    BME AI Studio on Mac
    GDD
    I installed the AI studio for Mac on a MacBook Pro 10.13. It starts up and gives the splash screen and never continues.
    I see an error message in ~/Library/Logs/bme*/electron.log:
    {"message":"","level":"error","service":"electron","timestamp":"2021-08-26T00:57:51.364Z"}
    {"message":" info This Node instance does not support builds for N-API version 6\nnode-pre-gyp info This Node instance does not support builds for N-API version 6","level":"error","service":"electron","timestamp":"2021-08-26T00:57:51.376Z"}
    I installed Electron Apps and they work fine. The sample code runs well. Node runs fine from a command prompt.
    How can I debug this?  The UI Studio runs fine on a new Macbook Pro but I can't always access this. I have Docker installed, tensorflow installed. My path is probably running something else?
    My actual preference is to run it on a RPI 4, raspberry OS 64 or 32 bit.
    Gary
    15 REPLIES 15
    Re: BME AI Studio on Mac
    Hello GDD,
    1. When you installed AI studio on your MacBook, did you install it with default settings?
    2.Could you provide a screenshot to see your problem as you descirbed "It starts up and gives the splash screen and never continues"?
    GDD
    1. Yes. I installed it identically on another Mac (new one) that worked.
    2. The flash screen install shows.The flash screen install shows.
    3.
    env
    NVM_INC=/Users/user/.nvm/versions/node/v16.8.0/include/node
    TERM_PROGRAM=Apple_Terminal
    NVM_CD_FLAGS=
    SHELL=/bin/bash
    TERM_PROGRAM_VERSION=404.1
    NVM_DIR=/Users/user/.nvm
    PATH=/Users/user/.nvm/versions/node/v16.8.0/bin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
    PWD=/Users/user
    NVM_BIN=/Users/user/.nvm/versions/node/v16.8.0/bin
    _=/usr/bin/env
    GDD
    Here is a dump
    Process:               BME AI-Studio [1659]
    Path:                  /Applications/BME AI-Studio.app/Contents/MacOS/BME AI-Studio
    Identifier:            com.bosch-sensortec.bme-ai-studio
    Version:               1.6.0 (1.6.0)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           BME AI-Studio [1659]
    User ID:               501
    Date/Time:             2021-08-27 10:28:20.910 -0400
    OS Version:            Mac OS X 10.13.6 (17G14042)
    Report Version:        12
    Anonymous UUID:        968D1B51-8D40-D29F-0287-B9878FB12D2F
    Sleep/Wake UUID:       9FCD910A-ABFF-4AB6-9AF6-96DD6B2C7C91
    Time Awake Since Boot: 2800 seconds
    Time Since Wake:       550 seconds
    System Integrity Protection: enabled
    Crashed Thread:        0  CrBrowserMain  Dispatch queue: com.apple.main-thread
    Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000008
    Exception Note:        EXC_CORPSE_NOTIFY
    Termination Signal:    Segmentation fault: 11
    Termination Reason:    Namespace SIGNAL, Code 0xb
    Terminating Process:   exc handler [0]
    VM Regions Near 0x8:
        __TEXT                 0000000105f69000-0000000105f91000 [  160K] r-x/r-x SM=COW  /Applications/BME AI-Studio.app/Contents/MacOS/BME AI-Studio
    Thread 0 Crashed:: CrBrowserMain  Dispatch queue: com.apple.main-thread
    0   com.github.Electron.framework 	0x00000001061137c7 ElectronInitializeICUandStartNode + 1524231
    1   com.github.Electron.framework 	0x00000001060cbc98 ElectronInitializeICUandStartNode + 1230552
    2   com.github.Electron.framework 	0x000000010c1ef8b4 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 76810724
    3   com.github.Electron.framework 	0x00000001060ccf58 ElectronInitializeICUandStartNode + 1235352
    4   com.github.Electron.framework 	0x0000000106aa1478 ElectronInitializeICUandStartNode + 11542200
    5   com.github.Electron.framework 	0x0000000108c9109a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 20849098
    6   com.github.Electron.framework 	0x0000000108cc6b55 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 21068933
    7   com.github.Electron.framework 	0x0000000108cc4eef v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 21061663
    8   com.github.Electron.framework 	0x0000000108939842 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17344882
    9   com.github.Electron.framework 	0x000000010894a11a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17412682
    10  com.github.Electron.framework 	0x0000000108949de1 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17411857
    11  com.github.Electron.framework 	0x000000010898922e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17671006
    12  com.github.Electron.framework 	0x0000000108984b3a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17652842
    13  com.github.Electron.framework 	0x0000000108988bef v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17669407
    14  com.apple.CoreFoundation      	0x00007fff4acd8b01 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
    15  com.apple.CoreFoundation      	0x00007fff4ad90e5c __CFRunLoopDoSource0 + 108
    16  com.apple.CoreFoundation      	0x00007fff4acbbb0c __CFRunLoopDoSources0 + 300
    17  com.apple.CoreFoundation      	0x00007fff4acbaf2d __CFRunLoopRun + 1293
    18  com.apple.CoreFoundation      	0x00007fff4acba787 CFRunLoopRunSpecific + 487
    19  com.apple.HIToolbox           	0x00007fff49f9ad96 RunCurrentEventLoopInMode + 286
    20  com.apple.HIToolbox           	0x00007fff49f9aa0f ReceiveNextEventCommon + 366
    21  com.apple.HIToolbox           	0x00007fff49f9a884 _BlockUntilNextEventMatchingListInModeWithFilter + 64
    22  com.apple.AppKit              	0x00007fff48247a3b _DPSNextEvent + 2085
    23  com.apple.AppKit              	0x00007fff489dde34 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
    24  com.apple.AppKit              	0x00007fff4823c84d -[NSApplication run] + 764
    25  com.github.Electron.framework 	0x00000001089899c6 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17672950
    26  com.github.Electron.framework 	0x0000000108988772 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17668258
    27  com.github.Electron.framework 	0x000000010894a641 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17414001
    28  com.github.Electron.framework 	0x00000001089203ea v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17241370
    29  com.github.Electron.framework 	0x0000000107cce80a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 4323642
    30  com.github.Electron.framework 	0x0000000107cd02a2 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 4330450
    31  com.github.Electron.framework 	0x0000000107ccbb91 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 4312257
    32  com.github.Electron.framework 	0x0000000107b6681e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2849102
    33  com.github.Electron.framework 	0x0000000107b6651e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2848334
    34  com.github.Electron.framework 	0x000000010a145335 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 42558565
    35  com.github.Electron.framework 	0x0000000106cda095 ElectronInitializeICUandStartNode + 13871829
    36  com.github.Electron.framework 	0x0000000105f9f58a ElectronMain + 74
    37  com.bosch-sensortec.bme-ai-studio	0x0000000105f69fb0 0x105f69000 + 4016
    38  libdyld.dylib                 	0x00007fff72cb7015 start + 1
    Thread 1:
    0   libsystem_kernel.dylib        	0x00007fff72e0828a __workq_kernreturn + 10
    1   libsystem_pthread.dylib       	0x00007fff72fcf009 _pthread_wqthread + 1035
    2   libsystem_pthread.dylib       	0x00007fff72fcebe9 start_wqthread + 13
    Thread 2:: ThreadPoolServiceThread
    0   libsystem_kernel.dylib        	0x00007fff72e08c02 kevent64 + 10
    1   com.github.Electron.framework 	0x000000010899b866 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17746326
    2   com.github.Electron.framework 	0x000000010899b74b v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17746043
    3   com.github.Electron.framework 	0x000000010894a641 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17414001
    4   com.github.Electron.framework 	0x00000001089203ea v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17241370
    5   com.github.Electron.framework 	0x00000001089544bd v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17454573
    6   com.github.Electron.framework 	0x0000000108966f4a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17531002
    7   com.github.Electron.framework 	0x0000000108983497 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17647047
    8   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    9   libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    10  libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 3:: ThreadPoolBackgroundWorker
