    BME280 Temperature Compensation Issue
    Theorem25
    I'm using the BME280 for a project, and is having hard time converting the sensor's ADC temperature value into "human" readable temperature, the values always off. I'm not sure whether the issue is with the compensation equations or somewhere else.  I'm able to write and read data back and forth between the  BME280 sensor and the microcontroller.
    Below are sample pictures of the I2C communication
    Get VersionGet VersionRaw Temp and PressureRaw Temp and PressureRead Calibration ValuesRead Calibration Values
    Compensation Equations to convert raw ADC value into human readable temperature. For instance, the UT value  at this moment in time  is 0x00086b2b. After that value went throught the equations, the t_fine_temp value is 0x00000594 or 1428 in decimal which is 14.28 degree C which i think is incorrect. Unfortunately, i don't know what the correct value should be.
    int32_t BME280_CalcT(int32_t UT)
    #if 1
    	volatile sLWord t_fine_temp = 0x0000;
    	volatile sLWord t_fine_temp2= 0x0000;
    	//int32_t t_fine_temp3;
    	//int32_t t_fine_1;
    #if 1
    	t_fine_temp  = ((((UT >> 3) - ((sLWord)cal_param.dig_T1 << 1))) * ((sLWord)cal_param.dig_T2)) >> 11;
    	t_fine_temp2 = (((((UT >> 4) - ((sLWord)cal_param.dig_T1)) * ((UT >> 4) - ((sLWord)cal_param.dig_T1))) >> 12) * ((sLWord)cal_param.dig_T3)) >> 14;
    	t_fine_temp += t_fine_temp2;
    	t_fine_temp = ((t_fine_temp * 5) + 128) >> 8;
    #endif
    	return t_fine_temp;
    #endif
    cal_param	0x00000116	0x000116`Ram
    	dig_T1	0x596f	0x000116`Ram
    	dig_T2	0x1067	0x000118`Ram
    	dig_T3	0x3200	0x00011a`Ram
    Can anyone show me where thing went wrong ?
    Thank you very much
    Vu
    10 REPLIES 10
    Hi All,
    Thank you all very much for the help.
    Sincerely,
    Vu
