06-09-2021 11:38 AM
the BMA400 has the low-pass filter with bandwidth 0.24ODR or 0.48ODR. It is configurable by ACC_CONFIG0.filt1_bw.
Is there anything else need to be configured to enable this filter?
In the BMA400 Desktop Development 2.0 User Manual on page 10 I see the checkbox "Filter Bandwidth" on figure 10, so is it possible to disable this filter?
Where can I found more information about this filter?
06-10-2021 04:16 AM
Hello Faustyna,
You could see ACC_CONFIG0 register from data sheet, filt1_bw bit value 0 is for 0.4x ODR, filt1_bw bit value 1 is for 0.2x ODR. That you could enable or disable it by in "Filter Bandwidth" option..
