    BMA253 Single tap
    BMA253 Single tap
    mgchoi
    Hi, BOSCH
    Use the current BMA253
    I would like to use the function to wake up the MCU when an interrupt occurs using Single Tap.
    Is this possible or what Resister should I use?
    9 REPLIES 9
    FAE_CA1
    BMA253 is not available for new designs. Please switch to BMA400. BMA400 has built-in auto wake-up and auto low-power interrupt feature.
    Please see the attached PDF files for more information.
    Hi, BOSCH
    I set it up in the way you sent me during the test with DD, but there is no interrupt.
    What kind of setting is needed for this part?
    FAE_CA1
    Please increase the bandwidth to 1KHz instead of 125Hz as shown in the technical document. Then you should be able to see the single-tap interrupt signal on INT1 pin.
    Interrupt does not occur even if set to 1KHz.
