 -0.0333 -0.6727 -0.2261 74.1 -70.1 35.8
0.7037 -0.0334 -0.6727 -0.2258 74.1 -70 35.7
0.7037 -0.0335 -0.6728 -0.2256 74.1 -70.1 35.7
0.7037 -0.0336 -0.6729 -0.2255 74.1 -70.1 35.7
0.7037 -0.0336 -0.6729 -0.2253 74.2 -70.1 35.7
0.7037 -0.0336 -0.673 -0.2251 74.2 -70.1 35.6
0.7037 -0.0334 -0.6732 -0.2247 74.2 -70.2 35.6
0.7037 -0.0333 -0.6732 -0.2246 74.2 -70.2 35.6
0.7037 -0.0332 -0.6732 -0.2245 74.2 -70.2 35.6
0.7038 -0.0331 -0.6731 -0.2245 74.2 -70.2 35.6
0.7038 -0.0329 -0.6731 -0.2245 74.2 -70.2 35.6
0.7038 -0.0327 -0.6731 -0.2245 74.1 -70.2 35.6
0.7039 -0.0322 -0.673 -0.2246 74.1 -70.2 35.5
0.704 -0.0317 -0.6728 -0.2251 74 -70.2 35.6
0.704 -0.0315 -0.6727 -0.2253 74 -70.2 35.7
0.704 -0.0311 -0.6727 -0.2255 73.9 -70.2 35.7
0.704 -0.0309 -0.6726 -0.2258 73.9 -70.2 35.7
0.704 -0.0306 -0.6724 -0.226 73.8 -70.1 35.7
0.7042 -0.0301 -0.6722 -0.2264 73.8 -70 35.8
0.7046 -0.0295 -0.6717 -0.2269 73.7 -69.9 35.9
0.7049 -0.0292 -0.6711 -0.2277 73.6 -69.6 36
0.7053 -0.029 -0.6704 -0.2285 73.5 -69.4 36.1
0.7057 -0.0287 -0.6697 -0.2292 73.4 -69.1 36.1
0.7061 -0.0285 -0.6692 -0.2297 73.3 -68.9 36.2
0.7062 -0.0285 -0.6688 -0.2303 73.2 -68.7 36.3
0.7064 -0.0281 -0.6686 -0.2306 73.2 -68.6 36.3
0.7066 -0.0276 -0.6683 -0.2307 73.1 -68.5 36.3
0.7068 -0.0273 -0.668 -0.2311 73 -68.4 36.4
0.707 -0.0268 -0.6674 -0.2324 72.9 -68.3 36.6
0.707 -0.0266 -0.6672 -0.2328 72.8 -68.2 36.6
0.7072 -0.0262 -0.6669 -0.233 72.8 -68.2 36.7
0.7073 -0.0259 -0.6666 -0.2336 72.7 -68.1 36.7
0.7073 -0.026 -0.6663 -0.2345 72.6 -68 36.9
0.7073 -0.0258 -0.666 -0.2353 72.5 -67.9 37
0.7072 -0.0255 -0.6658 -0.2363 72.4 -68 37.1
0.707 -0.0253 -0.6656 -0.2374 72.3 -68 37.3
0.7069 -0.0248 -0.6655 -0.2382 72.2 -68 37.4
0.7068 -0.0245 -0.6653 -0.239 72.1 -68 37.5
0.7068 -0.024 -0.665 -0.2397 72 -68 37.7
0.7067 -0.0236 -0.6648 -0.241 71.9 -68 37.8
0.7064 -0.0233 -0.6646 -0.2422 71.8 -68.1 38
0.7062 -0.0229 -0.6643 -0.2435 71.6 -68.1 38.2
0.7063 -0.0221 -0.6641 -0.2441 71.5 -68.1 38.3
0.7062 -0.0217 -0.6639 -0.2449 71.4 -68.1 38.4
0.7062 -0.0214 -0.6637 -0.2453 71.4 -68.1 38.5
0.7063 -0.0211 -0.6635 -0.2455 71.3 -68 38.5
0.7064 -0.021 -0.6634 -0.2457 71.3 -68 38.6
0.7065 -0.0209 -0.6633 -0.2458 71.3 -68 38.6
0.7065 -0.0209 -0.6632 -0.2458 71.3 -67.9 38.6
0.7066 -0.0212 -0.6632 -0.2456 71.3 -67.9 38.5
0.7067 -0.0214 -0.6632 -0.2454 71.3 -67.9 38.5
0.7066 -0.0214 -0.6633 -0.2453 71.3 -67.9 38.5
0.7065 -0.0214 -0.6634 -0.2452 71.4 -67.9 38.5
0.7065 -0.0215 -0.6635 -0.2451 71.4 -68 38.5
0.7064 -0.0216 -0.6636 -0.245 71.4 -68 38.4
0.7064 -0.0217 -0.6638 -0.2448 71.4 -68 38.4
0.7062 -0.0217 -0.664 -0.2444 71.5 -68.1 38.4
0.7061 -0.0219 -0.6642 -0.2443 71.5 -68.2 38.4
