I think you can refer to the following page
https://stackoverflow.com/questions/13530209/how-to-convert-int-to-float-in-c
Thanks for sharing the link. It isn't clear to me what number I need to divide the integer output of the temperature conversion routine by to get a float I can print with units degrees Celcius. Is this documented anywhere as I cannot find it ?
OK, hope the following unit informatiion can help you.
temperature unit is degree *100
pressure unit is Pa
relative humidity unit is Relative Humidity [%] * 1024
