    BME280 Data to test Calculations
    Could someone please send me some the raw calibration values, and the raw register values for the Temperature/Pressure/Humidity for the BME280.
    With also the correct calculated Temperature/Pressure/Humidity readings?
    I would like to test my calculations as I think my pressure calculations are incorrect.
    8 REPLIES 8
    Re: BME280 Data to test Calculations
    Thanks for the link. I had seen (and used) the excel form already. What I needed was the Raw (Hex) data which is returned from the BME280, unfortunatley the sheet does not have this.
    The issue I have is that the BME280 returns a high pressure reading, the form also shows this so it is not my calculations. Is the sensor faulty?
    The temperature is correct, and humidity I don't have anything to check against.
    The Raw values are:
    Calibration:
    0x6C, 0x6E, 0x77, 0x66, 0x32, 0x00, 0xA8, 0x92, 0x27, 0xD5, 0xD0,
    0x0B, 0x6F, 0x18, 0xCA, 0xFF, 0xF9, 0xFF, 0xAC, 0x26, 0x0A, 0xD8,
    0xBD, 0x10, 0x4B, 0x65, 0x01, 0x00, 0x14, 0x0B, 0x00, 0x1E
    Temp/Press?Humidity:
    0x55, 0x33, 0x80, 0x81, 0x7F, 0xB0, 0x79, 0x13
    Calculations are:
    +24.44°C
    1148.38hPa
    54.17%rH
    Settings are:
    0xF5 = 0b10101000  ' Config Setting (1000ms Standby, IIR Filter @ 4)
    0xF2 = 0b00000010  ' Humidity Setting (x2 Oversampling)
    0xF4 = 0b01001011 ' Temp/Pres Settings (x2 Oversampling, Normal Mode)
    Do my settings/data look correct?
    Could it be a faulty sensor, or am I missing something?
    Hi Badger,
    The data that you provided does not specify which value corresponds to which calibration register. I could not decode the calibration data.
