    BME280 output reading not changing
    Highlighted
    Hello!
    I have some BME280 sensors reading on a custom board, however, the signals have not been correct with the library driver and I am looking for technical support for it.
    I have installed the software from your github: https://github.com/BoschSensortec/BME280_driver and follow along with the instructions. I downloaded this 02/13/2020, so the library should be up-to-date.
    I am controlling the BME through SPI and Particle board (C++), I haven't changed anything in the driver file yet but here are the SPI signal readings from the SPI_READ functions declared in the main script.
    Please let me know what could be the issue.
    Another questions I have is that I was wondering if you can provide the equations to convert analog signals to temperature/pressure/humidity. I cannot seem to find a clear equation in the datasheet or any sort of documentation.
    Please let me know how I can resolve this. thank you!
    2 REPLIES 2
    Highlighted
    Re: BME280 output reading not changing
    Hello!
    I looked into the signals that it is reading and noticed that the data collect burst read for register 0xF7 shows default (0x800000 0x800000 0x8000)
    Here is a sample of the signal read/write that the driver is initiating and what the signal output is:
    Please let me know why the data readings are not started, the device is connected, and is responding as BME280_OK (0).
    Tags (3)
    Highlighted
    Could you please share a code snippet of your project (at least BME280 configuration and data read-out)? From your description alone, it seems like you may trigger only one measurement (e.g. setting the BME280 to forced mode will trigger a single measure then go back to sleep mode), then reading-out this data sample multiple times.
    You can find the reference implementation directly in the sensor API you linked (e.g. BME280 humidity formula in floating point).
