    BMA456 fifo_err flag not working
    augusto1
    I'm using a BMA456 and i'm having trouble with the fifo_err flag in the ERR_REG ( 0x02 ) register.
    The device is configured as follows:
    •  Accelerometer
      • Nominal sampling frequency is 1600 Hz
      • Range is +/- 2G
      • Mode is set to high-performance
    • FIFO
      • Overwrite when full
      • Unfiltered data with no downsampling
      • Headerless mode
    I'm performing a test where i let the FIFO overflow but the flag is never set. The FIFO seems to be working fine and filling.
    Am i missing some configurations?
    I'm using a custom driver for space constraints but i based the logic on your example fifo_full_headerless_mode.
    I suspect that the problem may be that i'm not initializing the ASIC but i'm following your example which doesn't initialize it either.
    Thanks for the support.
    8 REPLIES 8
    Yes, that is the example i used to base my custom library. The example uses the fifo full interrupt while i would like to use the fifo_err flag to detect a fifo overflow.
    No help? Does anyone know if in order to read the fifo_err flag i have to initialize the ASIC? Is it possible to have a list of function supported by the BMA456 with and witouth the ASIC?
    Again.. sorry to bother.
    I can't find this information in the datasheet.
    Also, why some example initialize the ASIC while others don't?
    I really would like an answer.