0.7059 -0.022 -0.6645 -0.2438 71.5 -68.3 38.3
0.7059 -0.022 -0.6649 -0.2432 71.6 -68.4 38.2
0.7057 -0.0221 -0.6653 -0.2424 71.7 -68.5 38.1
0.7056 -0.0221 -0.6657 -0.2414 71.8 -68.7 38
0.7056 -0.0221 -0.6662 -0.2402 71.9 -68.8 37.8
0.7056 -0.0223 -0.6667 -0.239 72 -68.9 37.6
0.7055 -0.0228 -0.6672 -0.2375 72.2 -69 37.4
0.7054 -0.0237 -0.6678 -0.236 72.4 -69.1 37.2
0.7057 -0.0243 -0.6683 -0.2336 72.6 -69.1 36.8
0.7062 -0.0253 -0.6687 -0.2311 72.9 -69 36.4
0.7067 -0.0266 -0.669 -0.2284 73.2 -68.8 36
0.7076 -0.0284 -0.669 -0.2254 73.6 -68.3 35.5
0.7087 -0.0305 -0.6689 -0.2217 74.1 -67.7 34.9
0.71 -0.0328 -0.6688 -0.2177 74.5 -67 34.2
0.7112 -0.0356 -0.6687 -0.2135 75.1 -66.1 33.5
0.7126 -0.0388 -0.6685 -0.209 75.7 -65.1 32.8
0.7139 -0.0424 -0.6683 -0.2045 76.3 -64 32.1
0.7151 -0.046 -0.6681 -0.1999 76.9 -62.7 31.3
0.7163 -0.0497 -0.668 -0.1954 77.5 -61.4 30.6
0.7173 -0.0534 -0.6678 -0.191 78.1 -59.9 29.9
0.7184 -0.0571 -0.6677 -0.1866 78.7 -58.4 29.2
0.7194 -0.0607 -0.6675 -0.182 79.3 -56.6 28.5
0.7203 -0.0645 -0.6672 -0.1778 79.8 -54.7 27.8
0.7213 -0.0682 -0.6671 -0.1733 80.4 -52.6 27.1
0.722 -0.0723 -0.667 -0.1688 81 -50.3 26.4
0.7227 -0.0764 -0.6671 -0.164 81.6 -47.8 25.6
0.7234 -0.0803 -0.667 -0.1586 82.2 -44.3 24.8
0.7243 -0.0847 -0.6667 -0.1535 82.7 -40.5 24
0.7252 -0.0892 -0.6664 -0.1484 83.2 -3.9 23.2
0.726 -0.0939 -0.6661 -0.143 83.7 -3.1 22.3
0.7264 -0.0994 -0.6658 -0.1379 84.2 -2.3 21.5
0.7269 -0.105 -0.6655 -0.1327 84.5 -1.4 20.7
0.7272 -0.1108 -0.6653 -0.1271 84.8 -0.5 19.9
0.7275 -0.1169 -0.6649 -0.1216 84.9 0.5 19
0.7278 -0.1226 -0.6646 -0.116 84.8 1.4 18.1
0.7279 -0.1281 -0.6644 -0.1104 84.6 2.3 17.3
0.7279 -0.1337 -0.6642 -0.1048 84.3 3.2 16.4
0.7278 -0.1398 -0.6638 -0.0999 83.9 4.1 15.7
0.7277 -0.1457 -0.6635 -0.095 83.4 4.9 14.9
0.7274 -0.1515 -0.6631 -0.0899 82.8 53.3 14.1
0.7271 -0.1572 -0.6628 -0.0847 82.1 58 13.3
0.7266 -0.1633 -0.6625 -0.0798 81.4 62.1 12.5
0.7261 -0.1693 -0.662 -0.0748 80.7 65.7 11.8
0.7257 -0.1754 -0.6616 -0.0696 79.9 68.6 11
0.7254 -0.1814 -0.6608 -0.0647 79.1 71 10.2
0.7251 -0.1876 -0.6598 -0.0599 78.3 73 9.4
0.7248 -0.1938 -0.6588 -0.0552 77.5 74.7 8.7
0.7244 -0.2001 -0.6577 -0.0508 76.7 76.1 8
0.724 -0.2063 -0.6566 -0.0463 75.8 77.5 7.3
0.7234 -0.2127 -0.6554 -0.0417 75 78.7 6.6
0.7228 -0.2189 -0.6544 -0.0367 74.1 79.9 5.8
0.7223 -0.2247 -0.6533 -0.0309 73.2 80.9 4.9
0.722 -0.2309 -0.6516 -0.0255 72.2 81.6 4
0.7221 -0.2369 -0.6495 -0.0195 71.2 82.1 3.1
0.7223 -0.243 -0.6473 -0.0132 70.2 82.5 2.1
0.7225 -0.2488 -0.6448 -0.0065 69.1 82.8 1
0.7227 -0.2552 -0.6422 0.0001 68 83.1 360
0.7228 -0.262 -0.6394 0.0069 66.9 83.4 358.9
0.7226 -0.2692 -0.6365 0.0135 65.7 83.7 357.8
