04-11-2022 05:18 PM
04-13-2022 10:26 AM
@BSTRobin you can see in this image there is a "OK check mark" but im still getting the same error, attached is the saved project.
Is there a way to get debug log from ai studio ? as this error msg makes no sence.
04-13-2022 10:35 AM
Hi tomm,
Yes, I use both log data.
The recording time of one data file is less than 30 minutes.
The start and end time stamps of one of the data files are incorrect.
Please refer to the requirements of the wizard.
04-13-2022 10:48 AM
@BSTRobin here is a project with more data but getting same error 😞
04-14-2022 01:33 PM
04-19-2022 09:22 AM
Hi tomm,
When we refer the guide to record data, import data, training the algorithm, it worked well, haven't reproduced your problem.
Could you refer to the wizard carefully and check whether all your operations are correct?
