    BME 680 configuration on PIC32
    Vilius
    I am an undergraduate university student developing my thesis project with PIC32. I would like to use BME 680 sensor with it. I hooked everything on a breadboard, wrote a working I2C driver  for the PIC32, I also incorporated 3.3 <-> 1.8 V logic translator between the PIC32 and BME 680. But I got stuck with the configuration of the sensor... I was following these instructions: https://github.com/boschsensortec/BME680_driver
    I have added both of the header files and the source file to my project, but still, I can not understand, how do I configure the sensor in the main program? The last section of the link that I provided gives a ,,Templates for function pointers" but I have already written the universal read and write functions for the I2C, so do I still have to write those again? (I though that the point of having a driver written for you is to avoid all those separate register reads and writes...) I may sound confusing, but I would really appreciate any help, explanations or observations. Could you give me an exact template for the main function, highlighting the variables or other parameters I have to change or write for myself? You could possibly save my project 🙂
    For now, I came up with the example code, but I am not sure, if I have to write any more functions, or change the parameters...
        #include <xc.h>
        #include "configurations_bits.h"        //Including microcontroller`s configuration settings
        #include <stddef.h>        //Including all the standard C libraries
        #include <stdint.h>
        #include <stdbool.h>
        #include <stdlib.h>
        #include "stdio.h"
        #include <sys/attribs.h>
        #include "delay.h"        //Including all the separate module header files
        #include "inter_integrated_circuit_protocol.h"
        #include "bme680.h"
        //---EXAMPLE PART ONE-------------------------------------------------------------
        struct bme680_dev gas_sensor {
            gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY;                            //SDO pin is grounded, so this address is correct in my case
            gas_sensor.read = Inter_Integrated_Circuit_Read();                      //I2C read function is defined in the I2C header and source files
            gas_sensor.write = Inter_Integrated_Circuit_Write();                    //I2C write function is defined in the I2C header and source files
            gas_sensor.delay_ms = delay_ms();                                       //delay function is defined in the separate header and source files
        //SHOULD I ASSIGN THESE FUNCTIONS HERE?
            gas_sensor.amb_temp = 25;
            int8_t rslt = BME680_OK;
            int main(void) {        //Main program`s start
                Inter_Integrated_Circuit_Setup ();                                                        //Calling I2C configuration function
                Inter_Integrated_Circuit_Enable ();                                                       //Starting I2C module
               //---EXAMPLE PART TWO-------------------------------------------------------------
                    /* Select the power mode */
                        | BME680_GAS_SENSOR_SEL;
                    rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
                    /* Set the power mode */
                //---EXAMPLE PART THREE-------------------------------------------------------------
               uint16_t meas_period = 1000;    //Lets say 1000 millisecond? Is that the right value?
                    while (true){        //Main program loop
                       delay_ms(meas_period); /* Delay till the measurement is ready */
                            printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
                                data.pressure / 100.0f, data.humidity / 1000.0f );
                            /* Avoid using measurements from an unstable heating setup */
                            if(data.status & BME680_GASM_VALID_MSK)
                                printf(", G: %d ohms", data.gas_resistance);
                            printf("\r\n");
                            /* Trigger the next measurement if you would like to read data out continuously */
                            if (gas_sensor.power_mode == BME680_FORCED_MODE) {
                return (EXIT_FAILURE);
    Hi Vilius,
    You could refer BME68x driver code and example code from https://github.com/boschsensortec/BME68x-Sensor-API
    You don't need to rewrite driver code as it has been provided in the form of API, you only need to modify common.c according your host platform.
