    BMA400 autowakeup and inactivity interrupts
    msybl
    Occasional Visitor
    Introduction about BMA400 Auto Wakeup and Auto Low Power
    By following the above guide I tried to configure BMA400 to generate two interrupts:
    • Autowakeup
    • Gen1 - inactivity
    Both of the interrupts work alone. However, when I try to enable both, only the last configured interrupt works.
    case 1:
    • Autowakeup
    • Gen1 - inactivity ->Only this works
    case 2:
    • Gen1 - inactivity
    • Autowakeup -> Only this works
    Here is the code:
    #define NUMBER_OF_DEVICE_CONFIG 2
    uint8_t power_mode;
    struct bma400_device_conf conf[NUMBER_OF_DEVICE_CONFIG];
    /* Interrupt configuration structure */
    struct bma400_int_enable int_en;
    /* Selecting auto wakeup on wakeup interrupt event */
    conf[0].type = BMA400_AUTOWAKEUP_INT;
    /* Selecting auto low power mode*/
    conf[1].type = BMA400_AUTO_LOW_POWER;
    /* Get the previously set settings */
    _rslt = bma400_get_device_conf(conf, NUMBER_OF_DEVICE_CONFIG, &_bma);
    print_rslt(_rslt);
    conf[0].param.wakeup.wakeup_ref_update = BMA400_EVERY_TIME_UPDATE;
    conf[0].param.wakeup.sample_count = BMA400_SAMPLE_COUNT_2;
    conf[0].param.wakeup.wakeup_axes_en = BMA400_XYZ_AXIS_EN;
    conf[0].param.wakeup.int_wkup_threshold = 3;
    conf[0].param.wakeup.int_chan = BMA400_INT_CHANNEL_1;
    /* Enable auto low power on Gen1 trigger */
    conf[1].param.auto_lp.auto_low_power_trigger = BMA400_AUTO_LP_GEN1_TRIGGER;
    /* Set the configurations in sensor */
    _rslt = bma400_set_device_conf(conf, NUMBER_OF_DEVICE_CONFIG, &_bma);
    print_rslt(_rslt);
    #define NUMBER_OF_SENSOR_CONFIG 2
    struct bma400_sensor_conf conf[NUMBER_OF_SENSOR_CONFIG];
    /* Select the type of configuration to be modified */
    conf[0].type = BMA400_ACCEL;
    conf[1].type = BMA400_GEN1_INT;
    /* Get the accelerometer configurations which are set in the sensor */
    _rslt = bma400_get_sensor_conf(conf, NUMBER_OF_SENSOR_CONFIG, &_bma);
    print_rslt(_rslt);
    /* Modify the desired configurations as per macros
    * available in bma400_defs.h file */
    // conf[0].param.accel.odr = BMA400_ODR_100HZ;
    conf[0].param.accel.range = BMA400_4G_RANGE;
    conf[0].param.accel.data_src=BMA400_DATA_SRC_ACCEL_FILT_1;
    conf[0].param.accel.filt1_bw = BMA400_ACCEL_FILT1_BW_1;
    // inactivity
    conf[1].param.gen_int.gen_int_thres = 3; // x 8mg
    conf[1].param.gen_int.gen_int_dur = 100; // x ODR
    conf[1].param.gen_int.axes_sel = BMA400_XYZ_AXIS_EN;
    conf[1].param.gen_int.data_src=BMA400_DATA_SRC_ACC_FILT2;
    conf[1].param.gen_int.criterion_sel = BMA400_INACTIVITY_INT;
    conf[1].param.gen_int.evaluate_axes = BMA400_ALL_AXES_INT;
    conf[1].param.gen_int.ref_update = BMA400_EVERY_TIME_UPDATE;
    conf[1].param.gen_int.hysteresis = BMA400_HYST_0_MG;
    conf[1].param.gen_int.int_chan = BMA400_INT_CHANNEL_2;
    /* Set the desired configurations to the sensor */
    _rslt = bma400_set_sensor_conf(conf, NUMBER_OF_SENSOR_CONFIG, &_bma);
    print_rslt(_rslt);
    #define NUMBER_OF_INTERRUPT 2
    struct bma400_int_enable int_select[NUMBER_OF_INTERRUPT];
    int_select[0].type = BMA400_GEN1_INT_EN;
    int_select[0].conf = BMA400_ENABLE;
    int_select[1].type = BMA400_AUTO_WAKEUP_EN;
    int_select[1].conf = BMA400_ENABLE;
    _rslt = bma400_enable_interrupt(int_select, NUMBER_OF_INTERRUPT, &_bma);
    print_rslt(_rslt);
    _rslt = bma400_set_power_mode(BMA400_LOW_POWER_MODE, &_bma);
    print_rslt(_rslt);
    Mehmet
    Thanks for your inquiry. Please see the attached "How to test BMA400 shuttle board for auto-wakeup and auto-lowpower featurev1.pdf" for more informaiton.
