    BMA253 INT1/INT2 Output Characteristics
    Coleman
    Can you please tell me the INT1/INT2 Output Characteristics of BMA253?
    I looked through the datasheet but could not find the information in the datasheet.
    How much does the INT1/INT2 Output pin sink current when the output is set to Low '0'.
    I have the below situation:
    BMA253 is communicating with a master device by I2C.
    I2C bus is connected and pulled-up by 10kohm.
    BMA253 INT1 is connected to the master device GPIO and the Input pin is pulled-up internally with 25kohm resistor. (By mistake I have set the pin to Input pull-up)
    BMA253 INT2 is connected to the master device GPIO and the Input pin is pulled-down internally with 25kohm resistor.
    BMA253 INT1 and INT2 is active '1'
    So normally when the interrupt doesn't occur the INT1/INT2 output is set to Low '0'.
    6 REPLIES 6
    Hello Coleman,
    Which function do you map to INT1?
    Hello BSTRobin,
    I map the orient detection and low-g detection to INT1.
