05-16-2019 04:22 PM
I'm using the BME680 and I'm facing a problem with GAS Resistance measurements.
Here is my setup:
I first thought everything worked fine as I'm getting Temp,Pressure and RH values nicely correlating with measured environment, but even after a few days (weeks) of running measurements, I could still not make any sense of IAQ values.
It turns out that the GAS_RAW value is stuck to a high value corresponding to an adc reading of zero (gas_r=0 and gas_range =0).
I checked requested heater temperature and time (given by BSEC) and it looks correct (320 C/ 197ms in 3 seconds "LP" setup).
When fetching results I always get gas_valid and heat_stab bits set, thus the measurement seems to be correctly performed.
I traced the first seconds of measurements of a brand new BM680 and I saw that adc reading are actually moving:
18:46:07:642 [DRV 3] calc_gas_resistance: adc:392 range:11 -> 4291.02
18:46:10:634 [DRV 3] calc_gas_resistance: adc:960 range:9 -> 11720.93
18:46:13:633 [DRV 3] calc_gas_resistance: adc:379 range:8 -> 34713.96
18:46:16:635 [DRV 3] calc_gas_resistance: adc:413 range:7 -> 68053.58
18:46:19:638 [DRV 3] calc_gas_resistance: adc:616 range:6 -> 116028.30
18:46:22:641 [DRV 3] calc_gas_resistance: adc:619 range:5 -> 229796.34
18:46:25:643 [DRV 3] calc_gas_resistance: adc:839 range:4 -> 401811.03
18:46:28:646 [DRV 3] calc_gas_resistance: adc:309 range:4 -> 588290.75
18:46:31:648 [DRV 3] calc_gas_resistance: adc:879 range:3 -> 785630.88
18:46:34:651 [DRV 3] calc_gas_resistance: adc:533 range:3 -> 984626.62
18:46:37:653 [DRV 3] calc_gas_resistance: adc:310 range:3 -> 1176727.88
18:46:40:659 [DRV 3] calc_gas_resistance: adc:187 range:3 -> 1318627.50
18:46:43:658 [DRV 3] calc_gas_resistance: adc:80 range:3 -> 1473165.38
18:46:46:661 [DRV 3] calc_gas_resistance: adc:860 range:2 -> 1588895.38
18:46:49:664 [DRV 3] calc_gas_resistance: adc:687 range:2 -> 1769736.62
18:48:22:741 [DRV 3] calc_gas_resistance: adc:825 range:0 -> 6489747.00
18:49:34:803 [DRV 3] calc_gas_resistance: adc:366 range:0 -> 8974145.00
18:50:13:837 [DRV 3] calc_gas_resistance: adc:221 range:0 -> 10208728.00
18:56:32:915 [DRV 3] calc_gas_resistance: adc:0 range:0 -> 12946861.00
but after a few minutes the values reaches 0 and stays stuck. I understand ther is a "burn-in" phase for MOX sensors, but I guess it should not "burn" down to zero...
After unplugging/unpowering the BM680 for a while and restarting, I get back some "life" on adc measurements (starting lower than the very first time though), but following the same steep curve to zero. I tried 4 different boards with same result.
Does it ring a bell to anyone ? What could be my problem here ? I can give more detailed info about registers setup (even though I'm just following BSEC requests).
Laurent
05-20-2019 07:26 PM
This behavior doesn't seem expected in typical conditions. If you could share some your code and schematic related to the sensor, we could look for anything outstanding.
05-22-2019 03:14 PM
the Hardware side is quite simple: the BME680 is on a daughtercard with another I2C sensor(Idle during my tests), powered by VREG that can be set to anything between 1.8v to 3.3v (3.3V for my last tests), SDA and SCL are 1K-pulled to VREG, SDO tied to GND, CSB tied to VREG, VDD and VDDIO are tied to VREG and decoupled with 100nF+1uF.
Software side is more difficult to share/explain as I had to remap your code to my environment. I'll attach an excerpt of it anyway as I think its readable enough.
Here is a summary of the thread handling the BME:
First the Init part:
Then the measurement loop:
I attach both source code and a debug trace of its execution. If you need specific register dumps or test case I'll be happy to run them.
Thanks for your support,
Laurent
05-22-2019 03:16 PM
05-28-2019 11:23 AM
Any news about the log and source-code I shared ?
Laurent
