09-04-2020 04:17 PM
Has anyone used the BME280 driver on a 8 or 16 bit micro(SiLabs, PIC...etc)? If so, can you point me in the general direction of how you approached this? Thanks so much.
09-08-2020 03:40 AM
You means that you need a success solution that already use BME680 with 8/16 bit MCU, is that right?
Best regards.
09-18-2020 10:12 PM
THe 280. There are tons of "drivers" out there for it using the RPI or 32bit ARM cores. I just haven't found anything for an 8 bit micro. I just wanted to hear from someone that's developed one to get an indication on any pitfalls I might encounter.
08-30-2023 05:54 AM
I made Temprature/Humidity/Presser indicator by PIC12F1840 as picture.
If you need additional information, please let me know.
** I could privide source code if you need.
However, I have one bug in my souce code that is indicating wrong figure in temprature when it is under 0 degree.
I tried to find out how to fix this bug and find this community.
Still I could not find out how to fix the bug,,,,,
