I program an application, where the BMA is in low power mode, till an threshold is reached. After that, the BMA should read acceleration values, as long, as the interrupt is . The interrupt is only triggered once, when passing the ., so i thought, i read the GEN1triggeredthreshold status-bit and as long at it is set, i read the acceleration data. But the bit is only set to 1 and not reset. Any suggestions ?
Here my configuration:
//Auto-lowpower relative
setRawRegisterValue(AUTOLOWPOW_1_REG_ADDR, 0b00000010); //Configure Auto low Power when still standing
//Generic interrupt 1 (gen1) relative
setRawRegisterValue(GEN1INT_CONFIG0_REG_ADDR, 0b11111000); //Interrupt Condition: all axes, 100 Hz, auto update, hyst disable
setRawRegisterValue(GEN1INT_CONFIG1_REG_ADDR, 0b00000001); //Interrupt Condition: all axes must be under the threshold
setRawRegisterValue(GEN1INT_CONFIG2_REG_ADDR, 0b00000101); //Interrupt Condition: Set treshold to 5*8mg/lsb = 40mg
setRawRegisterValue(GEN1INT_CONFIG3_REG_ADDR, 0b00000000); //Interrupt Condition: Monitor Duration Cofig3*256+gonfig31 = 100 Samples
setRawRegisterValue(GEN1INT_CONFIG31_REG_ADDR, 0b01100100); //Interrupt Condition: Monitor Duration 100 sample /100Hz = 1s
//Auto-wakeup relative
setRawRegisterValue(AUTOWAKEUP_1_REG_ADDR, 0b00000010); //Configure Auto wakeup to switch from lowpower to normal mode
//Wakeup interrupt relative
setRawRegisterValue(WKUP_INT_CONFIG0_REG_ADDR, 0b11101110); // Interrupt Condition: all Axis; 3/4 Samples; auto update
setRawRegisterValue(WKUP_INT_CONFIG1_REG_ADDR, 0b00000011); // Interrupt Condition: Wakeup threshold 94 mg @4g range
setRawRegisterValue(AUTOLOWPOW_1_REG_ADDR, 0b00000010); //Configure Auto wakeup to switch from lowpower to normal mode
//HW Interrupt
setRawRegisterValue(INT_CONFIG0_REG_ADDR, 0b00000100); //Enable Gen1 Interrupt
setRawRegisterValue(INT1_MAP_REG_ADDR, 0b00000100); //Map Interrupts to Pin1 (Gen1 Interrupt)
//setRawRegisterValue(INT1_MAP_REG_ADDR, 0b00000101); //Map Interrupts to Pin (Gen1 + Wake Up Interrupt)
setRawRegisterValue(INT2_MAP_REG_ADDR, 0b00000001); //Map Interrupts to Pin2 (Wake Up Interrupt)
setRawRegisterValue(INT12_IO_CTRL_REG_ADDR, 0b00100010); //Configure Interrupt Behavior
Here the function that checks the status register for bit 3 set:
bool BMA400_Gen1_Intr_status(){
int value =getRawRegisterValue(INT_STAT0_REG_ADDR, 1);
if(value&0x04){
return true;
}else{
return false;
Hello Jones,
I'm little confused about your code because you are using your own definition.
But, generally you set wake-up threshold and always get INT_STATUS_0 value as 1.
I think because you enable x,y,z all axes and threshold is 90mg.
If BMA400 is on your board, X value should be 1g. Therefore, it is over 90mg.
That's why you already get wake-up interrupt, and never reset.
Simply, please test after disable x and only enable y,z. You could get the right result what you want 🙂
Oh then I'm confused.
Because as you can see, I mappped the interrupts to the interrupt-pins. My microcontroller, only gehts triggerd when i shake the bma.
Isn't the 90mg change ? So when there is 90mg change in 1 seconde for example ?
Thanks allready for your help.
Jones
Hello Jones,
I don't understand your reply fully.
I mean you enable x,y,z all axes and your threshold is 90mg.
Let's say if BMA400 is on your board. Z value should be around 1G right? ( Reversely -1 G)
Therefore, Z value is always over your threshold for your wake up threshold, so can't be reset.
To be specific, even though you reset mandatory, it will be set again right after.
