    BME680 BSEC library for Microchip PIC32 microcontrollers
    emm
    I require the Bosch BSEC library for the BME680, to run on Microchip PIC32 microcontrollers.
    Is there a BSEC library version compatible with Microchip's C32 or XC32 compilers (NOT for the MikroC compiler)?
    I see that PIC32 is not included in the table here: https://www.bosch-sensortec.com/bst/products/all_products/bsec
    However, I have found that the zip download contains a library file named "BSEC_1.4.7.3_Generic_Release\algo\bin\Normal_version\mplab\libalgobsec.a". The "mplab" suggests it is something related to Microchip. Is this library PIC32 or C32/XC32 compatible?
    o_o
    Contributor
    Not sure why it was included in this release, but the this Microchip build is made for the following part:
    MCU p/f: Microchip dsPIC33EP64MC202
    IDE environment: MPLAB v2.26
    Compiler: XC16 v1.23
    As PIC32 is not supported, I would recommend that you select a more common MCU architecture, such as ARM Cortex M series.
    emm
    Is Bosch able to provide an XC32 compatible library? This would be far more widely used than the MikroC library, which is provided.
    Otherwise, changing the sensor is a better solution than changing the MCU!
    o_o
    Contributor
    Unfortunately at this time, this time here is the list of supported architectures (May 2019):
    Platform Compiler ROM (BSEC) ROM (BSEC lite*) RAM TYPE
    Cortex-ARM ARMCC 19-20k 12-13k 1k Cortex-M0, M0+, M3, M4, M4_FPU, M7
    Cortex-ARM GCC 20-22k 12-14k 1k Cortex-M0, M0+, M3, M4, M4_FPU, M7
    Cortex-A* GCC 21k 13k 1k Cortex-A7
    AVR_8bit AVR-GCC 42k 25k 1k MegaAVR, XMEGA
    AVR_32bit AVR-GCC 24k 13k 1k 32-bit AVR UC3
    ESP8266 xtensa-lx106-elf-gcc 28k 17k 1k ESP8266
    ESP32 xtensa-esp32-elf-gcc 24k 14k 1k ESP32
    MSP430 msp430-elf-gcc 34k 20k 1k MSP430
    Android system-x86 gcc 39-49k 22-26k 1k x86, x86_64
    Android system-arm gcc 21-38k 13-19k 1k arm, arm64
    IAR gcc 20k 12-13k 1k Cortex-M0, M0+, M3, M4, M4_FPU, M7
    Raspberry PI0 linux arm-linux-
    gnueabihf-gcc
    71k 56k 1k armv6-32bits
    Raspberry PI3 linux arm-linux-
    gnueabihf-gcc
    72k 57k 1k armv8-a-64bits
    We support hundreds of microcontrollers and application processors that are the most popular at the moment.
