    BMA456 - ASIC not initialized
    Nitzan
    I'm using BMA456 accelerometer with I2C interface, with the following initialization code:
    uint16_t bma456_device_init()
    uint16_t rslt = BMA4_OK;
    /* Modify the parameters */
    s_dev.dev_addr = BMA4_I2C_ADDR_PRIMARY << 1;
    s_dev.interface = BMA4_I2C_INTERFACE;
    s_dev.bus_read = bma456_access_read;
    s_dev.bus_write = bma456_access_write;
    s_dev.delay = OS_PL_Delay;
    s_dev.read_write_len = READ_WRITE_LEN_16;
    s_dev.resolution = RESOLUTION_12_BIT;
    s_dev.feature_len = BMA456_FEATURE_SIZE;
    /* a. Reading the chip id. */
    rslt |= bma456_init(&s_dev);
    if(rslt != BMA4_OK)
       //ASSERT
    /* b. Performing initialization sequence.
    c. Checking the correct status of the initialization sequence.
    rslt |= bma456_write_config_file(&s_dev);
    if(rslt != BMA4_OK)
       //ASSERT
    /* Declare an accelerometer configuration structure */
    struct bma4_accel_config accel_conf;
    /* Assign the desired settings */
    accel_conf.odr = BMA4_OUTPUT_DATA_RATE_100HZ;
    accel_conf.range = BMA4_ACCEL_RANGE_16G;
    accel_conf.bandwidth = BMA4_ACCEL_NORMAL_AVG4;
    /* Set the configuration */
    rslt |= bma4_set_accel_config(&accel_conf, &s_dev);
    if(rslt != BMA4_OK)
       //ASSERT
    /* Enable the accelerometer */
    rslt |= bma4_set_accel_enable(1, &s_dev);
    return rslt;
    The code get into assert after "rslt |= bma456_write_config_file(&s_dev);". When I debug it I saw that the problem occure after reading the config_stream_status i.e the ASIC not initialized. When I'm running the code in Debug-Mode I don't see this problem.
    1. Can you help me understand why the ASIC not initialized?
    2. Do I have to run bma456_write_config_file? when I removing this line the code work without problems...
    Nitzan
    FAE_CA1
    Re: BMA456 - ASIC not initialized
    Yes, you need to run bma456_write_config_file in order to make many features available such as step counting, FIFO and interrupts, etc.
    Please refer to the examples online at https://github.com/BoschSensortec/BMA456-Sensor-API/commit/1f42063da36a13fe8e804bd55d4aeb681357b0c5 for more information.
