03-03-2020 09:58 AM
Hello there,
I am trying to use BME680 sensor with STM32 ARM Cortex F4 MCU, I succesfully implemented bme680 codes and it is working well, I can read temp, resistance, humidity and pressure values.
Than i proceed on implementing Bsec application, I succesfully added and compiled libalgobsec.a library file to Keil uVision. I tried to use source codes written for arduino, but i can not understand exactly how i get IAQ values and other user-level sensor outputs. Which function I need to call or what defines do I need.
I am very new at this forum, so i am sorry if any anomalius situation here by estabilishing this topic here. Thanks everyone, in advance.
03-03-2020 11:49 AM
The source code for Arduino is just one possible platform to run BSEC. If you are not using the Arduino IDE in your project, I would recommend that you take a look at the example code in the 'examples' folder of the BSEC release package, especially bsec_iot_example.c and bsec_integration.c/.h. I would also recommend you to have a look at the 'Integration Guide" application note (under the "integration_guide" folder).
05-06-2021 03:37 PM
From your post, I observed that you successfully integrated the BME680 with STM32. I am also trying to integrate BME680 with STM32F469 through STM32Cube IDE. Unfortunately, I encountered a problem while adding the compiled library "libalgobsec.a". Could you please guide me to add the compiled library. I attched the error message which i got during building the project.
Thanks in advance!!
