    BHI260AP Vertical Mounting
    soroush
    We are performing some tests on the BHI260AP shuttle board and driving it using the provided driver on GitHub repo on our custom MCU board: https://github.com/BoschSensortec/BHY2-Sensor-API
    In our application we require to mount the sensor vertically; however, using the available remapping function for physical acc/gyro sensors as follows:
    orient_matrix.c[0] = 0; orient_matrix.c[1] = -1; orient_matrix.c[2] = 0;
    orient_matrix.c[3] = 0; orient_matrix.c[4] = 0; orient_matrix.c[5] = -1;
    orient_matrix.c[6] = 1; orient_matrix.c[7] = 0; orient_matrix.c[8] = 0;
    rslt += bhy2_set_orientation_matrix(1, orient_matrix, &bhy2);
    rslt += bhy2_set_orientation_matrix(3, orient_matrix, &bhy2);
    leads to incorrect values for virtual sensors: BHY2_SENSOR_ID_ACCBHY2_SENSOR_ID_GYRO, and BHY2_SENSOR_ID_GAMERV. It passes those two functions without error though.
    Mounting the sensor in either of the 8 orientations shown in Figure 35 of the datasheet provides expected values.  Hence, I was wondering if our vertical axes remapping was wrong or if vertical mounting is not possible with this sensor at all !!!!
    soroush
    Update:
    Thanks to the BoschSensortec developer team for consideration, this problem has been resolved in the latest version of the API (1.4.1)
