    BMA456 offset compensation
    Andy_253
    I use the BMA456 sensor.
    I would like to use the API bma4_perform_accel_foc, for calculating the foc for all 3 axis - x,y,z.
    (I got a code from git hub)
    The API recieves the struct : bma4_accel_foc_g_value.
    I thought to declare - const struct bma4_accel_foc_g_value accel_g_value = {1, 1, 1, 0},  so all three axis will be calculated, but in the API code I see the following condition :
    if (((ABS(accel_g_value->x) + ABS(accel_g_value->y) + ABS(accel_g_value->z)) == 1) &&
    ((accel_g_value->sign == 1) || (accel_g_value->sign == 0)))
    which makes me think I should call one axis at a time (also in related APIs  it seems like that).
    but if so - will it be saved corrctly at the NVM? won't each call run over the previous values?
    I don't understand what is the proper input to the accel_g_value
    Thanks in advance,
    14 REPLIES 14
    Hi BSTRobin,
    I tested the FOC with default range(4g) and accel_g_value are {1, 0, 0, 1}
    But after FOC, the acc.x value didn't reach to '0'.
    I don't think that the purpose of FOC is to make acc value to '0'. It can find the axis of gravity and make it to 8192. Am I correct?
    I added some debug message in perform_accel_foc function as below picture.
    And then I got a debug message as below.
    Do you think, the FOC function working well on my device?
    I'd like to know your opinion.
    Best Regards,
    Andy
    Hi BSTRobin,
    Could you please reply the my previous question?
    I'm waiting for your answer.
    Best Regards,
    Andy
    Hello Andy_253,
    Let us to further check and give you feedback later.
    Hello Andy_253,
    From your log data, FOC run well on your side.
    For your test, X axis should be close to 8192 after FOC, not should be 0.
    Thanks for your confirmation.
    Best Regards,
    Andy
