    BHI260AP Virtual sensor problem
    ArneV
    I'm trying the BHI260AB/BHA260AB SDK Quick Start Guide. Everything works except for the Virtual Altitude.
    When building the firmware I get this error:
    .../arc_gnu/bin/../lib/gcc/arc-snps-elf/12.2.1/../../../../arc-snps-elf/bin/ld.exe: c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/12.2.1/../../../../arc-snps-elf/lib/em4_fpus\libnosys.a(sbrk.o): in function `_sbrk':
    sbrk.c:(.text._sbrk+0x10): undefined reference to `end'
    .../arc_gnu/bin/../lib/gcc/arc-snps-elf/12.2.1/../../../../arc-snps-elf/bin/ld.exe: sbrk.c:(.text._sbrk+0x10): undefined reference to `end'
    [202/208] Linking C executable user\user-flash-5c6
    ninja: build stopped: subcommand failed.
    Error running cmake build
    What is causing this error and what can I do  to make it work?
    Thanks in advance.
    Hi ArneV,
    What is SDK version you used?
    Are you compiling the original SDK or the modified SDK?