    0   libsystem_kernel.dylib        	0x00007fff72dfe1fa mach_msg_trap + 10
    1   libsystem_kernel.dylib        	0x00007fff72dfd714 mach_msg + 60
    2   com.github.Electron.framework 	0x000000010898e480 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17692080
    3   com.github.Electron.framework 	0x000000010895da6e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17492894
    4   com.github.Electron.framework 	0x000000010895e28e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494974
    5   com.github.Electron.framework 	0x000000010895df2d v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494109
    6   com.github.Electron.framework 	0x0000000108983497 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17647047
    7   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    8   libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    9   libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 4:: Chrome_IOThread
    5   com.github.Electron.framework 	0x0000000107cd2537 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 4339303
    Thread 5:: MemoryInfra
    3   com.github.Electron.framework 	0x000000010898e34e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17691774
    4   com.github.Electron.framework 	0x00000001089012cf v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17114111
    5   com.github.Electron.framework 	0x000000010894a641 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17414001
    6   com.github.Electron.framework 	0x00000001089203ea v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17241370
    7   com.github.Electron.framework 	0x0000000108966f4a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17531002
    8   com.github.Electron.framework 	0x0000000108983497 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17647047
    9   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    10  libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    11  libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 6:
    0   libsystem_kernel.dylib        	0x00007fff72e08bea kevent + 10
    1   com.github.Electron.framework 	0x000000010c49f887 uv_free_interface_addresses + 1303
    2   com.github.Electron.framework 	0x000000010c48f5fd uv_run + 365
    3   com.github.Electron.framework 	0x000000010c3ee593 node::MultiIsolatePlatform::CancelPendingDelayedTasks(v8::Isolate*) + 675
    4   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    5   libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    6   libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 7:
    0   libsystem_kernel.dylib        	0x00007fff72e07a16 __psynch_cvwait + 10
    1   libsystem_pthread.dylib       	0x00007fff72fd0589 _pthread_cond_wait + 732
    2   com.github.Electron.framework 	0x000000010c49ac09 uv_cond_wait + 9
    3   com.github.Electron.framework 	0x000000010c3ee752 node::MultiIsolatePlatform::CancelPendingDelayedTasks(v8::Isolate*) + 1122
    4   com.github.Electron.framework 	0x000000010c3ec5d9 node::Buffer::New(v8::Isolate*, char*, unsigned long, void (*)(char*, void*), void*) + 540521
    5   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    6   libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    7   libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 8:
    Thread 9:
    Thread 10:
    0   libsystem_kernel.dylib        	0x00007fff72dfe236 semaphore_wait_trap + 10
    1   com.github.Electron.framework 	0x000000010c49b160 uv_sem_wait + 16
    2   com.github.Electron.framework 	0x000000010c450bb3 node::inspector::Agent::GetWsUrl() const + 83
    3   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    4   libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    5   libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 11:
    3   com.github.Electron.framework 	0x000000010c48b982 uv_cancel + 514
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:: NetworkConfigWatcher
    2   com.apple.CoreFoundation      	0x00007fff4acbbdc5 __CFRunLoopServiceMachPort + 341
    3   com.apple.CoreFoundation      	0x00007fff4acbb117 __CFRunLoopRun + 1783
    4   com.apple.CoreFoundation      	0x00007fff4acba787 CFRunLoopRunSpecific + 487
    5   com.apple.Foundation          	0x00007fff4cdd6706 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
    6   com.github.Electron.framework 	0x0000000108989839 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17672553
    7   com.github.Electron.framework 	0x0000000108988772 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17668258
    8   com.github.Electron.framework 	0x000000010894a641 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17414001
    9   com.github.Electron.framework 	0x00000001089203ea v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17241370
    10  com.github.Electron.framework 	0x0000000108966f4a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17531002
    11  com.github.Electron.framework 	0x0000000108983497 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17647047
    12  libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    13  libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    14  libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 16:: CrShutdownDetector
    0   libsystem_kernel.dylib        	0x00007fff72e09142 read + 10
    1   com.github.Electron.framework 	0x000000010607367c ElectronInitializeICUandStartNode + 868540
    2   com.github.Electron.framework 	0x0000000108983497 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17647047
    Thread 17:: NetworkConfigWatcher
    Thread 18:: ThreadPoolForegroundWorker
    5   com.github.Electron.framework 	0x000000010895dfbd v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494253
    Thread 19:: CompositorTileWorker1
    2   com.github.Electron.framework 	0x0000000108982587 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17643191
    3   com.github.Electron.framework 	0x0000000109bfb3f1 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 37012769
    4   com.github.Electron.framework 	0x0000000108983497 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17647047
    Thread 20:: ThreadPoolSingleThreadForegroundBlocking0
    4   com.github.Electron.framework 	0x000000010895da7d v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17492909
    5   com.github.Electron.framework 	0x000000010895e28e v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494974
    6   com.github.Electron.framework 	0x000000010895e01d v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494349
    Thread 21:
    2   com.github.Electron.framework 	0x00000001061123a9 ElectronInitializeICUandStartNode + 1519081
    Thread 22:: NetworkConfigWatcher
    Thread 23:: ThreadPoolForegroundWorker
    Thread 24:: CacheThread_BlockFile
    5   com.github.Electron.framework 	0x0000000108966f4a v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17531002
    Thread 25:: com.apple.NSEventThread
    5   com.apple.AppKit              	0x00007fff48384fc4 _NSEventThread + 184
    6   libsystem_pthread.dylib       	0x00007fff72fcf661 _pthread_body + 340
    7   libsystem_pthread.dylib       	0x00007fff72fcf50d _pthread_start + 377
    8   libsystem_pthread.dylib       	0x00007fff72fcebf9 thread_start + 13
    Thread 26:: ThreadPoolSingleThreadSharedBackgroundBlocking1
    5   com.github.Electron.framework 	0x000000010895e0cf v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494527
    6   com.github.Electron.framework 	0x000000010895df5d v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 17494157
    Thread 27:
    0   libsystem_pthread.dylib       	0x00007fff72fcebdc start_wqthread + 0
    1   ???                           	0x00007000044c0b30 0 + 123145374403376
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x00007ffee9c944d0  rbx: 0x0000000000000013  rcx: 0x70206e65706f2068  rdx: 0x0000000000000000
      rdi: 0x0000000000000000  rsi: 0x00007ffee9c944d0  rbp: 0x00007ffee9c94520  rsp: 0x00007ffee9c944c0
       r8: 0x0000000000000000   r9: 0x000000000000002d  r10: 0x00007fffa4c2fb58  r11: 0x00007ffddd5b570a
      r12: 0x00007fff7208ee80  r13: 0x0000000000000000  r14: 0x00007ffee9c94548  r15: 0x000060400001b0d0
      rip: 0x00000001061137c7  rfl: 0x0000000000010246  cr2: 0x0000000000000008
    Logical CPU:     3
    Error Code:      0x00000004
    Trap Number:     14
    Binary Images:
           0x105f69000 -        0x105f90ff3 +com.bosch-sensortec.bme-ai-studio (1.6.0 - 1.6.0) <5CF444E6-280A-33A3-87FF-B56A6B4EC25C> /Applications/BME AI-Studio.app/Contents/MacOS/BME AI-Studio
           0x105f9d000 -        0x10d415f37 +com.github.Electron.framework (10.1.6) <C0E840DB-C562-31D3-BCEB-94DA1517BEA4> /Applications/BME AI-Studio.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
