12-29-2021 11:43 AM
Hi everybody,
Can someone help me out how to write the script for the bme680 within Arduino IDE to programm a certain temperature profile with 5 Steps maybe(different temperatures and time-frames)?
Normally there is only one step pre-programmed in the examples and i m not quit sure where to adapt to correct commands in the .h and .cpp files according the latest bosch bme680 data sheet.
Best
12-29-2021 04:47 PM
Hello xxxyyy,
To run BME680 on Arduino, you could refer github example code and readme doc.
https://github.com/BoschSensortec/BSEC-Arduino-library
12-29-2021 09:13 PM
Thx for the very fast reply!
Running on arduino is not the very first problem. Indeed i really struggle with the code to programm the profile:
https://github.com/BoschSensortec/BSEC-Arduino-library/blob/master/src/bsec.cpp:
Line 464: int8_t Bsec::setBme680Config(bsec_bme_settings_t bme680Settings)
Line 470: _bme680.gas_sett.heatr_temp = bme680Settings.heater_temperature;
Line 471: _bme680.gas_sett.heatr_dur = bme680Settings.heating_duration;
==> temp + dur can be integrated into a profile but how????
Best,
12-30-2021 03:52 AM
Hello xxxyyy,
Normally, it is not recommended to modify the profile. You can directly use the existing profile. The new profile requires laboratory testing and validation.
01-05-2022 11:53 AM
He BSTRobin,
This interesting because i also work with the AI studio and the dev-kit. indeed there it is possible to make significant changes within the temp profile and the say it will be possible soon to make your own temp profiles.
Best,
