    BHI260AP+BMM150 extremely high consumption 20mA
    harry4951
    Hi, I am using SPI between my MCU and BHI260AP. Once I disabled the BHI260AP init function, the total consumption of the PCB was 2.39mA, but if I enabled the BHI260AP, the total consumption became 22.31mA. I just enabled  BHY2_SENSOR_ID_RV, what is wrong?
    A snippet of the key code:
    rslt = bhy2_set_virt_sensor_cfg(QUAT_SENSOR_ID, sample_rate, report_latency_ms, &bhy2);
    print_api_error(rslt, &bhy2);
    printf("Enable %s at %.2fHz.\r\n", get_sensor_name(QUAT_SENSOR_ID), sample_rate);
    //---------------------------------Enable QUAT End------------------------------
    // Nordic specific code to enable GPIOTE
    hintr_ctrl = BHY2_ICTL_DISABLE_STATUS_FIFO | BHY2_ICTL_DISABLE_DEBUG | BHY2_ICTL_ACTIVE_LOW | BHY2_ICTL_EDGE; // re-enable interrupts. Page 121 datasheet
    rslt = bhy2_set_host_interrupt_ctrl(hintr_ctrl, &bhy2);
    /CJ
    harry4951
    ok, fixed by myself. Updated the BHI260AP_BMM150.fw.h from v2.7.0 to BHI260AP_aux_BMM150.fw.h v2.8.8 fixed it.