           0x10dd78000 -        0x10e008ff7 +libffmpeg.dylib (0) <6A525CAC-73E6-3A28-AC1E-DBD8FAFBF55B> /Applications/BME AI-Studio.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libffmpeg.dylib
           0x10e3d9000 -        0x10e3f4fff +com.github.Squirrel (1.0 - 1) <E4398068-33D3-3A00-9DBE-5ACC9B022501> /Applications/BME AI-Studio.app/Contents/Frameworks/Squirrel.framework/Versions/A/Squirrel
           0x10e422000 -        0x10e485ff7 +org.reactivecocoa.ReactiveCocoa (1.0 - 1) <701B20DE-3ADD-3643-B52A-E05744C30DB3> /Applications/BME AI-Studio.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/ReactiveCocoa
           0x10e506000 -        0x10e51afff +org.mantle.Mantle (1.0 - ???) <31915DD6-48E6-3706-A076-C9D4CE17F4F6> /Applications/BME AI-Studio.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
           0x111377000 -        0x1113c1adf  dyld (551.5) <CB9BFB56-4511-36F1-A546-891FF770C01C> /usr/lib/dyld
           0x113243000 -        0x11359cfff  com.apple.driver.AppleIntelHDGraphicsGLDriver (10.4.14 - 10.0.4) <EC999B40-0DAA-3BC5-9E71-53FAB4825CEC> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHDGraphicsGLDriver
           0x1136cc000 -        0x113f13fff  com.apple.GeForceTeslaGLDriver (10.4.14 - 10.0.4) <2C4EEF6D-346C-316A-B388-FECFFF78095E> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver
        0x7fff42f56000 -     0x7fff432a4ff7  com.apple.RawCamera.bundle (8.05.0 - 1017.4.1) <937CBA8D-60C8-3739-8DFF-1C737D6339EF> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff463f5000 -     0x7fff46b72ff7  libclh.dylib (4.0.3 - 4.0.3) <43AAC537-1186-33D6-A5FA-35AADE3543A8> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
        0x7fff46b78000 -     0x7fff46d58ff3  com.apple.avfoundation (2.0 - 1536.36) <AB868021-AB26-3198-897D-087EF3B360EA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
        0x7fff46d59000 -     0x7fff46e12fff  com.apple.audio.AVFAudio (1.0 - ???) <716306C4-A0EA-3D81-8F33-943153538C47> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
        0x7fff46f18000 -     0x7fff46f18fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <2EF00EFE-06E8-3082-85C3-2988B422A19D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff46f19000 -     0x7fff46f30ff7  libCGInterfaces.dylib (417.2) <82F29CAE-C0AC-3E29-8312-09E6FED7E067> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
        0x7fff46f31000 -     0x7fff4767fffb  com.apple.vImage (8.1 - ???) <56C275C1-459F-37CD-BF29-2E6D81C29E53> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff47680000 -     0x7fff47820ff3  libBLAS.dylib (1211.50.2) <93259222-2D94-333D-A1EB-09C6FC4A64B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff47821000 -     0x7fff4785bfef  libBNNS.dylib (38.1) <0AAE0109-71D5-3B26-8401-3E62DDF97624> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
        0x7fff4785c000 -     0x7fff47c35ff7  libLAPACK.dylib (1211.50.2) <70781D0B-AEAD-33EB-9900-10DC30F37D61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff47c36000 -     0x7fff47c4cff7  libLinearAlgebra.dylib (1211.50.2) <FB5A35EA-D636-3D69-AB53-B67E1EB8134C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
        0x7fff47c4d000 -     0x7fff47c52ff3  libQuadrature.dylib (3) <E936BDAF-8492-34D9-8C5C-AFBFCDAD8318> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
        0x7fff47c53000 -     0x7fff47cd3fff  libSparse.dylib (79.50.2) <0DC25CDD-F8C1-3D6E-B472-8B060708424F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
        0x7fff47cd4000 -     0x7fff47ce6ff7  libSparseBLAS.dylib (1211.50.2) <994A7D7E-FA3B-3943-A59C-8150B9AF86BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
        0x7fff47ce7000 -     0x7fff47e5afe7  libvDSP.dylib (622.50.5) <4BF310F4-31A3-3DA5-80E4-7F8014AD380B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff47e5b000 -     0x7fff47f11fef  libvMisc.dylib (622.50.5) <88143A88-4FDE-35A1-85FE-54FF0C2A9E43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff47f12000 -     0x7fff47f12fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <880DEF40-389A-3F56-ACA1-B62A5BC57E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff48206000 -     0x7fff49064fff  com.apple.AppKit (6.9 - 1561.61.100) <4E6EA3FA-8C2C-3B21-BFF9-6F8C458B7BE1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff490b6000 -     0x7fff490b6fff  com.apple.ApplicationServices (48 - 50) <2B5B76E7-0AB2-31F9-BE58-B963BF1EC2E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff490b7000 -     0x7fff4911dfff  com.apple.ApplicationServices.ATS (377 - 445.5) <60176327-F757-308E-B61A-D43394E87CC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff491b6000 -     0x7fff492d8ff7  libFontParser.dylib (222.1.9) <FFF2AC1A-D4D2-3AD3-BFF2-F3649ECB02AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff492d9000 -     0x7fff49324ff7  libFontRegistry.dylib (221.6) <30C6D1DE-C0E3-3447-A0EF-829443D95F0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff493c9000 -     0x7fff493fcff7  libTrueTypeScaler.dylib (222.1.9) <BF00CE2B-6BC5-3337-8350-A1BAB88A3CE0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
        0x7fff49466000 -     0x7fff4946aff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <04764FB2-22D8-36F0-9647-2D21562E28D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
        0x7fff4950a000 -     0x7fff4955cffb  com.apple.HIServices (1.22 - 625) <3C059A55-1409-373E-BF0B-C3299AFABDCF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff4955d000 -     0x7fff4956bfff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <8BB267F4-D5AA-3D35-8269-1A3CEA054ACD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff4956c000 -     0x7fff495b8fff  com.apple.print.framework.PrintCore (13.4 - 503.2) <2EA98448-9D6A-3912-9933-F7703CB01B6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff495b9000 -     0x7fff495f3fff  com.apple.QD (3.12 - 404.2) <525E9518-DFF3-3D8D-BD48-E0D63EEDBD16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff495f4000 -     0x7fff49600fff  com.apple.speech.synthesis.framework (7.8.1 - 7.8.1) <CD09019C-569B-3A56-B84C-26F2A6223455> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff49601000 -     0x7fff4988fff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <C7BE1645-BE23-3427-8650-1CEFDAF86710> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff49891000 -     0x7fff49891fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <294802B9-E24D-34EB-973F-6D2B8E2E86CB> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff49bb4000 -     0x7fff49f51fff  com.apple.CFNetwork (902.6 - 902.6) <46168F79-CCFA-349A-8508-B8CBCE27D440> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff49f66000 -     0x7fff49f66fff  com.apple.Carbon (158 - 158) <F8B370D9-2103-3276-821D-ACC756167F86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff49f67000 -     0x7fff49f6affb  com.apple.CommonPanels (1.2.6 - 98) <075486A5-8E39-3F72-BED7-752517379C55> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff49f6b000 -     0x7fff4a270fff  com.apple.HIToolbox (2.1.1 - 911.10) <8D2EBE85-9AF0-38BC-ACD3-1ED978643907> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff4a271000 -     0x7fff4a274ffb  com.apple.help (1.3.8 - 66) <7F210C1C-D7D3-3C97-A2E4-D3CC35F91807> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff4a275000 -     0x7fff4a27afff  com.apple.ImageCapture (9.0 - 9.0) <3993E094-AB86-3B22-BC18-4550F23854FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff4a27b000 -     0x7fff4a310ffb  com.apple.ink.framework (10.9 - 221) <83976BB8-A423-3AA5-8221-6EB04B3DEF0A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff4a311000 -     0x7fff4a32bff7  com.apple.openscripting (1.7 - 174) <C282DFBB-4BF2-3222-87E0-0B560D5B4B2F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff4a34c000 -     0x7fff4a34dfff  com.apple.print.framework.Print (12 - 267) <DFC4CE94-F6E6-3DFA-AB88-A13E4C5A7701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff4a34e000 -     0x7fff4a350ff7  com.apple.securityhi (9.0 - 55006) <1AB48F32-D1CB-3657-A30C-40A7E718A71D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff4a351000 -     0x7fff4a357fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A07BB54-438B-34C9-8061-45403E197ACA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff4a478000 -     0x7fff4a478fff  com.apple.Cocoa (6.11 - 22) <3269BC26-0217-39FE-A600-D702656D838B> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff4a486000 -     0x7fff4a53ffff  com.apple.ColorSync (4.13.0 - 3325) <EAD2D314-E810-33FB-B105-BD30ABB912AD> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff4a6cc000 -     0x7fff4a75fff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <AF2B41CC-DD7A-34EB-A842-00DC3B8F2E9F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff4a7c6000 -     0x7fff4a7efffb  com.apple.CoreBluetooth (1.0 - 1) <ED48840B-A80A-32C1-8E4B-DEB7A7CD3C1A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
