    BMA400 Step Counter Application
    ekmekci
    Re: BMA400 Step Counter Application
    Dear  o_O,
    Thank you for your fast reply.
    Your answer about step_counter and step_detector is acceptable. I will try to explain event i will do step less than 10 what will be condition step_counter and step_detector interrupt count.
    I need help about other questions,
    Which datasheet parameters is valid for step_counter register (July2018 or July2019).
    Also, i need help about understanding OSR,ODR, acc_filter_1,acc_filter_2 (which value will effect accuracy)
    Best regards,
    ekmekci
    Update,
    I am still waiting your valuable reply.
    ekmekci
    Also, i am trying to measure Still, walk and run time.
    So i need to catch transition from one to another.
    I tried actch_int for catching, it is working as a axis interrupt. When ever i shake sensor it gives interrupt.
    Is it possible to measure still, walk and run time ?
    Is it possible to adapt INT stat to actch_int ?
    BEst regards
    ekmekci
    Reminder...
    Vincent
    Please always use the lastest datasheet version which contains the latest parameters we set as default value.
    You can follow latest datasheet to change the parameters to see if it can meet your requirement
