    BME680 Lib issue: bsec_sensor_control(time_stamp, &sensor_settings);
    wcx8229
    I use myself board with STM32F030C8.
    I run the example code with configure generic_33v_3s_28d
    In function bsec_iot_loop(),  I get the struct sensor_settings value when first run bsec_sensor_control(time_stamp, &sensor_settings);
    but 3s later run bsec_sensor_control(time_stamp, &sensor_settings);  again,  struct sensor_settings value were changed to 0.
    can see my attachment picture.
    Can you give me some suggestion? Thank you!
    2 REPLIES 2
    wcx8229
    And,
    run  ret = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 0.0f, bus_write, bus_read, sleep, state_load, config_load); before bsec_sensor_control(time_stamp, &sensor_settings);    the value of sensor_settings looks like OK, but I don't confirm  if this process is corrected.
    wcx8229
    solved.
    My timer is not accurate for 3 seconds