        0x7fff4a7f0000 -     0x7fff4ab54ff3  com.apple.CoreData (120 - 851) <283AF401-07BC-3D50-9B8C-7990E64F66BA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff4ab55000 -     0x7fff4ac38fff  com.apple.CoreDisplay (99.14 - 99.14) <9B2B211D-EC0A-3569-BB37-887768CD6105> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
        0x7fff4ac39000 -     0x7fff4b0d5fff  com.apple.CoreFoundation (6.9 - 1455.300) <D9D5D50D-5DA3-34B6-8077-DD24315A4B1E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff4b0d7000 -     0x7fff4b706ff7  com.apple.CoreGraphics (2.0 - 1161.21.5) <C8BAA8C0-3DF0-37C3-8FB4-AB90BA8D4D56> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff4b708000 -     0x7fff4b9f7fff  com.apple.CoreImage (13.0.0 - 579.5) <B2B60A80-2E10-3EDF-920C-94288E55AE25> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff4b9f8000 -     0x7fff4ba63ff7  com.apple.corelocation (2245.0.41) <6BF57F70-732C-3140-B5A3-466ACF262765> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
        0x7fff4ba64000 -     0x7fff4baa9fff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <EE9A1F14-93BB-3DB1-AD62-064C1F4B6D85> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
        0x7fff4bc86000 -     0x7fff4bd7cffb  com.apple.CoreMedia (1.0 - 2276.80.4) <67942D16-3658-37FC-B61C-8ED3D4BFBFB9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff4bd7d000 -     0x7fff4bdcbfff  com.apple.CoreMediaIO (814.0 - 4995) <2A174DD1-431A-3313-9837-04C7E1B284B6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff4bdcc000 -     0x7fff4bdccfff  com.apple.CoreServices (822.37 - 822.37) <CE816EF2-2B89-3F54-A5C6-D3080B1EFB00> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff4bdcd000 -     0x7fff4be41ffb  com.apple.AE (735.2 - 735.2) <0938A72B-6A4A-36F1-95B3-5EF6B915CEEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff4be42000 -     0x7fff4c119fff  com.apple.CoreServices.CarbonCore (1178.4.2 - 1178.4.2) <4692EE3A-11FE-31FD-AF5B-30F892E87A05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff4c11a000 -     0x7fff4c14efff  com.apple.DictionaryServices (1.2 - 284.2) <F1F3EFAE-2562-394D-8FB3-BE22F16CD75A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff4c14f000 -     0x7fff4c157ffb  com.apple.CoreServices.FSEvents (1239.50.2 - 1239.50.2) <FE465894-4235-3CE2-9A97-32D6C6C7D9AD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
        0x7fff4c158000 -     0x7fff4c316ff7  com.apple.LaunchServices (822.37 - 822.37) <0DB4679F-AE39-3BF3-B39B-549322E355AF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff4c317000 -     0x7fff4c3c7fff  com.apple.Metadata (10.7.0 - 1191.8) <F3BD3FD7-208A-31E9-85CD-6E607DDAFEF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff4c3c8000 -     0x7fff4c428fff  com.apple.CoreServices.OSServices (822.37 - 822.37) <564DDE70-0250-346B-B5CC-4AFAC11A7373> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff4c429000 -     0x7fff4c497fff  com.apple.SearchKit (1.4.0 - 1.4.0) <97DD9E7D-3567-382B-ACF7-CE0E4FE78D36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff4c498000 -     0x7fff4c4bcffb  com.apple.coreservices.SharedFileList (71.21 - 71.21) <88991F51-0A75-34FF-8C91-ED0F3C270B7B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
        0x7fff4c75d000 -     0x7fff4c8adfff  com.apple.CoreText (352.0 - 578.23) <10DAF601-85A8-3F9C-8B0B-69DC16B95E47> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff4c8ae000 -     0x7fff4c8e8fff  com.apple.CoreVideo (1.8 - 0.0) <0DD4FFDF-E1F1-39D1-8246-5D0D9869F1EA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff4c8e9000 -     0x7fff4c974ff3  com.apple.framework.CoreWLAN (13.0 - 1350.2) <EC145FBD-F638-38B8-BE94-F892A2F02550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff4cbef000 -     0x7fff4cbf4fff  com.apple.DiskArbitration (2.7 - 2.7) <51DC4AED-6F0C-321F-93E3-20EA4341B768> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff4cdb2000 -     0x7fff4cdb4ff7  com.apple.ForceFeedback (1.0.6 - 1.0.6) <3BBF3660-5996-36D5-86C8-E439D37AEDBA> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
        0x7fff4cdb5000 -     0x7fff4d17cffb  com.apple.Foundation (6.9 - 1455.300) <0479E072-1DD0-3881-A9A2-EDAD3EE58C23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff4d1ed000 -     0x7fff4d21dff3  com.apple.GSS (4.0 - 2.0) <7E83A21E-4F90-38F3-9FD3-FAC0E0143243> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff4d21e000 -     0x7fff4d236ff3  com.apple.GameController (1.0 - 1) <56A770F2-5EEB-3D85-808E-22B71FD46D30> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
        0x7fff4d32f000 -     0x7fff4d433ffb  com.apple.Bluetooth (6.0.7 - 6.0.7f22) <08E33A6B-16A7-3E4E-82C9-E1E5A84300D0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
        0x7fff4d493000 -     0x7fff4d52efff  com.apple.framework.IOKit (2.0.2 - 1445.71.6) <4B5C715C-6A49-366B-9080-ABADE6A3B3BD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff4d530000 -     0x7fff4d537fff  com.apple.IOSurface (211.15 - 211.15) <08DA3232-805F-304B-80DD-C86B49CC4AAD> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff4d538000 -     0x7fff4d58dff3  com.apple.ImageCaptureCore (7.0 - 7.0) <5B5C36EE-69EE-39E8-8B5B-360EF3F4AC3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fff4d58e000 -     0x7fff4d70cfff  com.apple.ImageIO.framework (3.3.0 - 1739.3.8) <B4911BA1-6844-3BD6-BA68-AF4ACEB9D508> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff4d70d000 -     0x7fff4d711ffb  libGIF.dylib (1739.3.8) <003D0895-622E-3312-9DB3-F7B7BFD33AEE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff4d712000 -     0x7fff4d7f9ff7  libJP2.dylib (1739.3.8) <9CD47B18-AAD7-379F-B04F-606B97CC62EA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff4d7fa000 -     0x7fff4d81dfff  libJPEG.dylib (1739.3.8) <67715B7F-83C3-3A0E-9F1C-8B69041E1E3E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff4db0e000 -     0x7fff4db34ff3  libPng.dylib (1739.3.8) <CBA3121F-CACF-357A-B59D-804B8EFF8AF7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff4db35000 -     0x7fff4db37ff3  libRadiance.dylib (1739.3.8) <7F224790-D5FF-3671-BDF0-22D676E6EE6A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff4db38000 -     0x7fff4db85ffb  libTIFF.dylib (1739.3.8) <1D450863-14A2-3268-B848-037D7ABAB4B0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff4dd41000 -     0x7fff4ea27fff  com.apple.JavaScriptCore (13605 - 13605.3.8) <FCD40D3C-87D5-3738-A19F-F5DB84A643B7> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff4ea3f000 -     0x7fff4ea58ff7  com.apple.Kerberos (3.0 - 1) <C7CDC1E0-011B-3220-847D-1AC3DA6D5522> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff4ead8000 -     0x7fff4eaf6ffb  com.apple.CoreAuthentication.SharedUtils (1.0 - 425.70.2) <34405875-F2EC-35F1-A9F6-70B0C319217C> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/Versions/A/SharedUtils
        0x7fff4eaf7000 -     0x7fff4eb0dff7  com.apple.LocalAuthentication (1.0 - 425.70.2) <F6E31D09-191C-395E-8FE7-2F422DBD2D17> /System/Library/Frameworks/LocalAuthentication.framework/Versions/A/LocalAuthentication
        0x7fff4ed17000 -     0x7fff4ed1efff  com.apple.MediaAccessibility (1.0 - 114) <00F21329-1163-3283-A882-A5DD7A12D353> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
        0x7fff4ed34000 -     0x7fff4edcdfff  com.apple.MediaPlayer (1.0 - 1.0) <E04A1D72-429F-390E-9542-0DEB46DFB3EA> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
        0x7fff4edce000 -     0x7fff4f438ff7  com.apple.MediaToolbox (1.0 - 2276.80.4) <FA444376-E5AF-36AB-BE1D-76ECE4D72049> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff4f43a000 -     0x7fff4f4bbfff  com.apple.Metal (125.30 - 125.30) <67EDA241-80B1-3C67-BB2B-FF83E49FEF8D> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
        0x7fff4f4bd000 -     0x7fff4f4d7ffb  com.apple.MetalKit (1.0 - 98.3) <46B0ECC2-0C3F-3E74-A4E7-0B5D6DF4BEAA> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
        0x7fff4f4d8000 -     0x7fff4f4f3fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <8DED0F0C-4A10-36A3-A3E2-7D3CF429ACE1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
        0x7fff4f4f4000 -     0x7fff4f563fef  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <48F4A97F-143A-3918-AB92-6733E258E25A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
        0x7fff4f564000 -     0x7fff4f588fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <CD443ADC-07FE-3603-B0C9-60C2AF3616FF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
        0x7fff4f589000 -     0x7fff4f670ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <40EB0BAE-6DDE-3334-A28C-529AE4C6716A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
