    BME280 pressure reading wrong
    jlehman
    I am using the BME280 to get temp, pressure and humidity in demand mode 1/sec. I have over sampling for each parameter set to 1. Temp and humidity  work. The pressure should be around 1020 but comes back around 630. Sometimes I get the correct value but most of the  time it is stuck in the 630s. Any idea what I am doing wrong? I am using the 64 bit compensation functions from the data sheet.
    6 REPLIES 6
    Found my problem.  The write function was using an uninitialized stack value, causing random values to be sent to the control registers of the BMS280.
    Hey I am also facing the same issue,can you tell me where exactly in the write function
