    BME680 Integer Compensation Routines
    Hello
    How to I convert the integer output of calc_temperature, calc_humidity and cal_pressure to a float with the correct units for each physical quantity?
    I want to use the integer routines to save memory on computation and then print out a converted float for each of temperature pressure and humidity only at the final stage before printing. I can't see how to make this conversation from integer to float and I don't want to use the versions of calc_temperature, calc_pressure and calc_humidity that output a float.
    Re: BME680 Integer Compensation Routines
    Thanks for sharing the link. It isn't clear to me what number I need to divide the integer output of the temperature conversion routine by to get a float I can print with units degrees Celcius. Is this documented anywhere as I cannot find it ?
    OK,  hope the following unit informatiion can help you.
    temperature unit is degree *100
    pressure unit is Pa
    relative humidity unit is Relative Humidity [%] * 1024
