11-23-2020 09:14 PM
I am using the BME 680 and the BME 280 in a sealed glass jar. I know the absolute humidity in the jar is constant because it is sealed.
However, when I get my data from the sensors and calculate the absolute humidty, I am not getting a contant absolute humdity. I have been getting data from the jar being indoors at room temperature and at atmospheric pressure.
Is this because of how the sensors work? Are they not made for monitoring a small, enclosed space? If it is because of how the sensors work, I need to know why this is happening so I can account for it in my calculations.
Thank you for your help!
12-08-2020 06:54 AM - edited 12-08-2020 07:07 AM
Hi Sir:
Due to no reference device, we don't know the actual absolute humidity and its change.
I also can't confirm your results with your enviromental condition.
In our laboratory, temperature chamber and reference device are used to verify sensor performance and accuracy so that test results can be compared with them.
12-08-2020 03:46 PM
Hi Jet,
I understand that. I just don't have any absolutely accurate hygrometers available to me. To counteract that, I wanted to use a controlled environment (a sealed glass jar). I understand that you believe that the environment is not actually controlled. I undersand that you have doubts because there is no refference device but you also mentioned that the water may not be constant anyway. I am interested in knowing where those doubts come from. Where could this water content fluctuation be coming from? I know you cannot tell with certainty, but any thoughts and guesses you had are still valuable to me.
12-14-2020 06:46 AM - edited 12-14-2020 06:57 AM
Hi Sir:
Because I don't repeat your experiment, any thoughts and guesses without actual reference data are uncertain and untrusted.
Some internal documents will be shared under NDA and even we are prone to verify your experiment.
So more support, please contact the local FAE to get.
