    BMA456 Fails after initialization
    nafihahmd
    Hi, First of all let me admit that I am a newbie in embedded firmware. I am trying to write a code for BMA456 using ESP32 and Arduino platform(PlatformIO). I am using latest version of BMA456 Sensor API from the official repo. I am able to read the chip ID (0x16) correctly. But when I try to execute the further steps it's failing. The BMA456 seems to get hang at
     while (Wire.available() < len)
    Also I tried to read the status register at 0x2A  and got a value 0b11111 which is not even defined in the datasheet.
    I will attach my code below.
    P.S: I also tried arduino portred library from Seed studio. The link is here. I tried their step counter example and the steps never incremented.
     Main.cpp
    #include <Arduino.h>
    #include "bma456.h"
    #include "bma4_common.h"
    //  Function Declaration
    uint16_t init_BMA();
    uint16_t config_acc();
    // Global Variables
    struct bma4_dev bma_global; // Declare an instance of the BMA456 device
    uint16_t rslt = BMA4_OK;
    uint8_t init_seq_status;
    uint16_t int_status;         // Variable to store accel data ready interrupt status
    struct bma4_accel_config accel_conf = {0};
    void setup()
      Serial.begin(115200);
      Serial.println("\n BMA456");
      init_BMA();
      //config_acc();
      delay(150);
    void loop()
      // read_acc();
    uint16_t init_BMA()
      Wire.begin();
      // Modify Params
      // bma.dev_addr = BMA4_I2C_ADDR_PRIMARY;
      struct bma4_dev bma; // Declare an instance of the BMA456 device
      bma.intf = BMA4_I2C_INTF;
      bma.bus_read = usr_i2c_r;
      bma.bus_write = usr_i2c_w;
      bma.delay_us = usr_delay;
      bma.read_write_len = 8;
      bma.resolution = 12;
      bma.feature_len = BMA456_FEATURE_SIZE;
      /* a. Reading the chip id. */
      rslt |= bma456_init(&bma);
      Serial.println("tst_pnt1");
      Serial.println(rslt, HEX);
      bma4_error_codes_print_result("bma456_init status", rslt);
      bma4_set_command_register(0xB6, &bma); // reset device
      Serial.println("tst_pnt2");
      delay(500);
      /* b. Performing initialization sequence.
           c. Checking the correct status of the initialization sequence.
      rslt |= bma456_write_config_file(&bma);
      Serial.println(rslt);
      bma4_error_codes_print_result("bma456_write_config status", rslt);
      Serial.println("tst_pnt3");
      bma_global = bma;
      return rslt;
      bma = bma_global;
      bma4_set_accel_enable(BMA4_ENABLE, &bma);
      bma4_error_codes_print_result("bma4_set_accel_enable status", rslt);
      /* Assign the desired settings */
      accel_conf.odr = BMA4_OUTPUT_DATA_RATE_100HZ;
      accel_conf.range = BMA4_ACCEL_RANGE_2G;
      accel_conf.bandwidth = BMA4_ACCEL_NORMAL_AVG4;
      /* Set the configuration */
      rslt |= bma4_set_accel_config(&accel_conf, &bma);
      bma_global = bma;
      return rslt;
    i2c_read functipon
    int8_t usr_i2c_r(uint8_t reg_addr, uint8_t *read_data, uint32_t len, void *intf_ptr)
      Wire.beginTransmission(dev_addr);
      Wire.write(reg_addr);
      Wire.endTransmission(false);
      Wire.requestFrom(dev_addr, len);
      Serial.println("i2cR/tst_pnt1");
      Serial.println("i2cR/tst_pnt2");
      for (int i = 0; i < len; i++)
        read_data[i++] = Wire.read();
      Wire.endTransmission();
      Serial.println("i2cR/tst_pnt3");
      return 0;
    P.S 2: I am using the Serial.print() for debugging
    8 REPLIES 8
    Hi BSTRobin, I will try it and update it here today evening. Thanks for the reply
    Hello nafihahmd,
    By the way, did it work normally?
    No it didn't
    Hello nafihahmd,
    We know a little about Arduino platform. Could you capture I2C waveform with a logic analyzer?