        0x7fff4f671000 -     0x7fff4f671ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <A111E862-43E5-3247-9E98-0A40DC34AD9B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
        0x7fff50670000 -     0x7fff5067cffb  com.apple.NetFS (6.0 - 4.0) <02E09301-324F-3542-875D-B87B144635C8> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff53465000 -     0x7fff5346dfef  libcldcpuengine.dylib (2.8.7) <78747075-B07A-39B3-A065-013FB54332F6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
        0x7fff5346e000 -     0x7fff534c8ff7  com.apple.opencl (2.8.24 - 2.8.24) <429B5283-276D-372D-BB0E-EEBE1408C393> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff534c9000 -     0x7fff534e5ffb  com.apple.CFOpenDirectory (10.13 - 207.50.1) <E9AD4934-5DE3-3DD0-9D7B-9D288D829F15> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff534e6000 -     0x7fff534f1fff  com.apple.OpenDirectory (10.13 - 207.50.1) <8B54C486-14C9-3FEF-97B8-F4D6F59F75CF> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff54670000 -     0x7fff54672fff  libCVMSPluginSupport.dylib (16.7.4) <3E26CF2B-5074-3321-AD9E-6A667D61AA35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff54673000 -     0x7fff54678ffb  libCoreFSCache.dylib (162.12) <D12E1D0E-C0E5-329E-99B4-AB152C9ABBE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
        0x7fff54679000 -     0x7fff5467dfff  libCoreVMClient.dylib (162.12) <39951906-8566-3F9D-9EA8-EBD6084DCF73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff5467e000 -     0x7fff54687ff3  libGFXShared.dylib (16.7.4) <81A7875B-103D-3C82-B25C-DE24E57E5C8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff54688000 -     0x7fff54693fff  libGL.dylib (16.7.4) <2BB333D3-5C61-33DF-8545-06DF2D08B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff54694000 -     0x7fff546cffe7  libGLImage.dylib (16.7.4) <4DA003CE-0B74-3FE4-808C-B2FBCE517EB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff546d0000 -     0x7fff5483dff3  libGLProgrammability.dylib (16.7.4) <1F7FE846-FDAF-3B3E-85AE-2FD0D0C46803> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
        0x7fff5483e000 -     0x7fff5487cffb  libGLU.dylib (16.7.4) <BCB09CD8-EB0E-38FA-8B5A-9E29532EE364> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff551f4000 -     0x7fff55203ff3  com.apple.opengl (16.7.4 - 16.7.4) <77A788F3-8F0C-305C-AEB9-FF258676C599> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff55204000 -     0x7fff5539bff3  GLEngine (16.7.4) <D803B49C-2CE6-3282-B15E-D7859C58DBC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
        0x7fff5539c000 -     0x7fff553c4ffb  GLRendererFloat (16.7.4) <A474BF54-6B9C-3C76-BCB9-8FAD533E2B2A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
        0x7fff55582000 -     0x7fff556ceff7  com.apple.QTKit (7.7.3 - 3014.8) <F333568C-D990-3BBA-A09B-ABAB5F984905> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff556cf000 -     0x7fff55934ff7  com.apple.imageKit (3.0 - 1043) <1E72C513-391D-37CE-96D1-D2B59E2F23CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
        0x7fff55935000 -     0x7fff55a24ff3  com.apple.PDFKit (1.0 - 677.68) <07888D80-F4FD-38AD-8F21-48F59E486886> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
        0x7fff55a25000 -     0x7fff55f37ff7  com.apple.QuartzComposer (5.1 - 364) <0C9739CE-DCEA-3732-B3F4-EFB74464C9BC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
        0x7fff55f38000 -     0x7fff55f5bfff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F536C492-49CC-37B6-B740-DA266955E147> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
        0x7fff55f5c000 -     0x7fff56055ff7  com.apple.QuickLookUIFramework (5.0 - 743.13) <E56CBAA3-60CE-3E0C-B3DE-D21DBF93A785> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
        0x7fff56056000 -     0x7fff56056fff  com.apple.quartzframework (1.5 - 21) <DCEB0FCC-2C32-3D02-8752-7B6FA009AB85> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff56057000 -     0x7fff562a3ff7  com.apple.QuartzCore (1.11 - 584.64.2) <FD9A3180-479E-3DAC-9CF0-0D214C7E46A7> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff562a4000 -     0x7fff562fbff7  com.apple.QuickLookFramework (5.0 - 743.13) <4EA17C20-5BD9-335F-8EE1-D4AE16BE6A15> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff564c1000 -     0x7fff564dbffb  com.apple.SafariServices.framework (13609 - 13609.3.5.1.5) <8102DF3E-2C36-3B47-B10E-B990DABCF95D> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
        0x7fff56adb000 -     0x7fff56e06fff  com.apple.security (7.0 - 58286.70.19) <E118FC23-2E20-3999-826B-58488049A277> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff56e07000 -     0x7fff56e93ff7  com.apple.securityfoundation (6.0 - 55185.50.5) <3D9AD4EF-439C-3AE1-9332-AD291CF96C64> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff56e94000 -     0x7fff56ec4fff  com.apple.securityinterface (10.0 - 55109.50.6) <E9AA6D3B-E1ED-330A-B97D-2A71B4F13250> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
        0x7fff56ec5000 -     0x7fff56ec9ffb  com.apple.xpc.ServiceManagement (1.0 - 1) <3FCAF325-40C8-3148-9E49-E555F95B2946> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff5712a000 -     0x7fff57136ffb  com.apple.StoreKit (1.0 - 658.2) <BAB59B79-AC9B-3438-A4B3-DC0A7A1F02B0> /System/Library/Frameworks/StoreKit.framework/Versions/A/StoreKit
        0x7fff5726e000 -     0x7fff572deff3  com.apple.SystemConfiguration (1.17 - 1.17) <41D509AB-AED3-30FF-BB00-615BB5A8AC00> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff57493000 -     0x7fff5780efff  com.apple.VideoToolbox (1.0 - 2276.80.4) <1C94A509-0372-3B58-94BC-4488C042BD79> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff5a1db000 -     0x7fff5a26eff3  com.apple.APFS (1.0 - 1) <70034B32-9347-30FB-9DDE-95061F686613> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
        0x7fff5ae4e000 -     0x7fff5ae69ff3  com.apple.AppContainer (4.0 - 360.50.7) <E57B6D18-C2CD-3706-946C-501E237D1A23> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
        0x7fff5ae9b000 -     0x7fff5aec3fff  com.apple.framework.Apple80211 (13.0 - 1370.4) <C296CDDB-0A79-3D6B-898A-0FBA1892F5AC> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff5aec5000 -     0x7fff5aed4fef  com.apple.AppleFSCompression (96.60.1 - 1.0) <CBE1A092-CE90-36B9-AAA6-0BE2E7921504> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
        0x7fff5afd3000 -     0x7fff5afdeff7  com.apple.AppleIDAuthSupport (1.0 - 1) <924EA55F-1C87-347F-9212-F79EA2B2C84C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
        0x7fff5b018000 -     0x7fff5b060ff3  com.apple.AppleJPEG (1.0 - 1) <15558577-08E3-3087-86A9-8B6247978BCE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
        0x7fff5b09b000 -     0x7fff5b0c3fff  com.apple.applesauce (1.0 - ???) <9CE4CAE2-30B9-3DF6-9BC0-33D532D7B937> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
        0x7fff5b18c000 -     0x7fff5b18ffff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <62DC46E4-5D00-3EAF-94C8-0F45592F90D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff5b190000 -     0x7fff5b1e0ff7  com.apple.AppleVAFramework (5.0.41 - 5.0.41) <C82921AA-1537-3736-BC16-5CABB3EF0100> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff5b516000 -     0x7fff5b7afffb  com.apple.AuthKit (1.0 - 1) <C3087797-E472-300E-8B4A-448857ACE8E7> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
        0x7fff5b8e6000 -     0x7fff5b8edff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <B2A1EEDF-490A-38E2-A896-41057C0417BF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
        0x7fff5b8ee000 -     0x7fff5b975ff7  com.apple.backup.framework (1.9.6 - 1.9.6) <0A54D219-E71B-3BC6-8DFC-11ED47E431BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff5b97e000 -     0x7fff5b984ff7  com.apple.BezelServicesFW (305.1 - 305.1) <30FB8483-B8E4-3DA8-912F-6DF76D4CE2F6> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
        0x7fff5c759000 -     0x7fff5c7a8ff3  com.apple.ChunkingLibrary (189 - 189) <B3E4AA69-99C8-342F-B37E-C1921C72DBD2> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff5d324000 -     0x7fff5d330ff7  com.apple.CommerceCore (1.0 - 658.2) <6125A0B3-43CD-3A9B-BFE3-33742128B7CB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
        0x7fff5d331000 -     0x7fff5d33aff3  com.apple.CommonAuth (4.0 - 2.0) <21AF4AC2-E650-35F9-AB33-3EBA2769FBC0> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff5d676000 -     0x7fff5da7efff  com.apple.CoreAUC (259.0.0 - 259.0.0) <EF95ED0E-F4F1-3969-89BB-CE8CDD74C29F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff5da7f000 -     0x7fff5daafff7  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <6AC79B1F-0A12-34A4-BC0D-5A6A65ABABE0> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff5db46000 -     0x7fff5db98ff7  com.apple.corebrightness (1.0 - 1) <60643D9E-25C6-3A48-867E-9444B2181669> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
