    BMA400 activity changed interrupt
    td-filip
    I use BMA400 accelerometer's activity changed interrupt feature for my purposes. I have a question if it is possible to read out value named "last value" used in algorithm in activity changed interrupt section of BMA400's datasheet.
    Thanks in advance
    Filip
    krzysiek_tdp
    Just one note: if required, we are willing to sign an NDA to acquire this information. The 'last value' will be useful in easily determining whether the acceleration is increasing or decreasing.
    Kind Regards,
    Krzysztof
    Hi td-filip,
    Do you mean you would like to obtain sensor data at the time of activity change interruption?
    We would like to acquire value of `last value` register (if available), in theory we could download FIFO contents and make some computation on it, however solution will be way simpler and will have better energy efficiency if we take single value from the accelerometer.
    Hello BSTRobin,
    As krzysiek_tdp wrote, we would like to read value called "last value" mentioned in BMA400's datasheet in section "Activity changed interrupt" if it is possible.
    Also, I would like to ask if I understand steps of activity changed interrupt correctly. Is "Update / store the activity parameters: curr_value => last_value" step executed every observation period or is last_value updated only after detecting an activity change?
    Regards
    Filip
