Could someone please send me some the raw calibration values, and the raw register values for the Temperature/Pressure/Humidity for the BME280.
With also the correct calculated Temperature/Pressure/Humidity readings?
I would like to test my calculations as I think my pressure calculations are incorrect.
Thanks!
Thanks for the link. I had seen (and used) the excel form already. What I needed was the Raw (Hex) data which is returned from the BME280, unfortunatley the sheet does not have this.
The issue I have is that the BME280 returns a high pressure reading, the form also shows this so it is not my calculations. Is the sensor faulty?
The temperature is correct, and humidity I don't have anything to check against.
The Raw values are:
Calibration:
0x6C, 0x6E, 0x77, 0x66, 0x32, 0x00, 0xA8, 0x92, 0x27, 0xD5, 0xD0,
0x0B, 0x6F, 0x18, 0xCA, 0xFF, 0xF9, 0xFF, 0xAC, 0x26, 0x0A, 0xD8,
0xBD, 0x10, 0x4B, 0x65, 0x01, 0x00, 0x14, 0x0B, 0x00, 0x1E
Temp/Press?Humidity:
0x55, 0x33, 0x80, 0x81, 0x7F, 0xB0, 0x79, 0x13
Calculations are:
+24.44°C
1148.38hPa
54.17%rH
Settings are:
0xF5 = 0b10101000 ' Config Setting (1000ms Standby, IIR Filter @ 4)
0xF2 = 0b00000010 ' Humidity Setting (x2 Oversampling)
0xF4 = 0b01001011 ' Temp/Pres Settings (x2 Oversampling, Normal Mode)
Regards,
Do my settings/data look correct?
Could it be a faulty sensor, or am I missing something?