        0x7fff5de4e000 -     0x7fff5de5eff7  com.apple.CoreEmoji (1.0 - 69.3) <DCCF04BB-DA33-3DC0-B7C2-1D34870C0C0A> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
        0x7fff5e162000 -     0x7fff5e178ff7  com.apple.CoreMediaAuthoring (2.2 - 956) <EE44B61D-6742-3649-A52F-C6AA0431F846> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
        0x7fff5e4ad000 -     0x7fff5e552fff  com.apple.CorePDF (4.0 - 414) <320B28D5-5115-3C4B-9AEC-6114305DFACA> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
        0x7fff5e5f2000 -     0x7fff5e5faff3  com.apple.CorePhoneNumbers (1.0 - 1) <3B388768-5CDB-341A-BCE2-4047EAD009EA> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
        0x7fff5e785000 -     0x7fff5e7b6ff3  com.apple.CoreServicesInternal (309.1 - 309.1) <9A9DE5A0-3912-3311-A351-2B7B5C35D1F0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff5eb30000 -     0x7fff5ebc1fff  com.apple.CoreSymbolication (9.3 - 64026.2) <30652FA5-C731-3A22-864D-DF6D9C77CD4C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff5ec44000 -     0x7fff5ed79fff  com.apple.coreui (2.1 - 494.1) <5B4F3E9C-A4EF-3908-A035-59B8631C3685> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff5ed7a000 -     0x7fff5eeabfff  com.apple.CoreUtils (5.6 - 560.11) <2C5A0610-1F08-3603-8692-EE03E62EE622> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
        0x7fff5ef00000 -     0x7fff5ef64fff  com.apple.framework.CoreWiFi (13.0 - 1350.2) <500CC54F-A6CB-3D36-9BB1-C9C9F6A6E414> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff5ef65000 -     0x7fff5ef75ff7  com.apple.CrashReporterSupport (10.13 - 1) <1ADEC140-4838-3976-A14B-6268C5251481> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff5eff4000 -     0x7fff5f003ff7  com.apple.framework.DFRFoundation (1.0 - 191.7) <F7AB1B29-A4B0-3938-AFDC-DAA204929404> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
        0x7fff5f006000 -     0x7fff5f00affb  com.apple.DSExternalDisplay (3.1 - 380) <13AA3B17-E649-3B7B-B09D-9AE7C4A60887> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
        0x7fff5f08c000 -     0x7fff5f102fff  com.apple.datadetectorscore (7.0 - 590.3) <E645FBF0-B47D-3394-84DF-792B85E94CB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff5f150000 -     0x7fff5f190ff7  com.apple.DebugSymbols (181.0 - 181.0) <702DB951-F5A6-3155-9D84-BBA9A4B4E1BD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff5f191000 -     0x7fff5f2c0fff  com.apple.desktopservices (1.12.5 - 1.12.5) <96BB57E2-3359-3920-AA7C-BF03C2225485> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff5f58e000 -     0x7fff5f592ff7  com.apple.DisplayServicesFW (3.1 - 380) <921A2830-1A66-396E-A689-CD85B4B8F82C> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
        0x7fff600d5000 -     0x7fff60503fff  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <06065DA3-4091-3682-A308-BF3F2E3E4AF8> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
        0x7fff637b3000 -     0x7fff637befff  libGPUSupport.dylib (16.7.4) <16E276E6-27A7-36AF-A8B5-883E16B95A3A> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
        0x7fff637cb000 -     0x7fff637d0fff  com.apple.GPUWrangler (3.20.18 - 3.20.18) <B54A9063-01EC-3D2C-8924-86A1F315DEA2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
        0x7fff63b84000 -     0x7fff63ba9ff3  com.apple.GenerationalStorage (2.0 - 285.3) <0C898B63-E9A3-3D93-BB3D-CD54BFE51DED> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff63bc1000 -     0x7fff64503ff7  com.apple.GeoServices (1.0 - 1363.24.8.15.58) <9686AD86-FE07-3604-B91C-D372FF641E8E> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
        0x7fff64546000 -     0x7fff64555fff  com.apple.GraphVisualizer (1.0 - 5) <EB42FFAD-2BCA-3DE2-B40E-AFDE6E7FAA4D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
        0x7fff645d8000 -     0x7fff6464cfff  com.apple.Heimdal (4.0 - 2.0) <FF7BC1AE-1BA6-3150-A7CC-B9E0AD5EBE7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff6464d000 -     0x7fff6467bfff  com.apple.HelpData (2.3 - 167.2) <24A1E5D9-2801-36F4-9361-692467E5B615> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
        0x7fff64f5f000 -     0x7fff64f66ff7  com.apple.IOAccelerator (378.28 - 378.28) <F109E4CB-49D9-37FB-974A-8A3E9E8A61DA> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
        0x7fff64f6a000 -     0x7fff64f81fff  com.apple.IOPresentment (1.0 - 35.1) <AC89202B-8433-3B62-A7BE-467D1905F6FB> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
        0x7fff6534c000 -     0x7fff65372ffb  com.apple.IconServices (97.6 - 97.6) <7913A453-8D29-31DC-ADDB-7CEC068C9B86> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
        0x7fff6547f000 -     0x7fff65482ff3  com.apple.InternationalSupport (1.0 - 1) <D020C355-DCC1-3D7E-8FCE-BD6FF441824D> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
        0x7fff654f0000 -     0x7fff65500ffb  com.apple.IntlPreferences (2.0 - 227.5.2) <E036B12B-6017-3EF6-9E73-71DCE8036608> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
        0x7fff655f7000 -     0x7fff6560aff3  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <B999BEF6-F3E7-30EE-9177-FBC8E826659D> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
        0x7fff6560b000 -     0x7fff65700ff7  com.apple.LanguageModeling (1.0 - 159.5.3) <FAA236D6-CFB8-37D2-B635-B324E0719E32> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
        0x7fff65701000 -     0x7fff65743fff  com.apple.Lexicon-framework (1.0 - 33.5) <F8DD2D09-5CEE-3741-93CF-223FC61FCCA4> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
        0x7fff65747000 -     0x7fff6574eff7  com.apple.LinguisticData (1.0 - 238.3) <6F2ED02A-2120-3ABA-8EC1-314E4FFE77F3> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
        0x7fff65f4f000 -     0x7fff65f52fff  com.apple.Mangrove (1.0 - 1) <471F4581-5235-3381-B16B-CE92ED6CF086> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
        0x7fff660a2000 -     0x7fff663cbff7  com.apple.MediaRemote (1.0 - 1) <1FE6F7B0-E949-36F3-9646-1B85BA1BAF20> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
        0x7fff663cc000 -     0x7fff663edfff  com.apple.MediaServices (1.0 - 1) <7AE9BD6D-594B-319E-A750-D0607150BAE1> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
        0x7fff66462000 -     0x7fff664cbff7  com.apple.gpusw.MetalTools (1.0 - 1) <F2A47319-0430-3BB5-943E-651A40C127A9> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
        0x7fff664d4000 -     0x7fff664ebff7  com.apple.MobileAssets (1.0 - 437.60.1) <94912D67-E290-3205-B919-C70C0A8D7FCF> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
        0x7fff6665b000 -     0x7fff66674fff  com.apple.MobileKeyBag (2.0 - 1.0) <9EA31672-3B83-3ABF-B2D5-8584E159051E> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
        0x7fff66700000 -     0x7fff6672affb  com.apple.MultitouchSupport.framework (1614.1 - 1614.1) <A376F2FB-64AE-3B35-88B0-7D2BB4D1CB7C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff66991000 -     0x7fff6699cfff  com.apple.NetAuth (6.2 - 6.2) <85C5D94D-C67E-36DC-B0EA-02F53AC4FCD3> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff66b6a000 -     0x7fff66b86ff3  com.apple.network.statistics.framework (1.2 - 1) <8F5EFA64-84BE-353E-8302-70239CD9A7AA> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics
        0x7fff68238000 -     0x7fff68248ffb  com.apple.PerformanceAnalysis (1.194 - 194) <B6934994-BD69-36F9-914E-6BBDCD797612> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff6a007000 -     0x7fff6a025fff  com.apple.ProtocolBuffer (1 - 260) <195906B1-1DB1-3AD2-B2F7-87B867C27F40> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
        0x7fff6a192000 -     0x7fff6a1a8ff7  com.apple.QuickLookThumbnailing (1.0 - 1) <043881FB-D325-3145-99B9-B9307AF99365> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
        0x7fff6a1f3000 -     0x7fff6a1fffff  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.70.16) <AEAA88C6-CBB6-3598-9548-E4DF155B4A64> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
        0x7fff6a200000 -     0x7fff6a223ffb  com.apple.RemoteViewServices (2.0 - 125) <695CBF89-C15C-3E4C-8045-B46DCA64E3FB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff6a224000 -     0x7fff6a239ff3  com.apple.xpc.RemoteXPC (1.0 - 1205.70.16) <DD597F26-6BBE-3DAD-9257-7A5FCD60C109> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
        0x7fff6ba01000 -     0x7fff6ba04ff3  com.apple.SecCodeWrapper (4.0 - 360.50.7) <E6281F4F-9A07-3098-A352-7AC41CF942A4> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
        0x7fff6bb49000 -     0x7fff6bc5eff7  com.apple.Sharing (1050.22.9 - 1050.22.9) <CAB71093-B187-363E-BBAA-B0D23D7642AA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
