02-23-2019 11:56 PM
I have a couple of questions realted to BSEC 1.4.7.2 installation in Arduino ESP8266 (2.4.2 and 2.5.0):
1. Executed all the steps from Integration Guidelines for Arduino platforms.pdf. the library seems to be properly installed, the examples can be compiled without warnings and downloladed to the target platform. However, all the examples display the following error message after loading:
BSEC library version 1.4.7.1 BME680 error code : -2
- Any clue why the target displays version 1.4.7.1 instead of 1.4.7.2 which was downloaded and installed? 1.4.7.2 is the only library installed in my Arduino setup.
- Any idea why error code: -2 is reported for every example? The same HW setup works without any issues with Adafruit BME680 library.
2. Why are there two different versions of bsec_dataset.h and bsec_interface.h inclued in BSEC library distribution? Which version of these files should be installed in Arduino setup? The ones that come with the libalgobsec.a (from \BSEC_1.4.7.2_Generic_Release_20190122.zip\algo\bin\Normal_version\esp8266) or the ones from BSEC_1.4.7.2_Generic_Release_20190122.zip\Arduino\BSEC\src\inc?
3. Has anyone successfully run BSEC examples on NodeMCU/Wemos HW?
Regards
rbx
02-24-2019 11:59 AM
it is running fine here (and stable (more or less - see other posts) with Wemos D1 mini.
Have you checked the I2C address?
-> iaqSensor.begin(BME680_I2C_ADDR_PRIMARY, Wire);
in ben680_defs.h:
#define BME680_I2C_ADDR_PRIMARY UINT8_C(0x76) #define BME680_I2C_ADDR_SECONDARY UINT8_C(0x77)
I'm using the files from ...Arduino\BSEC\src\inc
Have you any more debug info?
03-05-2019 11:10 PM
Hi, I manage to resolve my problem. It was related to Wire object initialization - i.e. Wire.begin(I2C_PIN_SDA, I2C_PIN_SCL) was missing for I2C configuration. Once I added this to setup(), everything seems to be working fine.
Regards
rbx
04-04-2019 11:14 AM
please i am stuck in the same problem. I dont understand how to modify Basic library example to make it works. My bme680 address is 0x77 that match Secondary address. I tried to add a Wire.begin but no success.
04-08-2019 06:48 PM
Have you tried following the suggestion in this comment above? That would mean for example to initialize the library with the secondary address instead of the primary by default:
iaqSensor.begin(BME680_I2C_ADDR_SECONDARY, Wire);
Otherwise it would be great if you could share more details about your setup, including hardware used, schematic, code snippet, etc.