0.7221 -0.2768 -0.6336 0.0203 64.5 84.1 356.8
0.7213 -0.2845 -0.6309 0.0275 63.2 84.6 355.6
0.7202 -0.2924 -0.6281 0.0353 61.9 85.1 354.4
0.7191 -0.3004 -0.6251 0.0435 60.5 85.5 353.1
0.7178 -0.309 -0.6217 0.0515 59.1 85.9 351.8
0.7166 -0.3176 -0.6181 0.0599 57.7 86.3 350.4
0.715 -0.3263 -0.6144 0.0682 56.3 86.7 349.1
0.7132 -0.3349 -0.6109 0.0768 54.8 87.1 347.7
0.7111 -0.3436 -0.6072 0.0855 53.3 87.5 346.3
0.7089 -0.3522 -0.6036 0.0947 51.9 87.8 344.7
0.7065 -0.3611 -0.5997 0.1037 50.4 88.2 343.3
0.7039 -0.3699 -0.5956 0.113 48.9 88.5 341.7
0.7012 -0.3787 -0.5914 0.1224 47.4 88.9 340.1
0.6987 -0.3874 -0.5868 0.1316 46 89.1 338.6
0.6964 -0.3956 -0.582 0.1405 44.2 89.2 337.1
0.6942 -0.4031 -0.5771 0.1497 42.9 89.3 335.6
0.6917 -0.4103 -0.5727 0.1587 41.5 89.4 334.1
0.6889 -0.4173 -0.5685 0.1671 40.2 89.6 332.6
0.6858 -0.4242 -0.5647 0.1754 38.9 89.8 331.2
0.6825 -0.4308 -0.5612 0.1834 37.7 90.1 329.8
0.6792 -0.4367 -0.5579 0.1916 36.5 90.3 328.4
0.6757 -0.4427 -0.5544 0.1998 35.2 90.5 326.9
0.6719 -0.4489 -0.5511 0.2079 33.9 90.7 325.4
0.6679 -0.4551 -0.5475 0.2166 32.6 90.9 323.9
0.6639 -0.4611 -0.5437 0.2256 31.2 91.1 322.3
0.6602 -0.4672 -0.5392 0.2347 29.8 91.2 320.6
0.6564 -0.4732 -0.5347 0.2431 28.4 91.3 319.1
0.6528 -0.4795 -0.5298 0.2512 27 91.4 317.6
0.6497 -0.4854 -0.5244 0.2593 25.6 91.3 316.2
0.6464 -0.491 -0.5191 0.2673 24.3 91.3 314.8
0.643 -0.4965 -0.514 0.2751 23 91.3 313.3
0.6397 -0.5017 -0.5089 0.2828 21.7 91.3 312
0.6366 -0.5066 -0.5038 0.29 20.4 91.3 310.6
0.6335 -0.511 -0.4992 0.297 19.3 91.3 309.4
0.6301 -0.5151 -0.4951 0.304 18.2 91.3 308.1
0.627 -0.5195 -0.4906 0.3101 17.1 91.3 306.9
0.6237 -0.5237 -0.4863 0.3162 16 91.3 305.8
0.6207 -0.5282 -0.4817 0.3219 15 91.3 304.7
0.6176 -0.5323 -0.4771 0.3278 13.9 91.3 303.6
0.6147 -0.5365 -0.4724 0.3333 12.9 91.3 302.6
0.6119 -0.5406 -0.4677 0.3386 11.9 91.3 301.6
0.609 -0.5445 -0.463 0.3438 10.9 91.3 300.6
0.6063 -0.5485 -0.4579 0.3488 10 91.2 299.7
0.6033 -0.5522 -0.4532 0.3543 9 91.2 298.6
Hi hjoungjoo,
1.As you would like to design a product, suggest you use BHI260AP.
2.You need to calibrate accel, gyro and mag until the calibration accuracy reaches 3, and then do the test.
2.As you used geomanetic sensor AK09915 in your product, besides the physical sensor calibration states it is also possible to write a soft iron calibration(SIC) matrix and read BSX version information.
> We still have a lot of BHI260AB left. I plan to use and change the quantity I purchased before.
> The same problem occurs when calibration accuracy 3 are present.
> I'm also reviewing this part and developing it.
Hi hjoungjoo,
How is the current situation?