        0x7fff6bc5f000 -     0x7fff6bc7eff7  com.apple.shortcut (2.16 - 99) <A09B7F96-21BE-3C5D-AA59-B657F68D84BB> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
        0x7fff6bc89000 -     0x7fff6bc8aff7  com.apple.performance.SignpostNotification (1.2.6 - 2.6) <E77879A4-B040-3BE0-86F5-98173A4100AD> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
        0x7fff6c9e8000 -     0x7fff6cc85fff  com.apple.SkyLight (1.600.0 - 312.103.12) <A65B547C-B7CA-3E33-A0C5-58AB436A8467> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fff6d44e000 -     0x7fff6d45bfff  com.apple.SpeechRecognitionCore (4.6.1 - 4.6.1) <90CDCEAD-5A65-3C35-9370-2B306895E97C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
        0x7fff6d908000 -     0x7fff6d92ffff  com.apple.StreamingZip (1.0 - 1) <B5C3D9D6-B1DC-33E5-B7D2-ADAF3E0CA30E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
        0x7fff6e001000 -     0x7fff6e08afc7  com.apple.Symbolication (9.3 - 64033) <F576D527-4CB1-34A5-B15E-1130833EEDAB> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff6e5fb000 -     0x7fff6e603ff7  com.apple.TCC (1.0 - 1) <9D5466C6-A8B6-3C24-A791-6506B81D9998> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff6e810000 -     0x7fff6e8cdff7  com.apple.TextureIO (3.7 - 3.7) <32C460CD-E93D-3FA5-A4AE-CA648722F5FE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
        0x7fff6e977000 -     0x7fff6e978fff  com.apple.TrustEvaluationAgent (2.0 - 31) <D88126F5-BF35-30FB-BAC2-B804D7EB65B0> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff6e97e000 -     0x7fff6eb2efff  com.apple.UIFoundation (1.0 - 547.9) <D0994333-5EB4-3415-8D18-2A0487AE91E0> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
        0x7fff6f803000 -     0x7fff6f8d2ff7  com.apple.ViewBridge (343.2 - 343.2) <0A295791-B763-3E58-A9DD-8E4F40E815C9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff702aa000 -     0x7fff702acffb  com.apple.loginsupport (1.0 - 1) <E273A65A-6379-3787-B119-BC6ED94D4A81> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
        0x7fff70413000 -     0x7fff70446ff7  libclosured.dylib (551.5) <112BC241-6626-3848-8DD8-B34B5B6F7ABC> /usr/lib/closure/libclosured.dylib
        0x7fff70500000 -     0x7fff70539ff7  libCRFSuite.dylib (41) <14B00FCF-4C67-3736-95B5-76FEA6E4972C> /usr/lib/libCRFSuite.dylib
        0x7fff7053a000 -     0x7fff70545fff  libChineseTokenizer.dylib (28) <2237A259-0E59-3DD0-BADC-281C361FAB70> /usr/lib/libChineseTokenizer.dylib
        0x7fff705d7000 -     0x7fff705d8ff3  libDiagnosticMessagesClient.dylib (104) <3F855622-352B-3EA8-B7C8-94D1DB48C080> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff7060f000 -     0x7fff707d9ff3  libFosl_dynamic.dylib (17.8) <1A2A9D53-129E-3F7D-AE23-1D6E6D9EA017> /usr/lib/libFosl_dynamic.dylib
        0x7fff707f9000 -     0x7fff70800fff  libMatch.1.dylib (31) <7C8FF628-4B3B-3D63-AAEB-B85F41361DFC> /usr/lib/libMatch.1.dylib
        0x7fff70811000 -     0x7fff70811fff  libOpenScriptingUtil.dylib (174) <AC38B2C3-5A37-30EB-A246-CEFABD3DD4E7> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff70948000 -     0x7fff7094cffb  libScreenReader.dylib (562.18.5) <FFB20E40-7669-30F6-8577-B74E18076376> /usr/lib/libScreenReader.dylib
        0x7fff7094d000 -     0x7fff7094effb  libSystem.B.dylib (1252.50.4) <5A02016C-8F9D-3F47-8C39-AD2CD4F9F11D> /usr/lib/libSystem.B.dylib
        0x7fff709e1000 -     0x7fff709e1fff  libapple_crypto.dylib (109.50.15) <A8DEA8E9-5769-3C78-824D-969A98B94086> /usr/lib/libapple_crypto.dylib
        0x7fff709e2000 -     0x7fff709f8ff7  libapple_nghttp2.dylib (1.24) <24338D88-5D73-3165-9CFB-5A92734C9040> /usr/lib/libapple_nghttp2.dylib
        0x7fff709f9000 -     0x7fff70a23ff3  libarchive.2.dylib (54) <D2B6AD30-18CB-3E3C-ABBF-A0745654350F> /usr/lib/libarchive.2.dylib
        0x7fff70a24000 -     0x7fff70b27fe7  libate.dylib (1.13.1) <D828353D-3D64-30E3-970F-8D295407610D> /usr/lib/libate.dylib
        0x7fff70b2b000 -     0x7fff70b2bff3  libauto.dylib (187) <92E693DF-D74D-39A0-99AB-8A9F6FFEBA18> /usr/lib/libauto.dylib
        0x7fff70b2c000 -     0x7fff70be5ffb  libboringssl.dylib (109.50.15) <FC25FE02-6AA8-3F0B-9EF3-56A455C08C0F> /usr/lib/libboringssl.dylib
        0x7fff70be6000 -     0x7fff70bf6ff3  libbsm.0.dylib (39) <18D57879-A717-3466-9637-1704EE59A32A> /usr/lib/libbsm.0.dylib
        0x7fff70bf7000 -     0x7fff70c04ffb  libbz2.1.0.dylib (38) <0B4321CD-3D6F-3095-A12E-27F66B4321AD> /usr/lib/libbz2.1.0.dylib
        0x7fff70c05000 -     0x7fff70c5bfff  libc++.1.dylib (400.9) <142D6292-F30F-3949-9F37-3C97A579F540> /usr/lib/libc++.1.dylib
        0x7fff70c5c000 -     0x7fff70c80ff7  libc++abi.dylib (400.8.2) <EF5E37D7-11D9-3530-BE45-B986612D13E2> /usr/lib/libc++abi.dylib
        0x7fff70c82000 -     0x7fff70c92fff  libcmph.dylib (6) <890DEC4C-4334-393C-8B56-7C8560BBED9D> /usr/lib/libcmph.dylib
        0x7fff70c93000 -     0x7fff70caafd3  libcompression.dylib (47.60.2) <CC7ACB0A-49CD-3564-978F-49F843186F27> /usr/lib/libcompression.dylib
        0x7fff70f55000 -     0x7fff70f6dff7  libcoretls.dylib (155.50.1) <087E9F90-21E5-376D-9956-C4E346409682> /usr/lib/libcoretls.dylib
        0x7fff70f6e000 -     0x7fff70f6fff3  libcoretls_cfhelpers.dylib (155.50.1) <78CCDD10-7D71-365E-A0A5-8524ED5F5BF9> /usr/lib/libcoretls_cfhelpers.dylib
        0x7fff71108000 -     0x7fff71299fff  libcrypto.35.dylib (22.50.3) <6E609F99-59BC-3AEA-9DB3-FD360A2C50CC> /usr/lib/libcrypto.35.dylib
        0x7fff71440000 -     0x7fff71495ff3  libcups.2.dylib (462.2.10) <590D6ACC-68A0-371E-8646-FC59F814534B> /usr/lib/libcups.2.dylib
        0x7fff715d5000 -     0x7fff715d5fff  libenergytrace.dylib (16) <1F11D488-07C6-3D18-BEF2-0B28A992D761> /usr/lib/libenergytrace.dylib
        0x7fff715d6000 -     0x7fff715efff3  libexpat.1.dylib (16.1.1.1) <BF67821E-1B05-3E26-9EE9-4366CC0DAD03> /usr/lib/libexpat.1.dylib
        0x7fff7160c000 -     0x7fff71611ff3  libheimdal-asn1.dylib (520.50.9) <EF65C17E-31CD-31DC-876C-BF3EF393099C> /usr/lib/libheimdal-asn1.dylib
        0x7fff7163d000 -     0x7fff7172eff7  libiconv.2.dylib (51.50.1) <7965B866-C75A-3450-9891-0500349F7090> /usr/lib/libiconv.2.dylib
        0x7fff7172f000 -     0x7fff71956ffb  libicucore.A.dylib (59181.0.1) <17767680-09DF-3954-AB6C-B13B41F92A2E> /usr/lib/libicucore.A.dylib
        0x7fff719a3000 -     0x7fff719a4fff  liblangid.dylib (128) <C54A2059-A4BE-364B-94C2-581C548459BC> /usr/lib/liblangid.dylib
        0x7fff719a5000 -     0x7fff719beffb  liblzma.5.dylib (10) <60BEAB81-CE65-3479-90CC-03325AACEC95> /usr/lib/liblzma.5.dylib
        0x7fff719bf000 -     0x7fff719d5ff7  libmarisa.dylib (9) <47540053-02CF-35F8-A75E-074DB3D51812> /usr/lib/libmarisa.dylib
        0x7fff71a86000 -     0x7fff71caeff7  libmecabra.dylib (779.7.6) <B2ACB6A9-91AE-364B-9418-8EB938BF82B6> /usr/lib/libmecabra.dylib
        0x7fff71e86000 -     0x7fff72001fff  libnetwork.dylib (1229.70.2) <0596A03E-C984-3FE6-B88E-63D5F96EC49A> /usr/lib/libnetwork.dylib
        0x7fff72088000 -     0x7fff724793b7  libobjc.A.dylib (723) <616AB826-9179-3924-AA61-AF760363A3F5> /usr/lib/libobjc.A.dylib
        0x7fff7248c000 -     0x7fff72490fff  libpam.2.dylib (22) <E5840D63-8506-301A-9182-5000031854E1> /usr/lib/libpam.2.dylib
        0x7fff72493000 -     0x7fff724cbff7  libpcap.A.dylib (79.20.3) <6A9D27FA-2780-3E96-8B2E-645638AC13AC> /usr/lib/libpcap.A.dylib
        0x7fff72516000 -     0x7fff72519ff7  libpmenergy.dylib (187.70.3) <9CEC72DF-8C39-3DE3-84AE-4ECE0D628FA8> /usr/lib/libpmenergy.dylib
        0x7fff7251a000 -     0x7fff7251cfff  libpmsample.dylib (187.70.3) <8D8C4D79-1AE5-3820-A058-DF9A8F80B614> /usr/lib/libpmsample.dylib
        0x7fff7254a000 -     0x7fff72566ffb  libresolv.9.dylib (65.1) <D9BB6307-71E4-3A94-A745-1FCA114C6894> /usr/lib/libresolv.9.dylib
        0x7fff72568000 -     0x7fff725a1ff3  libsandbox.1.dylib (765.70.2) <2EF407AA-45B0-3E54-83B7-CA40F778FACA> /usr/lib/libsandbox.1.dylib
        0x7fff725b5000 -     0x7fff725b6ff3  libspindump.dylib (252) <7BE3801C-F1F5-3F54-AB70-9842F8EF3F09> /usr/lib/libspindump.dylib
        0x7fff725b7000 -     0x7fff72744ff7  libsqlite3.dylib (274.8.1) <B70A2908-E0F7-364E-952A-1D2D19787B89> /usr/lib/libsqlite3.dylib
        0x7fff72918000 -     0x7fff72978ff3  libusrtcp.dylib (1229.70.2) <1E065228-D0E3-3808-9405-894056C6BEC0> /usr/lib/libusrtcp.dylib
        0x7fff72979000 -     0x7fff7297cffb  libutil.dylib (51.20.1) <A50E15F1-20A2-3EA7-A8CE-A43662E18587> /usr/lib/libutil.dylib
        0x7fff7297d000 -     0x7fff7298aff3  libxar.1.dylib (417.1) <351781D5-3CCF-320F-BB5A-4DFCC1CCD31D> /usr/lib/libxar.1.dylib
        0x7fff7298e000 -     0x7fff72a75ffb  libxml2.2.dylib (31.20) <286F8531-7001-3989-9640-284443355433> /usr/lib/libxml2.2.dylib
        0x7fff72a76000 -     0x7fff72a9efff  libxslt.1.dylib (15.16) <57D56366-1E7B-356C-B2B8-F4688FF666E6> /usr/lib/libxslt.1.dylib
