    BMA456 Triple Tap
    brain_tom
    BMA456 Triple Tap
    Hello
    We are going to make a product using BMA456's Triple Tap.
    However, while checking the function in Development Desktop 2.0, there is a case where the interrupt occurs twice in double tap and triple tap.
    Is this normal?
    Are the values I set wrong?
    Accelerometer Setting
    ODR 200Hz
    Bandwidthnormal mode
    Filter PerformancePerfomance Optimized
    Range4g
    7 REPLIES 7
    Re: BMA456 Triple Tap
    Hi brain_tom,
    The interrupt only occurs once when triple tap.
    Latest DD2.0 software run with BMA456W configuration file, couldn't find triple tap setting.
    There are different BMA456 configuration file which support different features.
    BMA456W
    • Any motion
    • No motion
    • Step detector
    • Step counter
    • Step activity
    • Tap
      • Single tap
      • Double tap
    BMA456H
    • Any motion
    • No motion
    • Step detector
    • Step counter
    • Step activity
    • Auto low power
    • Tap
      • Single tap
      • Double tap
      • Triple tap
    BMA456MM
    • Any motion
    • No motion
    • Orientation
    • High-g
    • Low-g
    • Significant motion
    • Auto low power
    • Tap
      • Single tap
      • Double tap
      • Triple tap
    BMA456AN
    • Any motion
    • No motion
    https://github.com/boschsensortec/BMA456-Sensor-API
    Could we know your applicaton? If it is hearable application, you could use BMA456H configuration file which support single tap, double tap, triple tap.
    brain_tom
    hello, BSTRobin Thanks
    I used the BMA456MM configuration file
    What is the difference between BMA456H and BMA456MM configuration file?
    Hi brain_tom,
    BMA456H and BMA456MM provide a combination of different features, and as you can see from previous comments, users choose to use them based on whether the application requires these features.
    brain_tom
    Hi.  BSTRobin
    In the application note, it is as follows.
    I have a few questions for you.
    1. When using a multi-tap, the mode is supposed to be changed. Which of the performance mode and low power mode should be used?
    2. Is there only a difference in current consumption between performance mode and low power mode?
    Are there any other differences?
    3. Why is it necessary to change the ODR to minimum 200hz when using a multi-tap?
    4. Does the multi-tap algorithm behave differently or have different accuracy depending on the power mode?
