    BME280 SENSOR
    BME280 SENSOR
    PranithaReddy
    I have gone through the data sheet of BME280 in that there are configurations related to sensor enable and disable like shut off the sensor which is not needed like if i need temperature I need to disable the rest two.So can you please help me in debuuging thiS problem in code.
    Thank you
    K.Pranitha Reddy
    2 REPLIES 2
    Hi PranithaReddy,
    You could refer the following example code on github code https://github.com/boschsensortec/BME280_driver/blob/master/examples/bsd_userspace.c
    settings_sel = BME280_OSR_PRESS_SEL | BME280_OSR_TEMP_SEL | BME280_OSR_HUM_SEL | BME280_FILTER_SEL;
    rslt = bme280_set_sensor_settings(settings_sel, dev);
    Sorry for the delay I went through the source code which you asked me to refer in that bsd_userpspace.c file there is  no such function called settings_sel. I want to make my requirement more clear by addressing it once again. I want the solution for configuring individual sensors like for example  only temperature rest of the two sensors like pressure and humdity should be disabled. Can you please provide the solution.
    Thank You
    K. Pranitha Reddy