        0x7fff72a9f000 -     0x7fff72ab1ffb  libz.1.dylib (70) <47278BDC-596E-3037-B8DA-05FE9D5DBEF6> /usr/lib/libz.1.dylib
        0x7fff72b4d000 -     0x7fff72b51ff7  libcache.dylib (80) <096D3699-58D2-3D23-9512-BC88DAE7B16C> /usr/lib/system/libcache.dylib
        0x7fff72b52000 -     0x7fff72b5cff3  libcommonCrypto.dylib (60118.50.1) <B4E77BD4-A809-37E1-8A79-25955E0F5D9C> /usr/lib/system/libcommonCrypto.dylib
        0x7fff72b5d000 -     0x7fff72b64fff  libcompiler_rt.dylib (62) <4CEED002-D00B-35F8-B563-0546A5F71A43> /usr/lib/system/libcompiler_rt.dylib
        0x7fff72b65000 -     0x7fff72b6effb  libcopyfile.dylib (146.50.5) <F7A7999F-9509-3C67-8EE9-95BEE6772676> /usr/lib/system/libcopyfile.dylib
        0x7fff72b6f000 -     0x7fff72bf4ffb  libcorecrypto.dylib (562.70.3) <9C6E5CC2-272B-3740-AEDB-9EBEC98EC7F9> /usr/lib/system/libcorecrypto.dylib
        0x7fff72c7c000 -     0x7fff72cb5ff7  libdispatch.dylib (913.60.3) <285526B6-A2A6-316D-A1CC-37803B71E203> /usr/lib/system/libdispatch.dylib
        0x7fff72cb6000 -     0x7fff72cd3ff7  libdyld.dylib (551.5) <49ABA86D-DD48-3133-9B14-B9A564EEBC66> /usr/lib/system/libdyld.dylib
        0x7fff72cd4000 -     0x7fff72cd4ffb  libkeymgr.dylib (28) <7CC7B5E1-AB7F-3495-A26A-396461BCB66B> /usr/lib/system/libkeymgr.dylib
        0x7fff72cd5000 -     0x7fff72ce1ff3  libkxld.dylib (4570.71.82.8) <44AF05D7-6BDF-3A9B-B5CF-D16C98B6844E> /usr/lib/system/libkxld.dylib
        0x7fff72ce2000 -     0x7fff72ce2ff7  liblaunch.dylib (1205.70.16) <265EE555-E988-3EE5-A39E-028FB3A5FE11> /usr/lib/system/liblaunch.dylib
        0x7fff72ce3000 -     0x7fff72ce7ffb  libmacho.dylib (906) <F5F16E2F-F961-3FF4-B02F-69BBDB57B8DC> /usr/lib/system/libmacho.dylib
        0x7fff72ce8000 -     0x7fff72ceafff  libquarantine.dylib (86.70.1) <262CECFE-A493-3EC6-8608-CEA93757265E> /usr/lib/system/libquarantine.dylib
        0x7fff72ceb000 -     0x7fff72cecff3  libremovefile.dylib (45) <EA24BFB6-24B7-3841-8AAC-FAF400910706> /usr/lib/system/libremovefile.dylib
        0x7fff72ced000 -     0x7fff72d04fff  libsystem_asl.dylib (356.70.1) <9481D82D-CFB7-3032-A07F-88F7F59CAC2C> /usr/lib/system/libsystem_asl.dylib
        0x7fff72d05000 -     0x7fff72d05fff  libsystem_blocks.dylib (67) <FA2C3663-9DBB-3AFB-80A3-E77BE0816AD0> /usr/lib/system/libsystem_blocks.dylib
        0x7fff72d06000 -     0x7fff72d8fff7  libsystem_c.dylib (1244.50.9) <25DD83D8-80CA-3DFF-8626-FE704911F19C> /usr/lib/system/libsystem_c.dylib
        0x7fff72d90000 -     0x7fff72d93ffb  libsystem_configuration.dylib (963.50.9) <61B26E1D-FEFF-38C6-AE0E-A6DD90145EB2> /usr/lib/system/libsystem_configuration.dylib
        0x7fff72d94000 -     0x7fff72d97ffb  libsystem_coreservices.dylib (51) <E8FA663F-1B0F-3B12-8F97-31A46E6B4D68> /usr/lib/system/libsystem_coreservices.dylib
        0x7fff72d98000 -     0x7fff72d99fff  libsystem_darwin.dylib (1244.50.9) <6195EEA1-83A7-35F0-8147-5AB031020CD0> /usr/lib/system/libsystem_darwin.dylib
        0x7fff72d9a000 -     0x7fff72da0ffb  libsystem_dnssd.dylib (878.70.4) <0D2C9583-5D28-375B-AEB4-F66F18C78322> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff72da1000 -     0x7fff72deaff7  libsystem_info.dylib (517.30.1) <9C2C96F3-638B-34E7-A2BD-24C643EAF957> /usr/lib/system/libsystem_info.dylib
        0x7fff72deb000 -     0x7fff72e11ff7  libsystem_kernel.dylib (4570.71.82.8) <C34BA704-FAFF-3DDB-9827-5930B5BEF134> /usr/lib/system/libsystem_kernel.dylib
        0x7fff72e12000 -     0x7fff72e5dfcb  libsystem_m.dylib (3147.50.1) <B3172533-77D2-3416-8487-4A505198E9E1> /usr/lib/system/libsystem_m.dylib
        0x7fff72e5e000 -     0x7fff72e7dff7  libsystem_malloc.dylib (140.50.7) <821E16C8-7A7E-3269-9167-10F4F413BF93> /usr/lib/system/libsystem_malloc.dylib
        0x7fff72e7e000 -     0x7fff72faeff7  libsystem_network.dylib (1229.70.2) <07BFD80A-E7EB-3DEB-B765-5E1659453114> /usr/lib/system/libsystem_network.dylib
        0x7fff72faf000 -     0x7fff72fb9ffb  libsystem_networkextension.dylib (767.70.2) <A90BAFFD-AC3D-3078-90B2-71463DBFD4A5> /usr/lib/system/libsystem_networkextension.dylib
        0x7fff72fba000 -     0x7fff72fc3ff3  libsystem_notify.dylib (172) <738B3BB0-4F20-3446-A3B6-095D796E5903> /usr/lib/system/libsystem_notify.dylib
        0x7fff72fc4000 -     0x7fff72fcbff7  libsystem_platform.dylib (161.50.1) <90A2A62F-8690-3FA7-A4D0-9085BF2FA44A> /usr/lib/system/libsystem_platform.dylib
        0x7fff72fcc000 -     0x7fff72fd7fff  libsystem_pthread.dylib (301.50.1) <283E64A7-A2B2-3212-95BA-4D21F9AE36CF> /usr/lib/system/libsystem_pthread.dylib
        0x7fff72fd8000 -     0x7fff72fdbfff  libsystem_sandbox.dylib (765.70.2) <C29E1B7A-F39B-344E-98F7-8FB32B10AE0A> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff72fdc000 -     0x7fff72fddff3  libsystem_secinit.dylib (30) <4E84DF62-57B5-36F9-819F-3C1E7FEDA856> /usr/lib/system/libsystem_secinit.dylib
        0x7fff72fde000 -     0x7fff72fe5ff7  libsystem_symptoms.dylib (820.60.3) <A45B4D84-2C69-3F19-83C2-2F1EEA73A7B5> /usr/lib/system/libsystem_symptoms.dylib
        0x7fff72fe6000 -     0x7fff72ffaff7  libsystem_trace.dylib (829.70.2) <4C4E5351-E370-3226-9B30-61E250DE3B2E> /usr/lib/system/libsystem_trace.dylib
        0x7fff72ffc000 -     0x7fff73001ff7  libunwind.dylib (35.3) <BAE12DA3-CF33-32AD-86B0-CCD6705ADFAA> /usr/lib/system/libunwind.dylib
        0x7fff73002000 -     0x7fff7302ffff  libxpc.dylib (1205.70.16) <26D99819-B813-320E-9E8F-9D57AD2DA63B> /usr/lib/system/libxpc.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 3471
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=547.0M resident=0K(0%) swapped_out_or_unallocated=547.0M(100%)
    Writable regions: Total=539.3M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=539.3M(100%)
                                    VIRTUAL   REGION
    REGION TYPE                        SIZE    COUNT (non-coalesced)
    Accelerate framework               256K        3
    Activity Tracing                   256K        2
    CG backing stores                  248K        3
    CG image                            40K        6
    CoreAnimation                       24K        5
    CoreImage                           12K        4
    CoreUI image data                  664K        9
    CoreUI image file                  180K        4
    Foundation                          28K        3
    IOKit                             15.5M        2
    Image IO                             8K        2
    Kernel Alloc Once                    8K        2
    MALLOC                           326.9M      120
    MALLOC guard page                   48K       11
    Mach message                        32K        7
    Memory Tag 242                      12K        2
    Memory Tag 255                     4.0G       58
    OpenGL GLSL                        256K        4
    STACK GUARD                       56.1M       29
    Stack                            185.8M       29
    VM_ALLOCATE                       14.6M       27
    __DATA                            59.9M      306
    __FONT_DATA                          4K        2
    __GLSLBUILTINS                    2588K        2
    __LINKEDIT                       199.1M       12
    __TEXT                           347.9M      307
    __UNICODE                          560K        2
    mapped file                       67.7M       31
    shared memory                      684K       10
    TOTAL                              5.2G      975
    Model: MacBookPro6,2, BootROM 99.0.0.0.0, 2 processors, Intel Core i5, 2.4 GHz, 8 GB, SMC 1.58f17
    Graphics: Intel HD Graphics, Intel HD Graphics, Built-In
    Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393955353432382D3034362E4130304C4620
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393955353432382D3034362E4130304C4620
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.102.30)
    Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: ST1000LM014-1EJ164, 1 TB
    Serial ATA Device: Samsung SSD 850 EVO 1TB, 1 TB
    USB Device: USB 2.0 Bus
    USB Device: Hub
    USB Device: Internal Memory Card Reader
    USB Device: Apple Internal Keyboard / Trackpad
    USB Device: BRCM2070 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: Hub
    USB Device: IR Receiver
    USB Device: Built-in iSight
    Thunderbolt Bus:
    GDD
    Re: BME AI Studio on Mac
    I uninstalled Brew, Macports. This did not fix anything.
    I created a new user. This did not fix anything.
    I downloaded a fresh High Sierra image and created a VirtualBox High Sierra. BME AI Studio also did not run in a CLEAN high sierra environment.
    So, I think I know the answer to this one... [tough luck huh? Why don't you go buy a new MacBook Pro and leave us alone!]
